Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2020
Old 10-24-2018, 09:10 PM   #26
get_schwifty
Member#: 485973
2018 WRX STI
Red
My biggest gripe is that I am a cripple so some days I can't drive it. I like the rattling...it's an appropriate approximation to the state of joints in my body.
get_schwifty is offline   Reply With Quote
Old 10-24-2018, 10:59 PM   #27
Chas2
Member#: 486914
2019 WRX Limited
CWP
Originally Posted by TifosiWA View Post
Are you talking about the auto dimming of the center console? If yes, you must have dash brightness adjustment set to the max. When you do it, it over-rides the sensor. Turn the dash brightness down one and then the auto dimming function of the center console will work according to whatever you had set your light sensitivity to. And yes, this is in the manual but I think it can be easily missed, I know I did.
Thanks so much!
Chas2 is offline   Reply With Quote
Old 10-25-2018, 06:33 AM   #28
rtv900
Member#: 428511
2016 STI
Originally Posted by lateralus1082 View Post
1) I'm reading the manual right now and it says nothing about calibration for outside temp. Just a note that it's the temp that's around the sensor.
maybe I'm mistaken and it's another car of mine that allows you to calibrate it
rtv900 is online now   Reply With Quote
Old 10-25-2018, 07:46 AM   #29
Fahrenheit85
Member#: 488754
Am I the only one having a issue with the auto up/down windows? Seems like if I want it anywhere between full open or close I gotta tap the button a few times to get it where I want the window. It's really annoying.
Fahrenheit85 is offline   Reply With Quote
Old 10-25-2018, 01:32 PM   #30
openuser
Member#: 486898
This .. for two weeks I drove around blinding people with the light reflected off of my face.
openuser is offline   Reply With Quote
Old 10-25-2018, 02:48 PM   #31
hicompb18c1
Member#: 489971
2018 WRX STI
Only real gripe is the infotainment system as a whole. I came from a Base STI and now am in a 2019 Limited with HK speakers. For a $42,000 car this system is just not easy to use or very nice. Disconnects my Bluetooth occasionally. Equalizer that only gives you 3 channels of adjustment? Absolutely embarrassing.
hicompb18c1 is offline   Reply With Quote
Old 10-25-2018, 03:02 PM   #32
ProZach626
Member#: 186084
2018 STI
The radio. Complete garbage, but I knew what I was getting into, being that I was coming from a 13 WRX and then a 15 STI.
The car will always rattle and it will ride rough. You're just going to have to deal with that. Put it out of your mind.
ProZach626 is offline   Reply With Quote
Old 10-25-2018, 03:23 PM   #33
SupraSentient
Member#: 487614
2019 WRX
Originally Posted by Chas2 View Post
2019 WRX Limited
I like the car a lot in general. There are some nits...which may be user error, but I think operation is still not intuitive.
1. Outside temp seems to always read 5-6 degrees high.
2. HK System boots up very slowly. I cannot plug the iPhone in until the HU boots up.
a. If I do plug in before car starts, there is no connectivity with HU, and you have to unplug and replug after boot up to get connection.
b. Sometimes there is some connectivity going on, but the iPhone touch screen becomes unresponsive, and the HU also shows CarPlay as grayed out and is unresponsive. You have to unplug and replug.
<snip>
Yikes, I'm glad I didn't get that HK system. My regular radio boots up very quick, I plug my Android in as soon as I get in the car. Takes it a few seconds to recognize the phone and pull up the AA screen but it's not bad. I've read the Apple one isn't as good as Android, but also you could try using a different cord. Some of the cords do not work well at all. Haven't had to unplug and replug in yet either.
I really wish the steering wheel controls would interact with the AA, or hell just work better in general. I pretty much can only depend on it for volume.
SupraSentient is offline   Reply With Quote
Old 10-25-2018, 03:39 PM   #34
MagicDoorHinge
Member#: 481354
2019 WRX STI
WR Blue
I use google play music and the left and right keys (on the same 4-way pad as the volume) skips tracks forward and backward. The mute button in the middle pauses the song. The source button allows me to switch to am/fm radio. What music service do you use that doesn't seem to be compatible with Android Auto? Pandora? Spotify?
MagicDoorHinge is offline   Reply With Quote
Old 10-25-2018, 04:04 PM   #35
WhiteRX09
Member#: 321304
2013 WRX
Phone calls bother me most. Max volume and you can't hear ****. It is like they didn't test it.
