Welcome to the North American Subaru Impreza Owners Club Sunday December 8, 2019
Old 12-28-2018, 09:39 PM   #1
james-30
Member#: 430450
2019 STI
Lapis Blue
Default 2019 sti build
So I have a 2019 STI that I'm building. For now I'm going full bolt on as there really isn't much info out there on how much power the refreshed pistons can take. I'll go stage 2 IAG closed deck later. For now my goal is a reliable 400awhp on stock internals. Even if the car can safely take 400+ im shutting things down at 400 as there is no reason to trash the stock block. All parts are still rolling in and I have yet to tare into my car. My question is am I forgetting anything?
Mod list:
*BCP x500+ turbo with oil lines
*Invidia catless downpipe
*Carven single exit catback
*ETS 4" front mount
*Tial 50mm BOV
*Grimmspeed up pipe with 40mm ts ewg
*Grimmspeed EBCS
*ID 1300cc injectors
*P&L Rails, -6NA lines, adjustable regulator
*High flow 340 lph pump
*DW hard wire kit
*COBB EBCS 1/4in EWG Fitting Kit
*ETS intake
*Full Cobb e85 kit
*South Bend stage 3 clutch
*HKS ELH
*IAG street AOS
*IAG TGV
*IAG 3mm Phenolic Spacers
*Perrin Turbo Inlet Hose
*NGK Spark Plugs LFR7AIX
*Air pump block off kit
*Group N engine, pitch stop and trans mount
*DDS carbon fiber drive shaft
*SuperPro rear sway bar, endlinks
*superPro adjustable rear lower arms
*superpro adjustable toe arms
*superPro front sway bar endlinks
*SuperPro bushing all around
*Fortune Auto coiloves 9K swift springs
*Wedsport RN-05M 18x9.5 265 35 18 good year F1's
james-30 is offline   Reply With Quote
Old 12-28-2018, 10:39 PM   #2
krismo
Member#: 139053
planning to upgrade suspension?
if so ill buy your stock suspension
krismo is offline   Reply With Quote
Old 12-28-2018, 11:04 PM   #3
james-30
Member#: 430450
2019 STI
Lapis Blue
Yes, I already have most all parts for my suspension as well. Still need coil overs and rear adjustable lower arms. Replacing all bushings with super pro and also I have a DDS driveshaft.
Old 12-28-2018, 11:18 PM   #4
greygonzalez
Member#: 461647
209 STI
ISM
Currently stock block, 2019 STI, fp red turbo, EWG at 21lbs pushing 450
greygonzalez is offline   Reply With Quote
Old 12-28-2018, 11:19 PM   #5
greygonzalez
Member#: 461647
209 STI
ISM
Would recommend going fmic. Intake temps are always -14 below ambient
Old 12-28-2018, 11:29 PM   #6
james-30
Member#: 430450
2019 STI
Lapis Blue
E85?
I almost went with FP black.
How many miles are on your 450hp build?
Old 12-29-2018, 12:32 AM   #7
greygonzalez
Member#: 461647
209 STI
ISM
Originally Posted by james-30 View Post
E85?
I was recommended fp rep by mike Adkins - mtuned. Trust him . JR says fp blue or black.
About 1k on it so far. I do drive the car hard cuz I have a daily
Old 12-29-2018, 01:18 AM   #8
GlarryHoodDIT
Member#: 460907
2016 WRX
Lol wat. Not on this planet.
GlarryHoodDIT is offline   Reply With Quote
Old 12-29-2018, 02:20 AM   #9
greygonzalez
Member#: 461647
209 STI
ISM
Intake temp 63. Ambient 76, okay -13
Old 12-29-2018, 03:02 AM   #10
GlarryHoodDIT
Member#: 460907
2016 WRX
Congratulations, you have inaccurate sensors.
Try and fight physics, I'm sure it'll work out great.
Old 12-29-2018, 07:04 AM   #11
greygonzalez
Member#: 461647
209 STI
ISM
These are the same sensors used to measure before and after 🤷🏽*♂️
As far as I am concerned this is accurate. If someone can help educate me then I am open to that.
