Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 02-19-2005, 12:59 AM   #1
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
Default jdm sti ver5-6 cluster pinout for dccd?
so i need to wire 6 wires from the dccd controller up to the combination meter, each of these correspond to the dccd lock %. Im using a sti jdm ver6 cluster and plugged ti right into my stock 99 RS cluster harness. How do i do this? Do i tap into certain wires? Or do i need a wiring harness fromm the jdm ver6 so i can have thsoe extra pins on the harness? Which pins on the jdm cluster are for the dccd? Can anyone point me in the right direction
ImprezaRSfan! is offline   Reply With Quote
Old 03-03-2006, 12:27 PM   #2
jnorth85
Member#: 76785
2000 700Whp The RSTI
SRP
did you ever get an answer for this? i am also looking!
jnorth85 is offline   Reply With Quote
Old 03-03-2006, 12:38 PM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
You need the v5/6 harness.
jamesfacts is offline   Reply With Quote
Old 03-03-2006, 03:10 PM   #4
jnorth85
Member#: 76785
SRP
why does the stock one not work when it plugs in to the cluster?
Old 03-03-2006, 06:18 PM   #5
o2sys
Member#: 43842
200? WRX STI
if this can be applied to V8 clusters as well i would like to know...
o2sys is offline   Reply With Quote
Old 03-04-2006, 10:12 AM   #6
jamesfacts
Member#: 51282
98 RS
Because a USDM cluster doesn't have all the extra DCCD pins.
Old 03-04-2006, 12:15 PM   #7
jnorth85
Member#: 76785
SRP
where are the version 6 harness avalable?
Old 03-05-2006, 08:12 PM   #8
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
hm, old thread but anyways - if anyone still needs V5-6 cluster dccd pinouts, let me know, I had those somewhere
Hyper is offline   Reply With Quote
Old 03-05-2006, 11:05 PM   #9
jnorth85
Member#: 76785
SRP
id be happy to have them.
Old 03-06-2006, 12:14 AM   #10
o2sys
Member#: 43842
200? WRX STI
hey hyper will this work for V8 cluster as well?
Old 03-06-2006, 12:28 AM   #11
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
nope, I think they are different
ok, so V5-6 clusters
you need to connect this to the 16 pin connector (the middle one)
here are the pins you are using:
b1, b2, b3, b4, b9, b10, b11,
each is for according DCCD indicator on the cluster; if I recall b11 is for the LOCK setting (because I screwed that wire ) so b1 = unlocked, b2 = little lock, b3 more lock and so on
just plug and see, thing works like a christmas tree
Many thanks to Dave @ Rallispec for this info
Old 03-06-2006, 12:39 AM   #12
jnorth85
Member#: 76785
SRP
awesome thanks for the info!!!!
Old 01-11-2019, 08:05 AM   #13
bredzy
Member#: 358182
2001 20K Impreza
Does anyone have a Pinout diagram for a JDM SUBARU WRX GDA GGA VERSION 9 GAUGE CLUSTER 180KM/H ?
bredzy is offline   Reply With Quote
interior questions and prodrive gc8 ver5/6 cluster Mr. Simplisto Interior & Exterior Modification 2 03-02-2010 08:02 AM
JDM STi v5/6 cluster bsmitty Interior/Dressup/Audio & Security 9 05-03-2008 05:31 PM
JDM STI ver5 & 6 wagon rear wing. Kosmic Interior & Exterior Modification 6 04-19-2007 01:39 PM
WTT: JDM STi version 6 steering wheel for momo champion Lachlan Interior/Dressup/Audio & Security 0 08-09-2006 08:27 PM
Cluster pinouts for JDM Ver3 or MY97 impreza FederalAuditor Electrical & Lighting 0 04-16-2005 04:23 PM
