Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 01-06-2016, 05:06 PM   #26
Subarujohnny
Member#: 436694
Oh yeah, upgrades other then motor...
Blouch 16gxt turbo
650cc injectors
200 fuel pump
perrin el headers
gutted up pipe
catless turboback
Sti tmic
and some others im forgetting
Subarujohnny is offline   Reply With Quote
Old 01-06-2016, 05:46 PM   #27
hail2theTheif
Member#: 42548
1999 GF8 V7 STi Swap
Interesting the feedback on using an Accessport. I've been talking to many tuners about my ej207 and they have all recommended using the Accessport if I don't mind loosing a it of low end the AVCS would be supporting. My guess is COBB is being diplomatic with their response since they don't officially "support" those motors.
hail2theTheif is offline   Reply With Quote
Old 04-04-2016, 02:05 AM   #28
Nuunchi
Member#: 419049
so quick question. How much is the ej205 capabile of? How much boost should I be pushing with my vf23 and how much should I push this motor?
Nuunchi is offline   Reply With Quote
Old 04-04-2016, 01:11 PM   #29
hail2theTheif
Member#: 42548
From my experience having a V7 STi 207 motor tuned on an Accessport and Opensource tune I can tell you the motor is not much fun on the Accessport tune down low or for dailyablilty. If you're tracking the car and mostly using the top end, you will probably be fine.
I daily my swap and the difference was major. I gained power all across the board using the AVCS. Accessport tune was about 212hp/186tq and the Opensource was 258hp/237tq.
Old 09-26-2018, 07:06 PM   #30
trueno92
Member#: 111755
Originally Posted by skiblur View Post
ah, good call on the jdm wrx motor. I'm not sure why more people don't get them instead of rebuilding ej205's, considering the price that they go for. The compression is 9:1. They have cast or hypernautic pistons, not forged like the sti v7. I believe the pistons have the same construction as the JDM v8 sti. The heads have avcs, which means a jdm ecu controls them. AVCS is the shiz. You want it. Get a jdm ecu to run them. redline is 7200 on the motor. so you know, avcs will lower spool by 3-500 rpms when tuned. It is a solid motor, and a nice performance bump over the standard WRX motor. Great motor for the stg 4 guys. the comp ratio will be fun. Get a reflash for 93 octane and a vf series turbo and enjoy most of what the STi motor is, without the 8k redline.
Hope this answers some questions. I A performance sells a premade avcs harness. I wired my own and it took about an hour, and I'm not wiring savvy.
you could probably use a jdm sti ecu, somewhere could flash it for you.
good choice on the motor. you should be paying between 16-1900 max for the motor, with low milage.
If I can answer any other questions, let me know.
H.
Really doing the necrobump
RE: AVCS
Does ANYONE have the wiring pinout and what the engine side of the harness looks like?
trueno92 is offline   Reply With Quote
Old 09-26-2018, 07:57 PM   #31
subaru_gc8
Member#: 29292
2004 WRX wagon
nevermind
Old 09-26-2018, 08:03 PM   #32
snow_bound26
Member#: 395793
2005 92x Aero
This is what I used. I bare no responsibility if you screw it up.
https://drive.google.com/file/d/0B4s...jZDM1YWE4/view
snow_bound26 is offline   Reply With Quote
Old 09-26-2018, 09:27 PM   #33
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
some jdm AVCS 205 come with a TF03 turbo which is super tiny.
CarmelValleyWRX is offline   Reply With Quote
Old 09-27-2018, 11:29 AM   #34
trueno92
Member#: 111755
many thanks.
Anyone have much details on the V9 Ej205? no one or no websites really mention it.. looking for injector info...
