Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 01-20-2019, 09:38 PM   #1
cardude007617
Member#: 216556
2017 Impreza Limited
Default Stock stereo ground loop whine
Our 2017 Impreza Limited seems to have ground loop whine coming through the front passenger side door speaker. Any ideas what might make this happen with all stock stereo components?
cardude007617 is offline   Reply With Quote
Old 01-20-2019, 09:49 PM   #2
Blktrax
Member#: 220971
2002 WRX 223K Mi.
Take it in and have it fixed, it's 99% the H/K Amp under the seat. There is a revised part# amp and you're probably 4 versions behind on the radio firmware. Both are covered under 3/36
Blktrax is offline   Reply With Quote
Old 01-20-2019, 10:00 PM   #3
cardude007617
Member#: 216556
Is this something that a dealer will be aware of? Itís been in three times for this already and they havenít been able to resolve it. 3/36 still luckily applies
Old 01-20-2019, 10:08 PM   #4
Blktrax
Member#: 220971
2002 WRX 223K Mi.
APPLICABILITY: 2018MY Legacy and Outback
2018MY Crosstrek
2017 and 2018MY Impreza
SUBJECT: Harman Kardon Gen 3 Audio Amplifier
Operational Concerns
NUMBER: 15-217-18
DATE: 02/19/18
This bulletin announces availability of new audio system amplifiers to address the following
operating concerns with the Harman Kardon Gen 3 infotainment system:
Symptom 1: No audio output is heard but, the volume level displayed changes when turning the
knob
Symptom 2: Audio volume increases to maximum intermittently without turning the knob
Symptom 3: A buzzing, screeching or crackling-type sound is heard coming through the speakers
NOTE: All exchange amplifiers have the new software and circuitry installed
Old 01-20-2019, 10:10 PM   #5
Blktrax
Member#: 220971
2002 WRX 223K Mi.
Also tell them your radio keeps loosing its presets, and you read there is a software update.
The update should take you to version 18.43.20 if they do it correctly.
Old 01-20-2019, 10:28 PM   #6
cardude007617
Member#: 216556
Was the HK an upgrade in 17? Our door cards by the speakers donít say HK on them. We do have the larger Apple car play stereo that came with the limited. Just want to make sure itís not a case like the wrx where it was an upgrade.
Old 01-20-2019, 11:28 PM   #7
Blktrax
Member#: 220971
2002 WRX 223K Mi.
It was an upgrade option. Check your window sticker if you still have it.
Package #35 Eyesight, Blind Spot Detection, Rear Cross Traffic Alert, Moonroof (tilt/slide with sunshade), Navigation, Harman/Kardon 432w equiv amp and 8 speakers
MSRP $3845
It's either an external amp or the internal amp in the head unit is bad.
Old 01-22-2019, 10:12 AM   #8
SirBrass
Member#: 207263
2019 WRX Limited
Unless WRX is a 2019, you don't have apple carplay with the stock unit. And for those, Android Auto/Apple Carplay is standard on all trims, all options.
And if you have the HK system, your door speakers will have the Harmon Kardon tag. If you don't see it, you don't have it.
SirBrass is offline   Reply With Quote
Old 01-22-2019, 12:10 PM   #9
Blktrax
Member#: 220971
2002 WRX 223K Mi.
I believe weíre talking about a 17í Impreza, not a WRX
Old 01-22-2019, 12:11 PM   #10
SirBrass
Member#: 207263
2019 WRX Limited
Wasn't sure. Poster didn't specify and his profile only lists the 16 WRX.
Old 01-24-2019, 02:21 PM   #11
cardude007617
Member#: 216556
Correct, itís a 17 Impreza Limited. Not the WRX in my profile.
Old 02-18-2019, 12:46 PM   #12
cardude007617
Member#: 216556
Hi-
Where is the amplifier? is it under the carpet beneath the seat? I looked this weekend and didn't see/feel anything...
Old 02-18-2019, 01:24 PM   #13
Blktrax
Member#: 220971
2002 WRX 223K Mi.
Under the front part of the passenger seat if there is one.
Old 02-18-2019, 01:56 PM   #14
cardude007617
Member#: 216556
Unless there is carpet over it, it wasnt there.
The TSB is still valid if I don't have the stand alone amp right?
The car has been in 2 more times since I started this thread and they are telling me its a cvt pump noise and it's normal. This is completely wrong.
This weekend it was making the noise and I pulled the fuse for the radio and the noise stopped immediately. It's the radio (or the alternator's current is dirty).
Any advise to get this fixed?
Old 02-18-2019, 05:42 PM   #15
Blktrax
Member#: 220971
2002 WRX 223K Mi.
Its the internal amp then , basically you're going to have to show them exactly what you did; pull the fuse and the noise quits.
Also be aware there is an internal Fan in the head unit.
Old 02-20-2019, 07:54 AM   #16
Onyanineza
Member#: 495426
In your backsits?
Onyanineza is offline   Reply With Quote
Old 02-23-2019, 12:09 AM   #17
cardude007617
Member#: 216556
Update:
So since we pulled the radio fuse a few times messing around with things...now the noise has stopped for a few days. What the heck?
