09-02-2018, 09:06 PM | #1 |
Member#: 228010
Vehicle:2019 WRX Limited Crystal White Pearl |
Ceramic Coat
I ordered a ceramic coat bottle and was curious.. is it realistic to spread out the process over a week while using the car to commute?
... ex... Monday..Wash car and ironX and claybar. Tuesday.. ONR front panels only, dry panels.. polish with DA, spray IPA, ceramic coat. Wednesday.. same as above but one side.. Thursday.. same as above but other side Friday... same as above but backside and roof. If I use a new applicator microfiber each day, should be fine, right? Car has 1100 miles so not much correction to do...
09-02-2018, 10:23 PM | #2 |
Member#: 82391
Vehicle:08 OBP Sti |
Thats how im handling things right now im still newb with the 7424 and 10 year old paint my second time trying to make the car look good i noticed its way to warm to do the correction when its to hot.
So far ive been through the rear end and the hood in the last two weeks had to stop at the fenders. |
09-02-2018, 11:17 PM | #3 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
what product are you using? if its one of the more permanent ones, I wouldnt stretch it out, but if its one of the ones that lasts like a year or 2, eh it doenst matter so much.
09-03-2018, 01:24 AM | #4 |
Member#: 461897
Yes if that will work for you if you. If some reason you go a day without after polish just check the panel for any contamination
09-03-2018, 02:44 PM | #5 | |
Member#: 228010
I was going to spread out the polishing portion too since its the final decontamination step.. but now im wondering if that will make a mess out of my polishing pads.. |
09-03-2018, 03:13 PM | #6 |
Member#: 29292
SCIC
I would do the polishing all in one day if you can, and then with in a few days I would use the catpro reload and then do the UK,
09-03-2018, 03:14 PM | #7 |
Member#: 475983
Vehicle:2018 WRX Limited Silver |
I have used quartz uk several times myself.
With a new 2019 I d say DA polishing is OK but will go very quick as not much too correct. That whole project takes a few hours at most. I d set aside one day and do it all. The coating also goes very quick. Too me all the set up and cleanup is a lot of wasted time. Don t expect the coating too last a year or more either FYI. It will look good but you ll see the diminished beading esp on the sides faster than you will expect. White is also super easy and forgiving. |
09-03-2018, 04:09 PM | #8 | |
Member#: 29292
SCIC
09-03-2018, 04:13 PM | #9 | |
Member#: 475983
One panel a day though is too slow, LOL. |
09-03-2018, 08:31 PM | #10 |
Member#: 228010
Alrighty.. sounds like I should stripper wash on a friday after work..
FRIDAY: foam cannon with walmart vehicle and boat wash soap (alkaline). After mitting, rinse and Refoam and use nanoskin glove as claybar step. Rinse... dry... 2 hours. SATURDAY: DA polish .. quick since new car... use grease remover spray or IPA to remove polishing oils and residue. Dry car... 2 hours probably. SUNDAY: apply Cquartz to whole car. 2 hours? Spread out loke this will work with kids situation and use wifes car on weekend so it stays clean indoors. |
09-03-2018, 08:33 PM | #11 | |
Member#: 228010
09-04-2018, 07:41 AM | #12 | |
Member#: 475983
much better plan for a weekend project. You may find yourself going right to the next step. On a new car it would be easy to do in one day. The hardest step is the correction and you ll have hardly anything on yours. |
09-04-2018, 11:08 AM | #13 | |||
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
Touching back on your original post... If you do decide to do one panel per day DO NOT use the same applicator each day. As you keep going the new product will keep the applicator "wet" so it's not going to flash off and harden as quickly, but the next day it's going to be full of little bits of hard ceramic / glass. Toss it out and use a new applicator. The same goes for the microfiber towels you use to wipe off the panels. If you did the whole car all in a day (which I recommend as it's just as fast as waxing) you can get by with a couple towels for the entire car. Whether you do it all at once or one panel a day the towels you use for wiping it up need to go in the trash. Like the applicator, that product is going to flash, harden, and load the towels with ceramic / glass particles by the next day. |
09-04-2018, 06:32 PM | #14 |
Member#: 486850
I've had it professionally done on wheels
It takes them a weekend, and then they actually told me to let the wheels sit and let the coating harden for a week just to make sure |
09-04-2018, 08:58 PM | #15 |
Member#: 228010
If I have extra Ill use it on my winters before they get mounted.
