Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 01-16-2019, 09:51 PM   #1
cameden
Member#: 496577
Default Jiffy Lube overfilled my Impreza with oil....and now....please help!
Newb here, so if I'm in the wrong place can someone please redirect me to the correct place. Anywhoo heres my story
Took my 2006, automatic, subaru impreza with ~170k to Jiffy Lube for a high milage signature service. Everything was running just fine prior to drop off. Service was done and when i went to drive it away is the trouble began. My car would rev up super high then kick into gear, get very little power and was acting very erratically. I made it to the walmart less than a quarter mile down the road. I restarted it and noticed a ton of white smoke, barely made it back to the Jiffy Lube, very high rpms with no power then suddenly kicking into gear, all sorts of messed up stuff it wasn't doing before. Upon returning they checked the oil and there was way to much in it....like double on the dipstick. They drained it, and refilled it. Bottom line is it still is acting very strange, not nearly as bad as initially but it seams to be having some serious transmission issues. It appears its only on initial start up from a stop, as in the higher gears at higher speeds it seams to be ok. it has stalled a few times while coming to a stop, something it never did ever before. Would serious overfilling cause any of these issues or is this some crazy coincidence?
Any help is greatly appreciated as i am at a loss for words as to what could have all the sudden made my near perfect running car all the sudden faacked.
Thank you all so much and i look forward to talking through this with y'all...
cameden is offline   Reply With Quote
Old 01-16-2019, 09:59 PM   #2
Jack
Add Lightness
Member#: 13699
not my president
(From General)
They drained the transmission fluid, then filled the already filled crank case with 5 quarts of oil.
Get your transmission back up. Should have drained about 5 quarts, the way Jiffy Lube does it.
They have bought Subaru owners hundreds of transmissions because of the wonderful high school, never trained to be a mechanic morons. This is the reason that on manual transmissions, Subaru uses a T-70 Torx bolt. It's because morons don't own a T-70 torx wrench and they can't count that high anyways. It's an easy removal on an automatic with no silly T-70. They don't tend to be quite as motivated to figure out how to screw up looking and finding the trans drain bolt on an auto. But obviously, your moron found it.
Why the hell does anyone go to Jiffy Lube ever?
Oh....you should check if your trans drain bolt is now plastic. They always strip the bolt.
Old 01-17-2019, 01:17 AM   #3
subarumod
Member#: 468745
06 wrx
black as your girls soul.
I think its time to start watching a lot of youtube on how to do these things yourself. youll save money And feel good about yourself.. I cannot handle when they try to upsell you on stuff.. "we have this super special oil scent adder for only 29.99 more" For god sake just give me the oil and the filter and lets move on...
jiffy, midas, random shops make me sick to my stomach. Like, how in gods sake do you drive in for an $250 oil change and leave with a destroyed car.. Its not rocket science.
Whats messed up. Is now you really have to get under there. Or take it to a reputable place, so you can get evidence that they F'd your car.. Hope its a simple fix..
subarumod is offline   Reply With Quote
Old 01-17-2019, 06:18 AM   #4
rtv900
Member#: 428511
2016 STI
You didn't really clarify if you had them do a trans change or a motor oil change?
Now I'm guessing trans but they didn't put any fluid back in?
If that's the case you'll have to make sure that is documented as running it with almost no fluid for a bit of time is pretty bad as you know.
sucks dude
rtv900 is offline   Reply With Quote
Old 01-17-2019, 10:55 AM   #5
FaastLegacy
Member#: 11671
To be fair, you're not going to find certified mechanics changing oil anywhere unless you're talking about super high end cars and $20k oil changes.
FaastLegacy is offline   Reply With Quote
Old 01-17-2019, 11:05 AM   #6
ssbonline
Member#: 58705
2005 wrx - 5 speed
Silver/Premium package
Please don't take any cars to jiffylube.
ssbonline is offline   Reply With Quote
Old 01-17-2019, 12:20 PM   #7
SirBrass
Member#: 207263
2019 WRX Limited
My BRZ's transmission drain and fill bolts required a 10mm hex wrench or bolt. IIRC, rear diff was the same. Very easy to do. But it's always the 10mm everyone is missing .
SirBrass is online now   Reply With Quote
Old 01-17-2019, 02:29 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Totally assuming a typo....even ANY high end car, I can't see a $20K/$20,000 oil change......
But, yes.......I have an issue with some local shops just removing/replacing a wheel.....
Doing, fluids.....sheesh.......
Since I am usually in my driveway, I pick days and inform customers on work.
It's 20*F and snowing, I can do it, but no price break (working in driveway), call me when 50*F and not raining, I am more flexible.
Yep, I stay away from most "quickie places"......
Old 01-17-2019, 02:41 PM   #9
FaastLegacy
Member#: 11671
The Veyron supposedly has a $20k oil change. At most places, including reputable shops and dealerships, they've got a lube tech doing oil changes for $9/hr.
Old 01-17-2019, 02:56 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Subaru forum....WTF are you tying in a Veyron?!?!
Sheesh......
Crap, for that oil change, most of us are buying a new car......
GTFO with that comment......
Old 01-17-2019, 02:58 PM   #11
rtv900
Member#: 428511
2016 STI
yeah I did hear there was a Lambo out there that costs around that much.
the dry sump system requires oil be removed from a half a dozen places, all completely encapsulated in underbody structural parts and aero coverings.
