Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 01-22-2015, 04:07 AM   #26
Soobahrue
Member#: 259213
2007 WRX Limited
following the advice of this thread I'm about to purchase said wrx bbs option wheels for my 07wrx wagon....this better work!
Soobahrue is offline   Reply With Quote
Old 01-24-2015, 09:01 AM   #27
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
Is it a 3mm or 5mm spacer for the stock wrx 16x6.5 wheels to work?
Android287 is offline   Reply With Quote
Old 01-24-2015, 11:41 AM   #28
Soobahrue
Member#: 259213
2007 WRX Limited
Man it must be small, because it really almost fits without one...
Sent from my HTCONE using NASIOC mobile app
Old 01-24-2015, 05:31 PM   #29
SoapBox
Member#: 204578
My wife said she'd
buy me a Lotus, AKA REX8
Yes, 3mm.
SoapBox is offline   Reply With Quote
Old 05-17-2015, 03:00 AM   #30
HueroSTi
Member#: 198502
2000 2.5rs
I don't understand why if the rs and WRX wheel is 16x6.5 + 55 why won't the WRX clear?
HueroSTi is offline   Reply With Quote
Old 05-17-2015, 07:26 AM   #31
05-rsx
Member#: 101188
MY07 WRX Wagon
Spoke design.
05-rsx is offline   Reply With Quote
Old 05-18-2015, 01:02 AM   #32
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
98-01 RS wheels are 16x7. Spoke design is just as crucial as wheel width and offset when it comes to clearing the 4 pots.
khail19 is offline   Reply With Quote
Old 05-20-2015, 12:07 AM   #33
HueroSTi
Member#: 198502
2000 2.5rs
ah thank you
Old 05-20-2015, 05:41 PM   #34
sc00by4life
Member#: 97135
offset has very little, if anything, to do with brake clearance.
Old 10-11-2018, 09:09 AM   #35
Legacy_H6TT
Member#: 137502
1990 Legacy GT-t
Blue over silver
I can confirm that the Spec B 18x7.5 55p do NOT clear JDM Subaru 4 pots... My wheels arrived this morning having bought them based on reading/seeing other 55p rims clearing OK but they need about 5-6mm extra between the calliper and back of the wheel spoke.
I have a number of potential solutions to this problem;
1. swap out the wheels however I do like the style of the Spec B 10 spokes.
2. Grind the calliper down - I'm going to pop out a piston and measure to see how much meat there is to play with, but i don't want to grind the SUBARU lettering completely off.
3. Reposition the calliper. This is my preferred option since I want to mount it lower and further out so I can run a 316mm rotor. There might just be enough clearance doing this but if I can find a 5x100 316mmx25mm rotor with a 55mm hat depth then this should work. I'm designing a custom bracket specifically to achieve this.
Legacy_H6TT is offline   Reply With Quote
Old 10-11-2018, 09:11 AM   #36
Legacy_H6TT
Member#: 137502
1990 Legacy GT-t
Blue over silver
Wrong. Offset has a lot to do with brake clearance, amongst other things. a 55p wheel for example will give less clearance than a 48p, all else being equal.
Old 10-17-2018, 04:11 AM   #37
Johhn2
Member#: 490304
yes Stock 17" 9-2x Aero wheels clear.
Johhn2 is offline   Reply With Quote
WTB: Kartboy 2-Pot Adapters, 16x7 Wheels, FHI 4/2 Pot Rotors/Pads, 02 AW STI Scoop proletariandan Private 'Wanted' Classifieds 0 03-18-2009 04:17 PM
Subaru 4/2 Pot Caliper Clearance? Buggn' Out Brakes, Steering & Suspension 4 11-18-2008 06:18 PM
P1's and factory 4 pot/2 pot clearance hypoxvi Tire & Wheel 2 09-01-2008 11:01 AM
