Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 10-01-2018, 08:51 PM   #551
GK1707
Member#: 373868
2004 STi
Anyone know if the 04 STi BBS comes stock with TPMS?
GK1707 is offline   Reply With Quote
Old 10-02-2018, 12:26 AM   #552
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Sorry can't help but laugh.
They didn't have TPMS in '04... so the answer is NO!
Old 10-02-2018, 08:47 AM   #553
GK1707
Member#: 373868
2004 STi
Are you talking about universally? Bc my 04 Rx8 had tpms...
Old 10-02-2018, 10:32 AM   #554
96accord
Member#: 145105
'15 Accord (Daily)
Why would I be talking universally? This is a Subaru forum.
Old 11-19-2018, 06:49 PM   #555
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Originally Posted by Carrrlos22 View Post
Any ideas?
These are the SF chassis JDM Forester OEM alloys.
GTBGUY is offline   Reply With Quote
Old 11-26-2018, 07:47 PM   #556
cu888
Member#: 470900
Originally Posted by B.C. View Post
elpincherichie - thanks for the new specs! Much appreciated! Not a bad weight.
cu888 - hopefully you got a quicker response elseware, but yes I believe those wheels will fit. As long as the bolt pattern is the exact same, and other specs are close, usually you are good. Also going from +55 to +53, I believe you are moving 2 millimeters away from the brake calipers so no issues there, also moving 2 millimeters is inconsequential with concerns on bearing wear and tear.
Thanks B.C., confirmed that the 2002 Impreza WRX rims fit perfectly on a 2017 Impreza.
cu888 is offline   Reply With Quote
Old 12-10-2018, 05:13 PM   #557
Trigger Tough
Member#: 491335
Anyone have the weight of the Type-RA wheel yet?
Id like to know the same thing. I heard they were forged though
Unfortunately I banged 2 of mine into a curb so Im waiting to get my wheel and tire package to cover it. Once that happens Im thinking of putting some Speedline 2120s on it like the real RA uses because the stock rims are around $1,200 each and Id rather garage them to prevent anymore accidents from happening. lol
Trigger Tough is offline   Reply With Quote
Old 12-10-2018, 06:54 PM   #558
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Wrap them in bubble wrap while they're on the car
Old 01-04-2019, 02:00 PM   #559
sniperkill
Member#: 496023
Default Perhaps some missing or unknown info
Hey guys. This is my first post. Just wanted to throw this info out there cuz I just found out recently.
On the 2018 WRX rims, they will NOT fit over 4 piston brembo STI calipers. I have a 2014 STI and recently got some rims from a friend that came off his 2018 WRX and the front rims would not fit over the calipers. The calipers rubbed the backside of the rims bad. So I had to buy one of those 1/4 spacers and put that on first, then they fit right on there.
sniperkill is offline   Reply With Quote
Old 01-09-2019, 04:39 PM   #560
WhiteRX09
Member#: 321304
2013 WRX
Originally Posted by SnowmanCT View Post
2015+ WRX/STI optional 18" 15 spoke black alloy
18"x8.5" offset +55
OEM part #: B3110VA040
Anyone know how much these weigh? Searched for an hour and the best I found is "reduced weight" vs. stock wheels...
But do they fit over the 18-19 six pots?
WhiteRX09 is offline   Reply With Quote
Old 01-29-2019, 02:59 PM   #561
Mach V Dan
Member#: 12029
I don't know for sure, but probably. So far every OEM wheel that we tried that fits over the FOUR-pot Brembos, also fits over the SIX-pot Brembos.
Dan
Mach V
FastWRX.com
Old 01-29-2019, 08:51 PM   #562
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
Default Weight Rating?
2 questions, Id like to put some STI wheels on my wifes Ascent.
