Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 10-09-2018, 11:49 PM   #11751
Bolster
Member#: 22290
2002 STI Ver 9
Spec C Wagon
Got my Version 9 Spec C motor in and running.... only to find an oil leak at the external oil cooler unit on the block. Damaged in shipping, so I had to order one from the UK. Was nice to see it start and run for a minute without CELs. Running a Ver 8 ECUs for now.
Bolster is offline   Reply With Quote
Old 10-10-2018, 04:39 AM   #11752
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
Originally Posted by mrsaturn7085 View Post
The USDM intercoolers are almost the same, too. Lots of money for little (or no) benefit). I could not fit the 2006-2007 intercooler behind the DBW throttle without firewall interference.
I think the benefit of the OEM style is having the throttle response given the large reservoir right in front of the throttle. Turbo lag is negligible but the throttle lag does exist with a FMIC. You can tune around it with a little more spark, etc. but it *DOES* need to be considered when you tune the tip-in.
EDIT: Hyper - are you logging pre-throttle boost in that photo? That's a great place to do it that I hadn't considered, but for anti-lag tuning, I've been brainstorming where I want to stick the tap.
What I *really* wouldn't mind having is a restrictor with something like this built-in so I could measure PR and hold it around 1.8.
yes, it goes directly into the autronic map sensor
honestly I can't say I noticed any added throttle lag when I added my lateral FMIC setup. I can see when it can become an issue with long piping and a core made out of soda cans
that's a cool restrictor, never seen one like that before, we've always been using a long trumpet copied from prodrive grN
Hyper is offline   Reply With Quote
Old 10-10-2018, 04:00 PM   #11753
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
I've got 3 and haven't really noticed any difference in how they perform:
1. Prodrive 33mm aluminum (N15)
2. TMR 34mm steel (N14-N15)
3. STI 33mm long aluminum (N14-N15)
As far as I can tell, the only difference is which inlet you want to run. The STI long one needs the STI inlet while all the others work find with the Samco/Prodrive.
mrsaturn7085 is offline   Reply With Quote
Old 10-20-2018, 07:37 PM   #11754
Bolster
Member#: 22290
2002 STI Ver 9
Spec C Wagon
Update for those buying twin scroll engines: the newer style GDB JDM twin scroll down pipe is the exact same length as the USDM downpipe, so you won’t need anything besides possibly an adapter for the 2.5” donut flange in the down pipe to your car-back if it has a 3.0” flange, for instance.
Old 10-20-2018, 08:14 PM   #11755
Bolster
Member#: 22290
2002 STI Ver 9
Spec C Wagon
Here is a shot of the downpipe.
Old 10-21-2018, 12:23 PM   #11756
mephistomarius
Member#: 330895
2002 Impreza wrx
blaze yellow
Originally Posted by Bolster View Post
Update for those buying twin scroll engines: the newer style GDB JDM twin scroll down pipe is the exact same length as the USDM downpipe, so you wont need anything besides possibly an adapter for the 2.5 donut flange in the down pipe to your car-back if it has a 3.0 flange, for instance.
This is facts, I bought a jdm exhaust only to find my dp was too long, I had an exhaust shop cut the 3" off and reweld the flange on the dp. Now I'm stuck with jdm length exhausts.
mephistomarius is offline   Reply With Quote
Old 10-21-2018, 10:34 PM   #11757
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Default EJ207 Owners?
The twin scroll down pipe of a ver 9 is long and equal to our usdm, the twin scroll down pipe on a ver 8 is short as is a single scroll down pipe of a ver 7.
D-Rodman is offline   Reply With Quote
Old 10-27-2018, 05:31 PM   #11758
suprabats
Member#: 357908
Correct, because I swapped my V7 to twin scroll from single scroll, I used the tomioka twin scroll usdm length dp. Nice piece and performs well.
suprabats is offline   Reply With Quote
Old 11-08-2018, 04:04 PM   #11759
JaviJuice
Member#: 126376
2007 wrx lmtd
Hey everyone,Side question:
Kinugawa wastegate actuator for the vf36, preload is 3 full turns? I found one reference to this but wanted to double check... 1.2 bar spring if it matters. TIA.
JaviJuice is offline   Reply With Quote
Old 11-08-2018, 04:17 PM   #11760
Bansheeboy11
Member#: 182415
1999 RS
I went off their site for a baseline to start with but it was pretty far off, you'll have to readjust it as you do logs to find where it should be set at.
Bansheeboy11 is offline   Reply With Quote
Old 12-04-2018, 01:03 PM   #11761
JaviJuice
Member#: 126376
2007 wrx lmtd
Do V9 ej207s have a COmbi valve? Or where is the barometric sensor in the v9207? Total noob with this stuff but cant really seem to find this infor for a 207... also what are avg barometer sensor numbers upon startup? Thanks in advance!
Old 12-04-2018, 02:16 PM   #11762
mrsaturn7085
Member#: 375462
WR Blue
Baro is internal to the ECU or potentially read by the MAP before starting. Never bothered to check, but it's one of the two.
Old 12-05-2018, 10:12 AM   #11763
JaviJuice
Member#: 126376
2007 wrx lmtd
So if im running my usdm ecu, on a jdm motor, what would be the way to solve this? Finding the baro sensor from the old 255 and connecting it? Or is there another way around it?
Old 12-05-2018, 01:17 PM   #11764
mrsaturn7085
Member#: 375462
WR Blue
There is nothing to solve...
Old 01-15-2019, 12:44 PM   #11765
GF4dad
Member#: 360001
06 STI
World rally blue
New 207 owners here. I recently acquired a v7 ej207 for my 2000 impreza RS. Any advice what do before I drop this motor in my car? What else do I need to check? Ill be running JDM ecu. Do I need tune for 93oct? Im only going to run it in stock form nothing crazy.
GF4dad is offline   Reply With Quote
Old 01-15-2019, 01:42 PM   #11766
my name is joe
Member#: 171412
only thing you have to worry about is passing emissions. Most don't connect to the jdm ecu's. Unless it's a track car then it doesn't matter. Just do the normal maintenance stuff and go on your way.
my name is joe is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
