Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 01-22-2019, 05:25 PM   #2076
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
So has anyone snagged a pair of the wisefab uprights yet? Any feedback on them?
Old 01-23-2019, 03:50 PM   #2077
*Ulimited*
Member#: 139249
I have the rears, so far my only gripe is that the recess for the clip to hold the bearing in was just ever so slightly too low in the cup. With the bearing fully pressed in the bearing sleeve is just a hair too tall for the groove. The clip would not expand outward into the groove with the bearing in place, I had to sand the clip down slightly for it to fit into place and expand. Other than that the caliper is in a slightly different position but I don't see any reason that should be an issue yet.
It's going to be a little while before I get my struts back from the rebuild before I can bolt it all back together.
*Ulimited* is offline   Reply With Quote
Old 01-23-2019, 04:37 PM   #2078
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
How was the e brake fix?
WRX8XB is offline   Reply With Quote
Old 01-23-2019, 05:50 PM   #2079
*Ulimited*
Member#: 139249
Fairly easy work with a grinder. Putting the springs and pins back together in the right order is probably harder.
Old 01-23-2019, 06:36 PM   #2080
WRX8XB
Member#: 45323
Hmm that makes them very tempting. Hmm.
Old 02-07-2019, 03:35 PM   #2081
*Ulimited*
Member#: 139249
Anyone ever make their own solid bushings? I'd like a solid aluminum outrigger bushing not just an insert. I know whiteline makes a poly version but i'd like it to be solid.
http://www.whiteline.com.au/product_..._number=W91379
Thinking about modifying whitelines design a bit.
Old 02-07-2019, 03:40 PM   #2082
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Yes. If you have a lathe or access to a lathe it's easy. Alluminati I think has some solid aluminum bushings too if you're looking to buy.
Mine aren't aluminum but they are solid. You could easily do 6061 and just drill the hole in the center for the bolt.
Old 02-07-2019, 04:08 PM   #2083
*Ulimited*
Member#: 139249
I haven't seen a company that has this particular bushing for sale. Looks like no for Alluminati, I actually just did a full set of their stuff.
Old 02-07-2019, 04:55 PM   #2084
subydude
Member#: 80649
Then yeah, buy a round of aluminum and find someone with a lathe you can borrow.
Mine are made from 1018 since I needed the ballast.
Old 02-08-2019, 01:19 AM   #2085
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I just welded some plate on the top and bottom of the outriggers to make them solid. Easier than using a lathe- although I love subydude's "Ballast".
Old 02-08-2019, 08:21 AM   #2086
WRX8XB
Member#: 45323
I wish I needed ballast. Lol. So much work to do.
Old 02-18-2019, 12:17 PM   #2087
*Ulimited*
Member#: 139249
What do you guys think? V2 will have the part that presses into the sleeve be the exact height of the sleeve so that it can be pressed in more easily.
Old 02-18-2019, 12:19 PM   #2088
subydude
Member#: 80649
Looks good. I'd drill and tap a small hole for a set screw after pressing it in assuming you're making it out of AL. I tack welded mine since they were steel. Just extra peace of mind really and probably not super critical.
Old 02-18-2019, 12:25 PM   #2089
*Ulimited*
Member#: 139249
I was thinking something like this, I almost was thinking of making them two pieces with a lip on the bottom similar to the top so that they would sandwich into place. A set screw would do the same thing I suppose.
Old 02-23-2019, 09:24 AM   #2090
smoky
Member#: 221439
2004 STI
I have these that locks the t-bar, they are made of aluminium and fit on top of the stock bushing. Not using them, if interested PM me
smoky is offline   Reply With Quote
Old 02-28-2019, 12:49 PM   #2091
*Ulimited*
Member#: 139249
The lite speed outrigger lockdown set, I maybe would have tried these if they were still able to be ordered easily but at this point i'm already down the path of making a full solid replacement. Luke from full spectrum is making me a set based on my design, thanks though!
Old 03-13-2019, 07:53 PM   #2092
unit114643
Member#: 499025
2013 WRX STI
Default Need help with next tire choice.
I have a question regarding my next set of tires. I have recently been attending my local autocross events and I am really enjoying it. I've been wondering if I should be running a more sticky tire with my current setup.
I drive a 2013 Subaru STI. Stage 2- Cobb intake, downpipe, invidia q300 exhaust. I also have an accessport with a dyncomp tune (moderate tune for Arizona heat)
I've got K-sport coilovers with whiteline 22Front/24Rear swaybars.
I've got G2 Nitto's NT555 Tires 245/40/18 with -2.5 front end camber.
They currently have me running in "SM" autocross class. Any general recommendation on tires/setup would be appreciated. Thanks in advance for reading my post!
unit114643 is offline   Reply With Quote
Old 03-14-2019, 08:14 AM   #2093
yellowblur
Member#: 485903
2018 WRX w/PP
If those are your only mods, the more appropriate class (as of 2018) would be STU. Then you will be going against cars prepped much closer to yours. Simply going with a set of 200 tread wear tires offered by Bridgestone, Nexen, Hankook, or BFG will shave 1.5 to 2 seconds off a 60 second course compared to the tires you have now. That is, of course, if the driver can drive the car that fast. Seat time, seat time, seat time...
yellowblur is offline   Reply With Quote
Old 03-14-2019, 10:38 AM   #2094
quiksilver_dragon
Member#: 246479
2005 Impreza WRX STi
I think it depends on if the downpipe is catless or catted. I believe if it is catted he can run in STU. But if it's catless it jumps you to SM. Depending on the wheel specs as well.
quiksilver_dragon is offline   Reply With Quote
Old 03-14-2019, 11:01 AM   #2095
subydude
Member#: 80649
Actually, he's in SP if catless, not SM. SP and SM both don't care about wheel size.
And yes, get a good set of RE71R or Rival S 1.5 tires and drive on those for a year or two. If you decide you want to get more competitive then choose some more mods.
A quality AOS wouldn't hurt now and in the future though and make sure to check the oil before and after each event.
Old 03-14-2019, 12:41 PM   #2096
quiksilver_dragon
Member#: 246479
I always forget about the prepared classes. Lol.
But catless isn't allowed in STU. Learned that one the hard way.
Old 03-14-2019, 02:36 PM   #2097
subydude
Member#: 80649
That's correct. I haven't double checked, but I think the open boost rule went through in STU? I don't pay as much attention to ST as SM. If so STU is normal pump 93 tunes with a catted down pipe assuming no other mods to his setup. If it's catless then ASP. If he's got some extra stuff he's not saying like back seat removal, built engine, etc then SM.
But I still go back to the whole "run for a year with good tires, add a good AOS, and maybe get more camber" then decide if you want to mod it for autox or not.
Old 03-15-2019, 10:20 AM   #2098
Thorium06
Member#: 254372
Open boost tunes did go through for STU, but you still have to have stock hardware/solenoids. Fuel is limited to 95.9 octane, so make sure you measure ahead of time. STU does require a cat, but there are specifics about placement and cell count, and I think they just revised that one as well.
Thorium06 is offline   Reply With Quote
Old 03-15-2019, 11:14 PM   #2099
Homemade WRX
Member#: 33782
96 in the garage
Do they seriously have equipment to test it?!!
Old 03-16-2019, 11:01 AM   #2100
Thorium06
Member#: 254372
More than likely no. I had a protest written for the first day of nationals for that purpose, but with how that day ended up being I didnít want to stick around the site any longer.
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
