Welcome to the North American Subaru Impreza Owners Club Sunday April 21, 2019
Old 03-22-2019, 10:56 PM   #7976
paulsen93
Member#: 395402
2015 WRX CVT Prem.
Dark Gray Metallic
A few more angles . . .
paulsen93 is offline   Reply With Quote
Old 03-22-2019, 11:20 PM   #7977
96JZA
Member#: 463078
2018 WRX Limited
Crystal White Pearl
I feel like I'm the only person of any car running this color on the 57DRs and finally posting on this thread after having the wheels on for almost 5 months.
18x9.5 +38 Eternal Blue Pearl Grams 57DRs with 255/35/18 Michelin Super Sports and HKS Hipermax IV-SP coils with Cusco rear LCAs.
96JZA is offline   Reply With Quote
Old 03-22-2019, 11:28 PM   #7978
Sean2213
Member#: 469103
2018 Subaru WRX STI
Crystal White Pearl
Noob question here...
Planning to buy 18x10 +39 offset on some 265/35/18 Michelin sport 4s. I have an Ď18 STI, will this set up clear the brembos and have no rubbing issues? Or 18x9.5 +38 is better? I will running on stock height for now and will be lowering in the future.
Sean2213 is offline   Reply With Quote
Old 03-22-2019, 11:47 PM   #7979
fullah
Member#: 233053
Not my car but came across this on the interwebs. These are listed as 18x10.5 +22 with a 275/35/18 tire. Not sure if anyone has any info on these wheels but they're the Circuit Performance CP32 in black. I think they look pretty good for being sub $100 each wheels and 23 lbs which is the same as the Avid Av20.
Originally Posted by fullah View Post
Came across these wheels on nlmotoring.com in a 18x9 +35. They are around 23 lbs each which isn't terrible. They are about the same weight as the Avid Av20 wheels a lot of guys run.
Sometimes they are about $60-$100 per wheel when NLmotoring runs clearance deals on them.
So far only came across these two pics on a 2015+ body. Anyone know if the owner of this car is on the forums? Looking for more pics if they're out there. I kinda like the look in black.
fullah is offline   Reply With Quote
Old 03-24-2019, 11:14 PM   #7980
alozcarney
Member#: 477167
Any one have a 18x8.5 +35 or 18x9 +35 set up? Looking at some TE37's and I'm not looking for flush, but just inside the fender well.
alozcarney is offline   Reply With Quote
Old 03-25-2019, 11:05 AM   #7981
kaeknows
Member#: 357191
2016 WRX
ISM
before anyone ask for "specs?!" its in the previous page
kaeknows is offline   Reply With Quote
Old 03-25-2019, 11:33 AM   #7982
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Pretty extreme for somebody who isn't claiming any recent autocross or track day activity . . .
Norm
Old 03-25-2019, 11:54 AM   #7983
kaeknows
Member#: 357191
2016 WRX
ISM
i wasnt aware i need to autox or track my car to run those specific alignment
kevin
Old 03-25-2019, 12:25 PM   #7984
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
kevin
Why would you choose to live with the downsides of an alignment that's out there near the ragged edge of what even the extreme people in either of those activities use, and then only drive it on the streets?
Norm
Old 03-25-2019, 12:31 PM   #7985
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Just so you know, I've up-sized the tires on some of my cars by 40 or even 50mm, with wheel widths upped by 2.5" and even 3", without needing to go full-race with the alignment just to make them fit.
Norm
Old 03-25-2019, 12:52 PM   #7986
kaeknows
Member#: 357191
2016 WRX
ISM
Norm
Norm
i didnt know -3.5/-3 was the most extreme i can run on my street car, thank you for the heads up /s. Just so you know I've also ran 245/40 on the same wheels w/o spacers on -2.5 and -1.5 alignment without touching the fenders, i can also dial in my camber to -3 and -2 with this current setup, which I'll be doing when I rotate my tires. I got bored with the old setup and played around with the spacers, not everyone wants to stick with the same look, 10k miles on those tires with not much tread wear on near the ragged edge alignment
no spacers, untouched fenders, -2.5/-1.5 alignment, tell me if those alignments are "full-race"
kevin
Old 03-25-2019, 01:03 PM   #7987
Stoleyourboard
Member#: 483007
Default 2015 WRX/STi Aftermarket wheel and tire fitment
Norm
You sound like a retard Norm
Stoleyourboard is offline   Reply With Quote
Old 03-25-2019, 01:12 PM   #7988
Stoleyourboard
Member#: 483007
Originally Posted by anarekist View Post
anyone rocking 18x10.5 +22, what did it take to fit them? is rolling fenders enough?
nevermind that's dumb.
how about 18x9.5 +22?
