Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2020
Old 04-11-2019, 12:48 PM   #2101
T-37
Member#: 175624
0304 WRX WRX
SY WRB
What does everyone like for clutches? I've got a South Bend that seems to let go above a certain torque (odd since the oem clutch before it held fine).
I'm thinking about just getting an Exedy Hyper Twin and being done with it.
Are puck clutches okay to live with? Is an organic type more likely to survive if you slip the clutch just a little too long (over a carbon or ceramic?)
Edit: I should add 6MT with 1.5way R160 and all WRX axles
T-37 is online now   Reply With Quote
Old 04-11-2019, 07:29 PM   #2102
101rs
Member#: 38124
2000 Impreza RS
BRP
I'm running a full face Competition Clutch in my sm car and has held up to 400whp for a few seasons now, pretty happy with it.
101rs is offline   Reply With Quote
Old 04-12-2019, 10:22 AM   #2103
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
I also use a full face organic clutch, but from Exedy in my SM car. Has held up to 475 wtq for a while. I like the idea of a twin disk, but the full face setup is WAY cheaper and keeps working.
subydude is offline   Reply With Quote
Old 04-12-2019, 11:15 AM   #2104
jahjahsqc
Member#: 454825
2011 Impreza STI
I also run an Exedy. I tried the 6 puck at first and hated that decision. The motor had to come back out for something not-clutch related and I swapped to a full disc and I love it. I'm at like 360 tqe
jahjahsqc is offline   Reply With Quote
Old 04-12-2019, 03:11 PM   #2105
1qukSti07
Member#: 326585
2007 STi
I'm running the ACT sprung 6-puck disk with the HD pressure plate. It's holding up well at 525wtq. I have launched on it well over 100 times in the last 2 years, it has not yet slipped at all. The engine came out for a spun rod bearing and it had plenty of meat left on the disk. It is a little chatty in stop and go traffic, but since the car see very little street time, I have no problem with it.
1qukSti07 is offline   Reply With Quote
Old 04-12-2019, 07:56 PM   #2106
wantsti
Member#: 134764
04 sti
java black pearl
I have the act 6 puck and have no complaints about it. Over 400 whp
wantsti is offline   Reply With Quote
Old 04-15-2019, 05:26 PM   #2107
vlad11591
Member#: 295970
2019 STI
CWP
I see people running 255/265 tires for WRX 15+ auto x runs.
Has anything changed? From my understanding, the max width for WRX allowed is 245 correct?
vlad11591 is offline   Reply With Quote
Old 04-15-2019, 06:38 PM   #2108
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
1993 FWD Base Impreza
What class? This is the Street Mod thread and SM has no tire limitations.
Old 04-24-2019, 11:59 AM   #2109
*Ulimited*
Member#: 139249
^ Street touring tire allowances (STU) did go up to 265 within the past few years
*Ulimited* is offline   Reply With Quote
Old 04-24-2019, 12:01 PM   #2110
*Ulimited*
Member#: 139249
ACT Full face organic here as well, i've seen too many twin and triple disk cars have all sorts of driveline breakages
Old 05-15-2019, 01:51 PM   #2111
Wes7143
Member#: 501606
2005 Impreza WRX STi
What do you guys think about running RE-71Rs in SM? I know I can run stickier tires, but I have some 255 width RE-71Rs left over from a street class car. Am I going to be seriously slower this season than my Hoosier running counterparts?
Wes7143 is offline   Reply With Quote
Old 05-15-2019, 02:01 PM   #2112
Thorium06
Member#: 254372
You will be giving up a ton of potential time by not running A7s
Thorium06 is offline   Reply With Quote
Old 05-15-2019, 05:29 PM   #2113
quiksilver_dragon
Member#: 246479
I would say yes. Because 255 is not close to being wide enough for SM regardless. I use to run 255 re71 in SM and the other people were running 295+ A7.
So if you're considering 255's just accept it for what it is and know that you won't be putting down stellar times. You may be competitive locally in SM depending on what you have for local drivers.
quiksilver_dragon is offline   Reply With Quote
Old 05-15-2019, 05:37 PM   #2114
subydude
Member#: 80649
Dusty
As stated, depending on who you have locally, 255 street tires may be enough for fun. Anyone with a remotely prepped SM car on hoosiers will do some damage though, and national level cars start at 315 A7's.
Old 05-15-2019, 05:47 PM   #2115
quiksilver_dragon
Member#: 246479
I need to get on the 315 band wagon. Just not prepared to make the jump/work needed to go up from my 295....
Old 05-15-2019, 06:00 PM   #2116
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
that depends on how you define "seriously" ...but yeah, YES.
that said I won the Packwood tour in ASP, on RE71Rs, just depends on who shows up and on what tire.
DougM is offline   Reply With Quote
Old 05-15-2019, 09:00 PM   #2117
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Its rare for people to run Hoosiers in SM in small local events. Usually SM are the folks with a bunch of mods that aren't too serious.
Our first regional event there were 5 Subarus running RE71Rs in SM, it was fun
Old 05-16-2019, 09:39 AM   #2118
Wes7143
Member#: 501606
Yeah, that's what I thought which is too bad. I think eventually I'll try to modify the car back down to STU to shield myself from the burden of buying A7s.
I think it depends on if the downpipe is catless or catted. I believe if it is catted he can run in STU. But if it's catless it jumps you to SM. Depending on the wheel specs as well.
Right now the car has a bigger turbo than stock and is catless. I don't think it's responsive enough like that for autox anyways and would probably be faster in the tight sections with the stock turbo. The previous owner had it built this way. Maybe when I'm ready I could find someone who would want to trade turbos.
Edit: I should also mention that the car has an IAG stage 2 short block. I'm unsure if that would also keep me out of STU if the compression ratio was not changed, and if the part is not add performance and only adds durability. If that's the case, I probably will not be going to STU ever.
Old 05-16-2019, 09:48 AM   #2119
Wes7143
Member#: 501606
I run in a couple local clubs (CMC in Maine, and SCCNH in NH) as well as NER SCCA. There's a small but serious crowd that runs Hoosiers in prepared in SM classes. That said, there's also a lot of "accidental" SM cars. People who are more into the car than the sport and have found themselves classed into SM rather than trying to arrive there. I bet I'll be able to have some friendly competition with them despite my RE-71Rs.
Old 05-16-2019, 10:03 AM   #2120
subydude
Member#: 80649
Dusty
NER is the home of G-Fab. Lots of good SM people there in all of the classes.
Old 05-16-2019, 10:20 AM   #2121
Thorium06
Member#: 254372
A built, non OEM motor, regardless of it actually makes the car faster puts you in SM anyway
Old 05-16-2019, 10:26 AM   #2122
Wes7143
Member#: 501606
That sucks. I just don't want to eat ring lands.
Old 05-16-2019, 11:44 AM   #2123
Thorium06
Member#: 254372
Nobody does. FWIW, I went through 3-4 OEM motors during my years in STU
Old 05-17-2019, 04:18 PM   #2124
quiksilver_dragon
Member#: 246479
SM in our regions around here in the midwest(Wisconsin/Illinois/Iowa) are all pretty competitive and at least 2-4 cars show up with 295+ Hoosier A7's per event.
Old 05-22-2019, 06:08 PM   #2125
smoky
Member#: 221439
2004 STI
I just build a new A2W intercooler setup and it works pretty good, but water can climb up a bit too much after a few runs. I was at Seneca and I have seen 2 people (1 in SSM) puting ice in there reservoir and telling me it's legal. I check the rules, can't find if that's legit or not. Any opinion?
smoky is offline   Reply With Quote
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
