12-28-2018, 08:39 PM | #1 |
Member#: 430450
Vehicle:2019 STI Lapis Blue |
2019 sti build 507awhp!
So I have a 2019 STI that I'm building. For now I'm going full bolt on as there really isn't much info out there on how much power the refreshed pistons can take. I'll go stage 2 IAG closed deck later. For now my goal is a reliable 400awhp on stock internals. Even if the car can safely take 400+ im shutting things down at 400 as there is no reason to trash the stock block. All parts are still rolling in and I have yet to tare into my car. My question is am I forgetting anything?
Mod list: *Forced Performance Red Ball Bearing *Forced Performance inlet *Cylinder 4 cooling kit *Invidia catless downpipe *Carven single exit catback *ETS 4" front mount *ETS SD intake *Tial 50mm BOV *COBB EBCS 1/4in EWG Fitting Kit *Grimmspeed EBCS *Killer B uppipe 38mm Tial ewg *Killer B header ceramic coated *Killer b pan, baffle, pickup *ID 1300cc injectors *Fuelab 6 Micron filter *Torque Solutions TGV *Six Star rails, -6an lines, FPR *Full Cobb e85 kit *Visconti basket upgrade *Walbro 485 pump *DW hard wire kit *South Bend stage 3 clutch *IAG street AOS *NGK Spark Plugs LFR7AIX *Air pump block off kit *Group N engine, trans mount *SuperPro pitch stop *Perrin brace for pitch stop *DDS carbon fiber drive shaft *SuperPro rear sway bar, endlinks *superPro adjustable rear lower arms *superpro adjustable toe arms *superPro front sway bar endlinks *SuperPro bushing all around *Fortune Auto coiloves 9K swift springs *Wedsport RN-05M 18x9.5 265 35 18 good year F1's
12-28-2018, 09:39 PM | #2 |
Member#: 139053
planning to upgrade suspension?
if so ill buy your stock suspension |
12-28-2018, 10:04 PM | #3 |
Member#: 430450
12-28-2018, 10:18 PM | #4 |
Member#: 461647
Vehicle:209 STI ISM |
Currently stock block, 2019 STI, fp red turbo, EWG at 21lbs pushing 450
12-28-2018, 10:19 PM | #5 |
Member#: 461647
Would recommend going fmic. Intake temps are always -14 below ambient
12-28-2018, 10:29 PM | #6 |
Member#: 430450
12-28-2018, 11:32 PM | #7 |
Member#: 461647
12-29-2018, 12:18 AM | #8 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
12-29-2018, 01:20 AM | #9 |
Member#: 461647
12-29-2018, 02:02 AM | #10 |
Member#: 460907
RMIC
Congratulations, you have inaccurate sensors.
Try and fight physics, I'm sure it'll work out great. |
12-29-2018, 06:04 AM | #11 | |
Member#: 461647
These are the same sensors used to measure before and after ***129335;***127997;****9794;***65039; As far as I am concerned this is accurate. If someone can help educate me then I am open to that. |
12-29-2018, 06:06 AM | #12 |
Member#: 461647
Let me add to the intake temps.... that’s at cruising of course. Idle or at a stop if not below ambient ***129315;
12-29-2018, 09:49 AM | #13 |
Member#: 476573
MAIC
Vehicle:2008 Impreza WRX STi Silver |
An air to air intercooler cannot cool charge air to a temperature colder than ambient, its just not possible. The absolute best you can hope for with an air to air intercooler is to have charge air temps be equal to the ambient?temp. Just think about it, say your charge air is 110*F and ambient temps are 73*. How does 73* air cool the charge air below 73*? It cant.
12-29-2018, 07:59 PM | #14 |
Member#: 430450
okay enough abt air to air intercoolers.
How hard it installing all four plugs? Also turbo install. Ive never done a turbo before. |
12-29-2018, 10:05 PM | #15 |
Member#: 332408
12-29-2018, 10:43 PM | #16 |
Member#: 430450
So I'm thinking abt swaping my Cobb intake out for the 18-19 AEM intake. Looking like the map sensor is now inside the box on the aem and filter looks much larger. Anyone have any feed back on this?
12-30-2018, 08:55 AM | #17 |
Member#: 476573
MAIC
MAF*. You probably wont see any discernable difference in performance.
12-31-2018, 09:25 PM | #18 | |
Member#: 113908
You can expect the ambient temp to be higher if you were sitting and the sensor is heat soaked (the ambient temp sensor is in the bumper/grill area where it gets a lot of heat from the radiator etc and not much direct airflow to quickly cool it). But if you are constantly seeing lower intake temp vs ambient, one of your sensors are off. Front mounts are great though. I saw about 10 degrees over ambient with the factory top mount and now i am 3-4 degrees over ambient with the front mount. |
01-01-2019, 07:47 AM | #19 | |
Member#: 428511
Vehicle:2016 STI |
Not the actual intake manifold temp post intercooler? Or do the 19's have different placed sensors than my 16? and yeah, it cools it below ambient? nice! |
01-01-2019, 01:27 PM | #20 |
Member#: 93750
MWSOC
Lol. Gotta love nasioc
01-01-2019, 09:32 PM | #21 |
Member#: 468393
Vehicle:2017 STI |
The AEM flows more than the Cobb. Whether it's worth it or not is debatable. I never liked the noisy Cobb box, though the design is efficient.
01-02-2019, 09:07 PM | #22 |
Member#: 430450
The Cobb is loud for sure. My tuner told me the AEM doesn't flow as good as Cobb. I cretin he hasn't seen the re design for the 18-19 sti.
01-02-2019, 09:29 PM | #23 | |
Member#: 468393
Vehicle:2017 STI |
Again, not significant but .... |
01-03-2019, 07:40 AM | #24 |
Member#: 450712
Vehicle:04 STi WRB |
Off Topic: What brand of floor jack's are you using? How do you like them?
01-03-2019, 01:10 PM | #25 |
Member#: 476573
MAIC