I have the forged BBS from my 15 STI and also thinking of the 18+ 19 STI wheels. Anyone know the weight rating for either? Thanks. I couldnt find any marking on the BBS.
skeeter281 is offline   Reply With Quote
Old 02-22-2019, 06:26 AM   #563
Henriksommer
Member#: 498111
Default Subaru impreza wrx sti v3 option wheels
Can you ad the option wheels for the 1996 v3 sti
BBS 16/7 et 53
Forged and very light (i think its around 13-14kg)
Stock tires 205/50/16
Henriksommer is offline   Reply With Quote
Old 02-23-2019, 09:09 AM   #564
stoney_dukes
Member#: 498143
Thank you for pulling this together.
stoney_dukes is offline   Reply With Quote
Old 02-23-2019, 10:42 PM   #565
Mach V Dan
Member#: 12029
I have to admit, your documentation is excellent. But those are extremely rare, and not something most people will ever encounter. Do you know how many sets were even made? I don't know that I have ever seen another set in the wild.
That sounds like the weight of the whole wheel and tire package; I usually quote the wheel only.
--Dan
Mach V
FastWRX.com
Old 03-09-2019, 11:35 AM   #566
Henriksommer
Member#: 498111
it should have been 13-14 lbs. sorry
Yeah they are extremly rare
The have the STI logo stamped into them on the back
Old 03-30-2019, 08:04 AM   #567
Specgtr
Member#: 173256
1999 V5 STI coupe
JDM STI forged s202 rims, made by Rays for STI. very similar to CE28.
17x 7.5, 53 offset, 5x100
7kg/15.4pounds.
Specgtr is offline   Reply With Quote
Old 03-31-2019, 02:32 PM   #568
ProTreeCRX
Member#: 499786
Anyone here know the wheel specs (height, width, offset, pcd) of the 2018 Type RA?
ProTreeCRX is offline   Reply With Quote
Old 03-31-2019, 11:33 PM   #569
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
2018 Type RA wheels (Gold)
Part# 28111VA230
19x8.5" BBS Forged Aluminum Alloy
+55mm offset
5x114.3 bolt pattern
I've seen references to the wheel weight coming in at ~24.2 lbs ("The forged-aluminum, 19-inch BBS wheels save 17.2 pounds" over the standard STI's cast wheels)
245/35-19 Yokohama Advan Sport V105 tires
These JDM wheels are very similar (11 kg):
https://www.sti.jp/en/parts/wrxsti_v.../ST28100ZR570/
WRXnick16 is offline   Reply With Quote
Old 04-02-2019, 02:27 AM   #570
ProTreeCRX
Member#: 499786
Part# 28111VA230
+55mm offset
thank you sir
Old 04-12-2019, 06:20 PM   #571
mrwillig
Member#: 407530
07-09 LEGACY GT
OEM WHEEL WEIGHT 23.4lbs
Was just able to weigh them today.
mrwillig is offline   Reply With Quote
Old 04-24-2019, 08:25 AM   #572
MeyeRacer06
Member#: 368240
2016 STI
Series.Hyperblue
According to this post in the Ascent forums, the OEM 20" Ascent wheel weight is 33 lbs.
https://www.ascentforums.com/forum/1...tml#post100699
MeyeRacer06 is offline   Reply With Quote
Old 04-24-2019, 07:47 PM   #573
WRMax
Member#: 126051
2006 WRX Ltd. Wagon
Noob Q here and I swear i've been searching to find answers..
2006 WRX Wagon
Stock rims are 17x7" w/+55 offset
I was given(free) a set of 2011 WRX rims that measure 18x8" w/+53 offset
Is this well outside of acceptable range offset for my vehicle? I don't believe i'll have any rub issue on my struts but couldn't find anything about this amount of offset and how it will affect wheel bearings.
Any help is greatly appreciated!
Last edited by WRMax; 04-25-2019 at 12:41 PM. Reason: I guess i dont know how this posting stuff works. oh well
WRMax is offline   Reply With Quote
Old 04-25-2019, 11:22 AM   #574
96accord
Member#: 145105
'15 Accord (Daily)
2006 WRX Wagon
PM'd to not clutter this thread.
Old 07-01-2019, 02:26 AM   #575
Basti33
Member#: 503756
Registered just to post this. From what I understand these came off a JDM spec c type r STI circa 2006 but I am happy to be corrected(I'm a subie noob). I bought a set for my '18 outback and it was only once I started looking for a 5th as a spare that I realised they weren't common.
Offset: +50
Bolt pattern: 5x114.3
Wheel Weight: 19.7lb / 8.94kg
OEM-equipped tire size: unknown
Notes: Enkei MAT process
Basti33 is offline   Reply With Quote
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
