Brakes & Suspension Forum sponsored by The Tire Rack |
06-26-2018, 08:46 AM | #601 |
Member#: 174548
South East
Vehicle:2002 impreza flat black |
The Unofficial "How to Lift your Impreza" Thread
Lifted this weekend. Used subtle solutions 2inch trailing arm spacer. Blox adjustable end links for the front sway bar and forester struts and springs. Did it by myself and took roughly 3 hours due to Florida heat. Time for some bigger tires and an alignment. I had lifted my previous wagon with a more complex set up but this basic setup is just as good.
07-16-2018, 03:36 PM | #602 |
Member#: 485418
E. Canada
Vehicle:2005 Outback Sport Green |
05 Obs
Not sure how active this thread still is, but im SUPER interested in lifting my 05 OBS with forester struts. I don't have too much money, but from what I've understood, I can use almost all parts directly off foresters and outbacks. Luckily for me, my local scrapyard is filled with 03+ foresters and outbacks, so finding parts wouldn't be too hard. I just need to know what EXACTLY do I ABSOLUTELY NEED. (I also want to keep my swaybars) Here is a list of things I already know:
Forester struts Forester trailing arm brackets Forester / outback rear sway bar bracket (?) Camber bolts (Rear only) What else would I really need to avoid issues, or is this a solid no frills solution? |
08-22-2018, 09:31 PM | #603 |
Member#: 490524
Why have I never seen a jacked up Impreza on the road? This is so cool.
08-26-2018, 08:42 PM | #604 |
Member#: 490495
I looked through most of this thread and didn't see a whole lot about 15+ wrxs. I was hoping to get a solution thats as high as possible with stock CV joints. Ideally a coilover that went 2" higher than stock for winter, and be able to drop back to stock or lower in the summer. I was considering a set of 2" spacers along with a coilover. I'm wondering if I can actually just get coilovers made for a forester and get everything with that.
10-10-2018, 02:12 PM | #605 |
Member#: 486785
Curious to know if anyone has has vibration issues after lifting? I have a 2007 wrx limited that I have lifted with, 2006 orester strut and springs, outback trialing arm bracket, outback rear sway bar bracket and adjustable front end links. I have what feels like a slight wobble in first gear when I accelerate and at highway speeds there’s a small vibration in the steering wheel.
10-17-2018, 01:12 AM | #606 | |
Member#: 337778
NWIC
Vehicle:2002 WRX Wagon Silver |
That looks rad!! My ‘02 is the same way. What size tires are you going with |
10-22-2018, 03:56 PM | #607 |
Member#: 492393
lifting 2005 impreza wrx wagon
I recently purchased forester struts and king springs for my 05 wrx. I also purchased the rear trailing arm spacers. Does anyone know if I will need the subframe spacers and steering extension?
10-23-2018, 09:36 PM | #608 | |
Member#: 445600
Tri-State
Vehicle:2002 Outback Sport Green |
And don't ever use aftermarket axles on a lifted Subaru!! |
10-31-2018, 10:31 PM | #609 |
Member#: 492393
I'm using kyb forester springs and King springs standard height for forester... 2" rear trailing arm spacers
11-12-2018, 02:38 PM | #610 |
Member#: 493949
Vehicle:2012 Impreza Base Hatchback, 5 Speed |
Help Needed Converting 2012 Impreza to Crosstrek Height
Hi Everyone,
This is my first post here, but I'm a long-time Subaru driver. I started with a 90's Impreza, then a 2004 Impreza, then a family, then a 2009 Forester, then a 2017 Forester, and now a used 2012 Impreza Base Model for our 2nd car. All stick shift. Probably have over 300K miles driving Sub's. The height of the Impreza is such that it bottoms out on a section of my driveway area that I sometimes use for overflow parking. I also have a long driveway that gets piled up with snow, so I'm concerned about bottoming out there too. So I'd like to do a mild lift. Hoping the forum can set me straight on the best way. I'm thinking the height of the Crosstrek should be fine...and I'll pair it with the larger Crosstrek tire size for a set of snows I need to buy soon. Can someone help with the differences between Impreza and Crosstrek suspensions that I'd need to address? Is it simply a strut swap? Or are other parts swaps needed? I'll look around for junked Crosstrek's for parts. This is Vermont...and Subaru is practically the state vehicle. Thanks! |
11-12-2018, 03:06 PM | #611 |
Member#: 493949
Looks like I can get a set of 4 used factory Crosstrek Strut + Spring assemblies locally for about $280. Does that sound reasonable?
12-11-2018, 06:38 PM | #612 |
Member#: 101384
SCIC
Vehicle:2004 TS Platinum Silver Metallic |
Anyone have info about different Forester struts?
I've been checking this thread while planning a lift on my 04 Impreza Wagon and just now finished scrolling through ALL the pages and didn't see mention of different Forester struts. I see a lot of people using "04" and others using "08". I just checked and part numbers (KYB excel g) are different for the 04 and 08 MY's. Does anyone know if this is some minor difference, possibly even valving or is it actually a physical difference that would lead to different amounts of lift? I found some 04 struts locally I'm thinking of picking up but I'd still need to find springs. |
12-14-2018, 11:40 PM | #613 |
Member#: 472828
MWSOC
Vehicle:2007 Impreza 2.5i Grey |
Alternative to Camber Bolts?
