Welcome to the North American Subaru Impreza Owners Club Monday September 28, 2020
Old 02-02-2019, 12:10 PM   #101
Innkeepr
Member#: 471069
04 WRX
WR Blue
Originally Posted by subaru_gc8 View Post
for the coils did you use oem or did you buy some aftermarket ones
I used aftermarket OE replacements - Aceon 7805-9551.
They are made in the USA - have used them before with no issues.
Innkeepr is offline   Reply With Quote
Old 02-02-2019, 12:19 PM   #102
subaru_gc8
Member#: 29292
2004 WRX wagon
im kinda doubting that they are made in america..... but honestly Ihad a coil issue and it sounds judt like what you are descibing. no CEL or anything but it sputtered like when I tried to step on the gas and actually boost. went through that for about a year til I got tired of it and changed all the coils with OEM nthen it went away
Old 02-03-2019, 11:06 AM   #103
Innkeepr
Member#: 471069
04 WRX
WR Blue
LOL - I have to agree with you there. Just went and checked the boxes - surprise surprise...made in china.
How the *** do these companies get away with this BS is beyond me. Perhaps the box was made in the US ? -
After dropping 2K on the turbo and TMIC, I went cheap on coils - my bad, I should have known better. When they fail - they will be replaced with the OEM ones.
Old 02-13-2019, 06:41 PM   #104
cosworth89
Member#: 497748
Default Help lol
Good evening. Sorry to bring this back to life but.. I have a 1995 impreza WRX which is a Japanese import, it had a hks FCD fitted which caused loads of issues so I removed it and it's running much better than it was (was fuel cutting at 0.5 bar!) It also has a electronic boost controller fitted which I have figured is nackered so have removed it and just looped the actuator and turbo direct so it boosts at between 0.6 and has spiked at 1.1Bar in 4th/5th gear where the ecu cuts the fuel and u end up head butting the windscreen!.... the car idles lovely has only done around 100k it has a FMIC and a straight through turbo back exhaust... the issue I'm getting recently is there is what looks to be a red light that looks like an exhaust cat that comes on the dash after hard acceleration in 4th/5th gear where it tends to splutter a little bit and has a loss of power... I have no idea what the light is or what it means, there is an aftermarket lambda sensor in the down pipe from the turbo as it has just been made to fit the original loom.... could this cheap lambda sensor be the issue? It only starts running crappy when it's warm and in 5th gear in wot and the red light comes on.... sorry for the long description but I've been scratching my head for days over this issue it's driving me mad
Cheers guys!
cosworth89 is offline   Reply With Quote
Old 02-14-2019, 04:56 PM   #105
03jdmlegacy
Member#: 497001
My car was stuttering around 2500rom or any time you stepped on the throttle hard. I thought I cleaned the maf. But apparently you can take it apart and clean inside it. Not just the test drop. This fixed the issue
03jdmlegacy is offline   Reply With Quote
Old 02-16-2019, 10:14 AM   #106
cosworth89
Member#: 497748
I've spoke to a Subaru tuning specialist here in the uk, he said that it's more than likely down to the car running the standard ecu with upgraded intercooler, straight through exhaust and cone air filter has upset the ecu and the fueling etc which is causing it to run like crap it's trying to accommodate for all the upgrades and it just can't so next thing to do is get the remap I guess! Also my wastegate actuator isn't cutting boost when it is suppose to. How do i know of its on the standard setting as I fear it has been messed about with.
Tia.
Old 11-05-2019, 12:20 PM   #107
subasubarubaru
Member#: 429708
2003 WRX Wagon
Did any of you solve this issue? I can't get past 10psi boost. No leaks; double sure. Starts bucking at WOT and won't reach target boost. Changed back to oem bcs and got 15psi then it reverted right back to same bucking, shuddering problem.
subasubarubaru is offline   Reply With Quote
Old 11-05-2019, 08:39 PM   #108
sig
Member#: 318247
This just happened to me. My coils went bad right at the start of the cold weather and I replaced them with new plugs and problem solved. I was having bucking at WOT as well as a flashing CEL at one point, the car ran fine otherwise. I would start there.
sig is offline   Reply With Quote
Old 11-05-2019, 11:10 PM   #109
Innkeepr
Member#: 471069
04 WRX
WR Blue
Solved mine - 1. I had a new MAF installed that was bad right out of the box ! yes it was an aftermarket and not OEM.
2. random misfire was a coil. replaced all 4 with known good used ones, never another issue.
Old 11-08-2019, 06:35 PM   #110
subasubarubaru
Member#: 429708
2003 WRX Wagon
sig and Innkeepr thanks for the replies! I have a set of coil packs and spark plugs somewhere. I'll try that.
UPDATE: YES! Yes... that was it for me. Thanks again guys. Replacing the coils and plugs cleared all issues including not reaching target boost, bucking at WOT, and occasionally stuttering. Aside from that the car ran perfect. That is why I waited so long to check the coils and plugs. Also, I never had ANY check engine lights or misfires codes. So glad to have my 'car' back!
Old 12-05-2019, 07:45 PM   #111
boxer4rsti
Member#: 115444
04 Forester XT
Default 100% wastegate flutter
Originally Posted by m0nkey View Post
Here is a video of what i am talking about. Does this sound like wastegate flutter?
Heres a video from 1st to 2nd
WP_20120511_045810Z.mp4 video by itsmedavid - Photobucket
heres a video of a 3rd gear pull
WP_20120511_050032Z.mp4 video by itsmedavid - Photobucket
My previous 04XT boosting 17.8 on the stock td04 and it would go crazy like that when boosting hard. Was worried at first and took it to my tuner and he explained that especially with smaller turbos being worked hard the waste gate has to work like crazy to not over spin your turbo..made me smile hearing that sound lol learn to love that sound!
boxer4rsti is offline   Reply With Quote
wrx sputtering, but only when it's wet outside? 1WRX0003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 11-10-2018 07:17 PM
hesitation when tapping gas, no boost reading on ap after inlet install drewvdw Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 08-05-2011 10:43 PM
hesitating when full boost g-unit555 Legacy Forum 3 08-10-2008 01:44 AM
Stumbles/Hesitates when under any kind of boost. NITROS UTEC 3 08-16-2007 10:52 AM
Hesitation when car hits full boost (sometimes) JDM_Scobaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-14-2005 11:35 AM