WhiteRX09 is offline   Reply With Quote
Old 10-25-2018, 05:08 PM   #36
thatdamnalex
Member#: 441196
2016 sti
I recently got a rattle in my dashboard that only happens at low speeds. It sounds like its coming from behind the steering wheel. It doesn't do it over big bumps just little bumpy parts on the road when I'm coming to a stop or something
thatdamnalex is offline   Reply With Quote
Old 10-26-2018, 01:13 PM   #37
SupraSentient
Member#: 487614
2019 WRX
Google Play and Pandora. It's entirely possible that the one time I tried it I went full derp I had hoped that the steering wheel would at least let me switch between navigation and Google Play, or switch from AM/FM/SXM to Android Auto. It's not a huge menace though since I've mostly memorized the layout and I can switch without looking.
Old 10-26-2018, 10:04 PM   #38
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
It's probably near the same as my rattle. Welcome to my hell.
Scorpius is offline   Reply With Quote
Old 10-29-2018, 06:10 AM   #39
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
If you mke calls within Android auto the sound quality is amazing in comparison.. its not using bluetooth for AA calls.
MtnXfreeride is offline   Reply With Quote
Old 10-29-2018, 06:12 AM   #40
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
Not sure what that guy was talking about. I have a limited with HK and it boots up instantly. I also can plug my phone in at any time even before turning the car on. Android auto does take about 30 seconds to become available.. takes a lot longer on my wifes older phone.
Old 10-29-2018, 08:32 AM   #41
Obviously Tyler
Member#: 395955
2019 Mazda 3 Premium
1999 Miata 5MT
Wait for freezing temperatures, that's when all of the evil little rattles come to life.
Not a 19, but my exhaust vibrates some of the rear shelf plastic against my back glass when it's cold outside and it's so loud.
Obviously Tyler is offline   Reply With Quote
Old 10-29-2018, 02:40 PM   #42
VanillaEps
Member#: 8271
2019 STi Limited
ISM
Has anyone else had issues with the SRH? My SRH light comes on and off randomly.
VanillaEps is offline   Reply With Quote
Old 10-29-2018, 02:57 PM   #43
MagicDoorHinge
Member#: 481354
2019 WRX STI
WR Blue
I have not seen that warning light. Question, when you start your car do your SRH scan left and right before locking into place? I wonder if that is some sort of check to let you know whether it is working or not.
Old 10-29-2018, 04:33 PM   #44
rw2453
Member#: 468643
I just turn my music up and boom. No more rattles!
rw2453 is offline   Reply With Quote
Old 10-29-2018, 05:11 PM   #45
Chas2
Member#: 486914
2019 WRX Limited
CWP
I am sure the left right scanning on start up is a test. That is what my other cars with SRH aka AFS did/do
Old 10-29-2018, 09:01 PM   #46
Subie-Drew
Member#: 490059
Default Same
yeah I have the exact same rattle... 3,500 miles and just started noticing it.
Subie-Drew is offline   Reply With Quote
Old 10-29-2018, 10:57 PM   #47
Sideways
Member#: 6295
2019 Limited.... FM reception is absolutely garbage. Sat radio is fine thought.
BUT no rattles, granted I only have 1k miles, but this is my 8th WRX over the last 17 years and every other one were rattling well before.
LOVE the feel of the improved transmission over the 2016 and the steering responsive bi leds are so much better than the funky LEDs on the 15-17. And the LEDs fogs are a bonus.
And despite the horrible FM reception, finally having android auto is nice.
Sideways is offline   Reply With Quote
Old 11-02-2018, 02:28 PM   #48
Chas2
Member#: 486914
2019 WRX Limited
CWP
I agree, they move quickly and it takes some time to get used to
Old 11-02-2018, 02:37 PM   #49
Chas2
Member#: 486914
2019 WRX Limited
CWP
It turns out that I have to unlock the iPhone first. A new iOS 12 feature. CarPlay is recognized by the phone as a USB device and the lock out is a security feature. Unlike plugging the iPhone into a computer, however, thankfully you do not get a separate prompt on the iPhone asking if you want to give the external device access.
Old 11-02-2018, 03:02 PM   #50
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
SRH is speed based so your car needs to be moving for it to work.
jasonwrx86 is offline   Reply With Quote