If I were to get the 2" spacers from Subtle Solutions for the trailing arms would I need to get the camber bolts? or would the spacers compensate for the shift?
12-16-2018, 10:09 PM | #614 |
Member#: 157921
Click
12-16-2018, 10:45 PM | #615 |
Member#: 463653
RMIC
Vehicle:2003 WRX Wagon @vader.wrx |
The trailing arm spacers act to move the wheel backwards, they don't have anything to do with camber. Still gonna need the bolts
01-04-2019, 08:18 PM | #616 |
Member#: 472828
MWSOC
02-08-2019, 09:10 AM | #617 |
Member#: 488260
Vehicle:2011 Impreza WRX Blue |
Could anyone provide dimensions here for the SG forester rear strut? Thanks!
02-15-2019, 08:30 PM | #618 |
Member#: 433063
Looking to lift my 08 WRX hatch.
My daily and trail car for coyote hunting. Wanting to go kyb Forester struts and King springs. Primitive says go with raised WRX springs instead... What do I need for rear tire centering. I've read multiple things... Thinking of just adf multi link or new rear trailing arms |
03-27-2019, 03:27 PM | #619 |
Member#: 499651
08 impreza outback sprot
Hey guys so I have an 08 impreza outback sport in great shape. now I'm not expert but from the looks of this forum I can lift this thing witch I need living were I live. (on top of a mountain in Vermont) it looks to me from what has been said here that I can pretty painlessly put 07 forester struts and spring in this to achieve 3 inches or so. I have the struts and springs used in good shape is there any thing I should really be watching out for with this modification. I will be having a shop do it as I am not skilled enough. any pointers would be great.
03-31-2019, 11:21 PM | #620 |
Member#: 499841
exhuast tuck?
Just finished about 5 months of work restoring a junked 98 legacy that I'd inherited. The car was basically worthless when I inherited it, with the dreaded oil separator plate spewing oil and causing quite a stink. Anyway, I restored the interior, banged out the dents, replaced body panels, replaced nearly every rubber component on the engine and transmission. I lifted it with 98 forester struts and a 30mm spacer, and lowered the drivetrain with the parts outlined in the original post.
When I was all done I went under to measure my new clearance expecting like a million inches. It is nice that i can crawl under the car without jackstands now. What I don't like is the exhaust is now the lowest part on the bottom of the car is the front catalytic converter at 7 inches. The exhaust looks like it's hanging way down because it got spaced down but the heat shielding didn't. Question, has anybody attempted to "tuck" their exhaust for extra clearance? I thought maybe the easiest fix would be to fabricate a shorter hanger that's bolted to the transmission. I figured that would lift both catalytic converters and not add any leaks before the o2 sensors. Beyond that I would need to fabricate or buy some new exhaust headers. Perhaps this is all a bad idea, since bringing the exhaust heat closer to the tranny could cause some problems. |
04-08-2019, 11:32 AM | #621 |
Member#: 245653
MWSOC
Hey all,
I'm looking to lift my 2009 impreza. I have found very very few threads with minimal information. Ideally I can probably use FXT struts to get a 3" or more lift, but i'm not sure what else I need to do, to have this be proper and safe. Can somebody please assist? Thanks! |
04-09-2019, 12:29 AM | #622 |
Member#: 491721
Vehicle:2009 Impreza OBS Newport Blue Pearl/Silver |
I'm looking to get a 1.5" or 2" spacer lift kit for my 09 OBS. I also currently have a 22mm whiteline rear sway bar. I was wondering if installing a spacer kit will interfere with the sway bar's endlink mounts or possibly any other suspension components? Or will it be just as simple as bolting the spacers on to the top hats? Sorry, I'm still learning about this suspension stuff.
04-14-2019, 01:12 PM | #623 |
Member#: 326261
05 Saabaru rear strut and wheel clearance
Is anyone else running into an issue with rear wheel clearance and the strut housing?I have only a few mm’s of clearance. What’s the best way to remedy this?
My current set is below: 07 forester-strut and springs complete assembly 07 forester- rear trailing arm brakes 07 forester- rear sway bar and brackets Stock 16” wheels w/ 215/65-16 General Grabbers at2 |
04-14-2019, 01:33 PM | #624 | |
Member#: 101384
SCIC
My much bigger problem is the rubbing in the front inside of the tire on the unibody at full lock. Which, I imagine you will have as well. |
04-14-2019, 02:07 PM | #625 | |
Member#: 326261
As far as the fronts yes I’m rubbing hella bad at full lock. But I knew that was going to happen with 27” tires. But if there’s a way to lessen or even better solving the issue all together I’m all ears. Last edited by Finch1021; 04-14-2019 at 04:22 PM. |
Similar Threads | ||||
The Official "How old are you?" thread | wrxpeed | Off-Topic | 53 | 07-03-2019 11:11 AM |
The "How to spend your 4-day weekend w/o your girlfriend" thread | MK19_ | Off-Topic | 44 | 04-16-2007 01:18 PM |
The official "How much of your bumper did you have to cut for your FMIC" thread. | lawn boy | Interior & Exterior Modification | 0 | 04-17-2005 11:56 AM |
The The Unofficial What front lip is that? Thread. post and tell.... | mmmprza | Member's Car Gallery | 3 | 04-11-2004 02:14 AM |
re-reading "how to make your car handle" last night | jmott | Texas Impreza Club Forum -- TXIC | 18 | 08-18-2002 06:02 PM |