9.5 +22 235/40/18
To achieve this Iíve had to roll and pull the fenders and shave the rear bumper tabs. Im currently on 14k Bc Racing Extreme Low coilovers , Cusco LCAís, Racer X ruca, and Racer X toe arms. My current alignment is -3.7R and -4F. This setup is definitely very achievable with little modifications if you donít go as low as I did. I am currently in the process of raising the car up and running a 255/35 tire. But according to Norm my alignment is only meant for race cars.
Old 03-25-2019, 02:42 PM   #7989
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Camber plates, right?
kevin
Sounds about what I'd try for a true dual-purpose DD/autocross or DD/track car running on max performance summer tires (MPSS, PS4S, or comparable). Test, and go from there. "Dual purpose" could still be 95+% street . . .
Norm
Old 03-25-2019, 02:47 PM   #7990
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Ah, yes. "Retard" is your new go-to word when you've got nothing constructive to add.
Shutup Retard
Norm
Old 03-25-2019, 03:15 PM   #7991
kaeknows
Member#: 357191
2016 WRX
ISM
Norm
yup, ohlins camber plates maxes out to -4.5 from my understanding. I ran my re11r til they were bald with (-2.5/-1.5), now currently on ad08r and I havent noticed any excessive wear on the tires with my current alignment. I do have agree that my rears are a little too much for a daily street car, will be getting that rear to -2 or less, just in time for canyon drives this summer
Old 03-26-2019, 08:41 AM   #7992
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
... Im currently on 14k Bc Racing Extreme Low coilovers , <snip> But according to Norm my alignment is only meant for race cars.
As long as cornering roll is under even a semblance of control - and with 14 kg/mm springs I can't see where it wouldn't be - you're never going to use all of the contact patch that's there unless you're actually running at race pace enough of the time to need that much. And hard street driving rarely gets above 2/3 of race pace in terms of cornering g's.
That old saying "some's good, more's better, and too much is just enough" has apparently has found new applicability.
Norm
Old 03-27-2019, 02:37 PM   #7993
Stoleyourboard
Member#: 483007
Norm
Didnít ask
Old 03-27-2019, 03:04 PM   #7994
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Didnít ask
Seemed like a wide-open invitation to me.
Oh well, maybe somebody else will find the information useful (feel free to take some of the credit for that information getting out there at all).
Norm
Old 03-29-2019, 10:43 AM   #7995
babazu
Member#: 485423
2015 WRX
Originally Posted by Subie_Noob_Brian View Post
18x9.5 +38 wheel
265-35-18 tire
Fortune Auto 500 coils
Rolled rear fenders
*pending alignment*
DSC_0247 by briangabel0, on Flickr
any rubbing of any sort? i am running same setup and looking to get coilovers but was wondering of clearance issues. tia!
babazu is offline   Reply With Quote
Old 03-29-2019, 02:26 PM   #7996
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
^His rears are rolled. Very common setup.
skeeter281 is offline   Reply With Quote
Old 03-29-2019, 02:59 PM   #7997
babazu
Member#: 485423
2015 WRX
maybe i just wont drop it as much?
Old 03-31-2019, 10:58 PM   #7998
Mister_G
Member#: 499784
Anyone have Wedssport SA72R wheels 18x19.5 +38 setup? Any photos?
Mister_G is offline   Reply With Quote
Old 04-01-2019, 10:57 AM   #7999
Kami Speed
Member#: 96479
2006 WRX STI
Obsidian Black Pearl
Here are some! At stock height you should be ok with a 255/35 tire. But if you want to run 265/35 tires you will more than likely have to roll the rear fenders at least. We are a dealer of WedsSports wheels so if interested shoot me a PM and I can get you deal on these
Kami Speed is offline   Reply With Quote
Old 04-01-2019, 03:05 PM   #8000
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
I'm on Swift springs and don't normally rub on 265/35 tires. I would imagine stock height should be even more okay. I've rubbed once, hitting a pretty nasty dip on the freeway going about 70mph, but that's about it.
Obviously YMMV depending on driving style, how much stuff you carry in the rear/trunk, and even the tire itself as some brands/tires are wider than others even within the same size. But at stock or close to stock heights, I don't think 265/35 is as tight of a fit as many people think it to be If you're on coilovers or bags then that's another story altogether.
YungBoba is offline   Reply With Quote