Basically nightmare disassembly just to get oil out.
Old 01-17-2019, 03:00 PM   #12
rtv900
Member#: 428511
2016 STI
I think his point was nobody should be assuming Jiffy lube guys are skilled in any way, as apposed to guys who work on ultra high end cars on the other hand where even a guy doing oil changes is high skill
Old 01-17-2019, 03:02 PM   #13
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
^This. Never go to Jiffy Lube. The last time I went there they left my oil cap lying on top of the motor and it got jammed in the drive belt, throwing the belt off the pulleys and spitting oil all over my engine bay.
Turpid Porpoise is offline   Reply With Quote
Old 01-17-2019, 03:20 PM   #14
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Well.....maybe........
Frankly, I don't think any of us care about high end cars.
Yes, I know some peeps that work at "quick lube" places.....some of them I would not trust bringing my mail from the street to the front door, let alone working on a sorta major investment of mine....
Whatever......hopefully not a major issue to the OP, hope it works out well.....
Old 01-17-2019, 03:34 PM   #15
Jack
Add Lightness
Member#: 13699
not my president
(From General)
For those of us who waste our lives watching youtube videos, the comment about $20k oil changes probably centered around Houston's DIY job he did on his rental company Bugati. It has 16 drain plugs for the dry sump oiling system and of course, you need to take stuff apart to get to them. Yah....$21k at a dealer.
That's not so bad. A McLaren F1 factory tire change involves flying over a team from England and renting a racetrack to properly balance the tires. No, I'm not making that up.
Old 01-17-2019, 04:53 PM   #16
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Bugatti Veyron $21K Oil Change ?.. Ehhh, I'll do it Myself ! - YouTube
Yep, I have read/seen that for a McLaren tire change....but.....Frikkin Subaru forum......dump this crap into OT or other models.....how many here can even pay for Veyron or McLaren insurance, let alone service....... way OT.....
As to quick lube places....yes, cheap.......issues?.....yep, maybe. As stated before, most employees I would be questioning having them walk 60' from mailbox to front door and get it right. Doing service on an expensive part of my life.........nope........
OP, hope you get this sorted out correctly based on your info and issue.
Old 01-17-2019, 06:34 PM   #17
Brego
Member#: 496617
what kind of damage does an overfilled oil cause, and how quickly does it occur?
Brego is offline   Reply With Quote
Old 01-17-2019, 07:04 PM   #18
anarekist
Member#: 468117
2017 WRX
DMG
apparently 1 mile to the walmart.
anarekist is online now   Reply With Quote
Old 01-18-2019, 06:21 AM   #19
rtv900
Member#: 428511
2016 STI
well the OP never clarified what even really happened, but we are all assuming he went for an oil change, but somebody drained the trans and then filled the engine back up even though it was never drained to begin with.
So he left with a half drained trans and a double filled engine.
the engine oil over fill isn't the major issue, it's the trans with no oil.
That's why it would rev super high before slamming into gear. It had no oil to pressurize it's valving.
Old 01-18-2019, 07:57 AM   #20
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
It can blow out seals, push liquid into the PCV system, likely a mess as well.
I agree with this. Hopefully the trans is OK and he gets documentation that this is what happened.
I know some peeps that have put a label next to trans drain and oil drain so others know which is which.
Old 01-20-2019, 12:05 PM   #21
branut89
Member#: 222413
I find the best way to make sure this never become an issue is doing the maintenance on my own.
branut89 is offline   Reply With Quote
Old 01-23-2019, 02:36 PM   #22
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Ain't just quicky oil change places. The Subaru Express guys at the dealer I work for do that at least once a month...
They have left so many drain plugs loose there is a 3" wide black streak from the Express bays down the lot and around the building to the service parking lot.
Elbert Bass is offline   Reply With Quote
Old 01-23-2019, 05:05 PM   #23
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
..... let alone working on a sorta major investment of mine....
ha haaa... you called a car an "investment"
bdubblu is online now   Reply With Quote
Old 03-04-2019, 09:05 PM   #24
Travistee
Member#: 220101
2009 outback sport
I accidentally overfilled my impreza more than 1/2 quart over. It lost power, but I only drove it a few miles to figure out the problem it had, then got an oil change. I only drove a few miles but I don't think it's back to normal yet. I think it should take about 25 miles for the ECU to adjust back to normal.
After the oil change I don't think it's back to normal but it's not too bad. I'm hearing some valve ticking but I'm not sure if I'm being to sensitive about that or if it was like that before. I think the ECU will fix itself in normal driving.
I will add some Lucas Oil Stabilizer that should quiet the valves.
If anyone thinks it could have damaged the valves let me know.
( I don't mean to hijack the thread)
I went to a jiffy lube. I asked if they could check anything while doing an oil change . They told me they are not mechanics. I don't see why anyone goes there.
Travistee is offline   Reply With Quote
Old 03-04-2019, 09:45 PM   #25
dpady
Member#: 498617
I agree on this one. They most definitely accidentally drained the transmission fluid and put double the oil in. Take it make to them and demand them to fix it. Being that jiffy lube is a chain if they refuse take it straight to head office and it'll get taken care of lickity split.
dpady is offline   Reply With Quote