Old 09-27-2018, 12:00 PM   #35
snow_bound26
Member#: 395793
2005 92x Aero
That's because there is no such thing as a V9 205. Those were loose definitions given to the 207 for enthusiasts to identify a few key differences for the 207 specifically. 205 can be identified as wire on plug w/DBC, coil pack on plug w/DBC or coil pack on plug w/DBW. They came from WRX as well as Forester XT with various turbos depending on the MY or chassis. To identify if it's from a WRX or Forester, look at the coolant crossover pipe. If it points directly at the radiator it's WRX. If it points to the right hand headlight it's Forester. JDM, ADM, and EDM all had different compression ratios to accommodate their local fuel.
Old 09-27-2018, 01:34 PM   #36
awcforever
Member#: 382066
96 Subaru
Green
I have a 2004 WRX. I just did the swap for a JDM EJ205. My engine is a high compression NON-AVCS. I spun a rod bearing on the dyno with my USDM 153k miles. So I picked up the JDM 205 from Northern Va. I believe due to the compression difference my tuner (National Speed in Richmond) had to remove about 7deg if timing for it to idle right. Iím running a Blouche 18g turbo, COBB 1050 injectors, Perrin catless downpipe to 3Ē SPT exhaust with a Perring equal length header and up pipe. It runs amazing! I hit 324hp and 305TQ. Running COBB Accessport V3.
The only things I modified was swapping oil pan, oil pickup, coolant/oil lines to turbo, cam/crank sprockets/sensors, I swapped the knock sensor just cuz. I was able to use the coolant lines it came with. they tell you to swap them but just an upper radiator hose from my Legacy parts car was required for the tighter bend, and honestly I like the heater core lines running abover the trans more than off by the steering shaft. Iím sure thereís a couple other little odds and ends but it was a straight forward project.
Just FYI....the return pipe for the turbo I believe coolant line is pressed in the head. I stuck a large screwdriver wrapped in tape through the line and pulled and twisted until it came free. Reinstallation wasnít bad.
awcforever is offline   Reply With Quote
Old 12-27-2018, 12:17 AM   #37
yoashtrey
Member#: 495174
So you werenít able to find a map from Cobb to use after you swapped in the JDM EJ205? I just bought one without AVCS, I understand I need to swap the parts you mentioned but can I just tune it through the Cobb AP or is a protune/opensource tune required because of the higher compression ratio?
yoashtrey is offline   Reply With Quote
Old 12-27-2018, 12:44 AM   #38
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
i doubt there is an "off the shelf tune" for the JDM ej205. you can tune the USDM ecu using your accessport though. you will need to custom tune it. if you have a JDM ECU you need open source tuning.
Old 11-05-2019, 08:41 PM   #39
Daymonslegacy
Member#: 508063
Hey so new to the forum I bought a jdm ej205 and plan on using a standalone ecu I plan on using the AVCS now could someone tell me what all I need to make it run I hear about the cam and crank sensors need to be switched to USDM ones does and body know where I can find the intake wiring harness to ecu pin outs
Thanks for the help
Daymonslegacy is offline   Reply With Quote
Old 11-06-2019, 02:47 AM   #40
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Given the fact that you state you want enabled avcs all you would need is to wire it.
D-Rodman is offline   Reply With Quote
Old 11-06-2019, 02:08 PM   #41
snow_bound26
Member#: 395793
2005 92x Aero
Why do you want a stand-alone ecu? Is this going to be strictly a race car? If not and you're not planning on pushing a bazillion HP then it's not necessary. Just get the appropriate JDM ecu.
Differences between JDM V9 STI, JDM V9 Spec-A/B/C, & JDM V8 Spec-C (Heads)??? nomorem3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-06-2013 09:57 PM
domestic ej20 versus JDM ej20 subenick Subaru Conversions 15 03-22-2004 07:00 PM
Differences between US EJ20 and JDM EJ20? Lee Chun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-03-2004 09:35 PM
Using a usdm ej20 block with jdm ej20 bottom end, whats the block diffrence with sti Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-02-2003 04:13 AM
Need JDM EJ20 Legacy Motor Specs from the past MY99 2.5GT Legacy Forum 4 05-09-2003 11:44 AM