Im starting to think paint correction is a wasted effort on a car thats never been through a car wash with 1100 miles.. hand washed with 2 bucket method twice so far. |
09-05-2018, 07:41 AM | #16 |
Merci Buckets
Most likely yes. Give the car a walk-around in the sun and make sure there are no swirls or other marks that bother you. Once you put that ceramic coating on you won't be able to polish out any imperfections for the few years it takes for the ceramic coating to finally disappear. If it's in really good condition the most you might want to do is just a finishing pad with a finishing / high gloss polish to make it really shine.
09-05-2018, 01:44 PM | #17 | |
Member#: 29292
SCIC
09-05-2018, 09:46 PM | #18 |
Member#: 485973
Vehicle:2018 WRX STI Red |
FWIW, as someone who is still newer to this, I think your alternative plan of doing the entire coating in a single go is best. I'm not familiar with the specific product you are using, but I imagine that it may be recommended that any treated area remain dry for a certain amount of time after application? (at least with the ceramics and polymer sealants I've used this has been advised.) If you apply the ceramic coating over a period of a week, and you plan to drive the car during this period, you might have to worry about cure times vs. inclement weather potential adversely affecting the final results.
I've personally spread the correction process over several days because of how long this process takes me in some instances. I've done an abrasive wash, decon, and clay all in a single day, and then proceeded to do a more aggressive compounding the next day, and a lighter finishing polish the day after along with the polymer sealant. Before beginning a session, I've just done a wipe down with a diluted IPA solution. I'm not sure how big of a job your car will be, but both my BRZ and STI needed a substantial amount of correction when brand new to the point where, as I am only working with a short-throw DA, I hit them both with M105 as I wanted a faster cut (even then, it was a slow process to achieve the level of correction I desired) (mind you, these were/are WRB/PR colors, both of which showed their defects pretty visibly, and I wanted them to appear as flawless as possible even when directly reflecting the brightest sunlight of the day, which on those colors loves to show any and all swirl marks.) |
09-06-2018, 09:14 AM | #19 | |
Member#: 228010
09-06-2018, 07:24 PM | #20 | |
Member#: 485973
09-09-2018, 09:48 AM | #21 |
Member#: 228010
Alright.. im done.. yesterday morning I polished the hood, roof and trunk deck since they had dealer installed scratches. I ended up doing an IPA spraydown and also used carpro ls eraser. I only ended up using half the bottle of cquartz uk 3.0 and I also ended up using the short pile side of a quality mircofiber towel to buff the product after waiting 20 seconds for flash to start happening. The seude towel the kit came with wasnt working well... streaking and not even looking.
My concern is that I wonder if any product was applied since maybe the microfiber towel was absorbing a lot... 24 hours later now and it looks fine.. just wonder how thick it applied. I applied reload a hour after cquartz as directed.. so I wont really know for a few months how well it went on. |
09-09-2018, 12:06 PM | #22 |
Member#: 82391
Im still playing the wait game till i can go at the rest of the car at once and have a few look overs for mistakes right now rain is coming down when it decides not to be to hot. I dont have a place to do the work freely so its a bit of wait.
Last week i was able to hide a nice 4 inch scratch on the front hood someone gave hours after i was checking why my ps fluid had changed to full red color then back to its dirty shade. |
09-09-2018, 03:21 PM | #23 | |
Member#: 228010
09-10-2018, 10:12 AM | #24 | |
Merci Buckets
10-16-2018, 04:58 PM | #25 |
Member#: 486914
Vehicle:2019 WRX Limited CWP |
Gyeon Ceramic
Anyone heard of or had any experience with this product?
GYEON Quartz Q² Syncro 50ml 9h Professional Ceramic Coating Kit $180 on Amazon. My PPF guy told me he just tried it and likes it. He also said you had to buy this for about $15 on Amazon Gyeon Q²M PREP Degreasing Product before Car Ceramic Coating for all surfaces Is this stuff really better than the older, cheaper polymer sealants like the Car Guys, Zaino or Meguiars? I understand about claying a car, and have done so, and about polishing, but only done that by hand and do not have DA orbital. I am deathly afraid of really taking the finish off because I have never used one, and heard horror stories about metal creases have the paint taken right off. |