Old 12-29-2018, 07:06 AM   #12
greygonzalez
Member#: 461647
209 STI
ISM
Let me add to the intake temps.... thatís at cruising of course. Idle or at a stop if not below ambient 🤣
Old 12-29-2018, 10:49 AM   #13
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
An air to air intercooler cannot cool charge air to a temperature colder than ambient, its just not possible. The absolute best you can hope for with an air to air intercooler is to have charge air temps be equal to the ambient?temp. Just think about it, say your charge air is 110*F and ambient temps are 73*. How does 73* air cool the charge air below 73*? It cant.
Turpid Porpoise is offline   Reply With Quote
Old 12-29-2018, 08:59 PM   #14
james-30
Member#: 430450
2019 STI
Lapis Blue
okay enough abt air to air intercoolers.
How hard it installing all four plugs? Also turbo install. Ive never done a turbo before.
Old 12-29-2018, 11:05 PM   #15
ayau
Member#: 332408
Intake manifold temp and intake temps are what you want to compare. The ambient temp on the dash isn't using the same intake sensor and will always read lower than intake temp.
ayau is offline   Reply With Quote
Old 12-29-2018, 11:43 PM   #16
james-30
Member#: 430450
2019 STI
Lapis Blue
So I'm thinking abt swaping my Cobb intake out for the 18-19 AEM intake. Looking like the map sensor is now inside the box on the aem and filter looks much larger. Anyone have any feed back on this?
Old 12-30-2018, 09:55 AM   #17
Turpid Porpoise
Member#: 476573
MAF*. You probably wont see any discernable difference in performance.
Old 12-31-2018, 10:25 PM   #18
need2blower
Member#: 113908
These are the same sensors used to measure before and after ����*♂️
I have to disagree as well, you will never get below ambient with an air-air intercooler. It's just not possible, the laws of thermodynamics say so.
You can expect the ambient temp to be higher if you were sitting and the sensor is heat soaked (the ambient temp sensor is in the bumper/grill area where it gets a lot of heat from the radiator etc and not much direct airflow to quickly cool it). But if you are constantly seeing lower intake temp vs ambient, one of your sensors are off.
Front mounts are great though. I saw about 10 degrees over ambient with the factory top mount and now i am 3-4 degrees over ambient with the front mount.
need2blower is offline   Reply With Quote
Old 01-01-2019, 08:47 AM   #19
rtv900
Member#: 428511
2016 STI
Dude, for one, isn't that 'intake temp' on your AP the Air Box temp right at your filter anyway?
Not the actual intake manifold temp post intercooler?
Or do the 19's have different placed sensors than my 16?
and yeah, it cools it below ambient? nice!
rtv900 is offline   Reply With Quote
Old 01-01-2019, 02:27 PM   #20
Foo_Blyat
Member#: 93750
Lol. Gotta love nasioc
Foo_Blyat is offline   Reply With Quote
Old 01-01-2019, 10:32 PM   #21
PDXREALTOR
Member#: 468393
2017 STI
The AEM flows more than the Cobb. Whether it's worth it or not is debatable. I never liked the noisy Cobb box, though the design is efficient.
PDXREALTOR is offline   Reply With Quote
Old 01-02-2019, 10:07 PM   #22
james-30
Member#: 430450
2019 STI
Lapis Blue
The Cobb is loud for sure. My tuner told me the AEM doesn't flow as good as Cobb. I cretin he hasn't seen the re design for the 18-19 sti.
Old 01-02-2019, 10:29 PM   #23
PDXREALTOR
Member#: 468393
2017 STI
I have MAF logs that show the AEM flows more than the cobb on my 17 sti. My tuner thought the same thing.... He even sent me the log and I had to point out to him that the flow was higher on the AEM.
Again, not significant but ....
Old 01-03-2019, 08:40 AM   #24
horsePOOGAS
Member#: 450712
04 STi
Off Topic: What brand of floor jack's are you using? How do you like them?
horsePOOGAS is offline   Reply With Quote
Old 01-03-2019, 02:10 PM   #25
Turpid Porpoise
Member#: 476573
Those are quickjacks, I use them for my corvette as well and they work great.
