Welcome to the North American Subaru Impreza Owners Club Thursday April 25, 2019
Old 03-23-2017, 06:51 AM   #26
Sky peterson
Member#: 291062
2008 Impreza Wrx
Like you I didn't want to spend the money on the tool that I'd use once or twice so I made one out of a frying pan. First I held a piece of paper to the face of the crank pulley, than took a pen and punctured the paper where the holes are that the subie tool utilizes. After that I held the paper to the frying pan and drilled out the holes. Next put on bolts with washers and nuts to simulate the subie tool . Than drilled a hole through the center for the 22mm socket and so on..
Sky peterson is offline   Reply With Quote
Old 03-23-2017, 10:03 AM   #27
crap GC 99
Member#: 413457
1999 Impreza L
Originally Posted by Charlie-III View Post
That top hole should allow you to get to the ring gear for the starter.
Do you have a AT or MT?
I have an automatic..
I looked in there i expected to see teeth.. but saw mostly empty space.
looking towards the rear i saw some relatively smooth gadget.. i guess its the torque converter. but the teeth were no visible or accessible. i think they are on the rear side of that. I may remove the starter and get to them that way if its not too much trouble. otherwise i may try the chain wrench with belt. or break down and buy the tool.
my crank pulley has very small holes that are unfortunately too small for the 3/8 extensions trick.
crap GC 99 is offline   Reply With Quote
Old 03-23-2017, 10:06 AM   #28
crap GC 99
Member#: 413457
1999 Impreza L
that is so awesome ! hahah
Old 03-23-2017, 01:36 PM   #29
JohnM10
Member#: 244231
2018 Crosstrek CVT
I purchased and used the Grimmspeed tool when I did my timing belt. It was well worth the $50.
http://www.grimmspeed.com/crank-pull...l-tool-subaru/
JohnM10 is offline   Reply With Quote
Old 03-23-2017, 02:59 PM   #30
Sky peterson
Member#: 291062
2008 Impreza Wrx
Edited
Old 03-26-2017, 02:18 AM   #31
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Look down the side of your bell housing. You may find a hole that you can stick a screwdriver though. You may be able to use a flat head screwdriver and engage the ring gear.
This image illustrates the holes.
http://i226.photobucket.com/albums/d...valance019.jpg
edit: Clearly this image is of a 2.2 or 1.8
CosmoTheCat is offline   Reply With Quote
Old 02-20-2018, 06:40 PM   #32
easy fix
Member#: 482365
Smile Crank Pulley removal and installation (no special tools)
Hi. I have a video that shows how to remove the crank pulley. Its easy and fast and requires no special tools. I hope this helps. Thanks for watching!
~shaun
easy fix is offline   Reply With Quote
Old 04-22-2018, 02:10 PM   #33
easy fix
Member#: 482365
Smile Crank pulley removal 2
Here is probably the best video on crank pulley removal and installation using nothing but the belt. This is my second video. Don't buy special tools. Make em! *new video as requested*
~shaun
Old 04-23-2018, 11:24 AM   #34
vfeno
Member#: 365813
2001 2.5RS
BRP
When I did this I ghetto rigged a “specialty tool” out of some scrap 2x4 and bolts. This mimicked the function of Subaru’s speciality tool for 1000x less. I wish I had kept pictures.
vfeno is offline   Reply With Quote
Old 03-18-2019, 03:36 PM   #35
honest john
Member#: 499163
Originally Posted by JamesWilson2 View Post
Put it in 5th gear, have someone step on the brakes. Apply long breaker bar to crank pulley.
The easiest way is to put a socket with a long breaker bar and a pipe on the bar on the crank pulley bolt. Then position the bar and breaker pipe on the ground or against the underside of the car chassis. Make sure you have jammed the bar on the correct side of the car so when you crank the car over on the key the bar locks and stops the crank bolt from turning, whilst the key being turned rotates the crankshaft which loosens the bolt.
It only takes 1 or 2 turns of the key for 3 or 4 seconds to loosen.
If its auto no 5th gear available.
honest john is offline   Reply With Quote
Old 03-18-2019, 11:32 PM   #36
CosmoTheCat
Member#: 3409
98 My FMIC
3 or 4 seconds and you'll potentially run the crank bolt all the way out and into your radiator fans. A half a second is all you need.
Old 03-19-2019, 08:48 AM   #37
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Correct, all you're looking to do it break the bolt free, so a starter bump is all that's needed.
Most Subaru, I take the overflow tank and fans out for working room. Thus no issue spinning the bolt to into the fans.
Old 04-02-2019, 01:31 PM   #38
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
i went to home depot, measured out a piece of pipe to slide over my ratchet. it was about 3-4 feet long and i put every muscle in my body into it. Finally broke loose.
the crank method just stalled.
David Medina is offline   Reply With Quote
Old 04-03-2019, 03:06 AM   #39
CosmoTheCat
Member#: 3409
98 My FMIC
What are you doing in Alabama?
Old 04-13-2019, 03:59 PM   #40
Nabox_27
Member#: 500247
2006 Impreza OBS
Evergreen
Originally Posted by rkramer View Post
And for future reference, the starter method isn't nearly as scary as it sounds, and works instantly! Your chances of breaking something with that are actually less than any other method.
Yeah that didn't work the power steering pulley skinned the back of my hand and I almost bled out. DO NOT TRY.
Nabox_27 is offline   Reply With Quote
Old 04-13-2019, 11:39 PM   #41
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
How did you manage that? I haven't done the starter bump method with my Subaru, but did with our old Odyssey second time I did the belt - you need to make sure you know which direction the engine rotates, then brace the breaker bar on a frame member or (better) the ground, then just blip the starter.
Why was your hand in there when you were trying it?
DrD is offline   Reply With Quote
Old 04-14-2019, 12:02 AM   #42
CosmoTheCat
Member#: 3409
98 My FMIC
Dude, you did it wrong.
If the power steering pulley skinned your hand while it was turning the key inside the car, it went all kinds of sideways.
Old 04-15-2019, 10:42 AM   #43
Nabox_27
Member#: 500247
2006 Impreza OBS
Evergreen
Lol. My friend posted this on my account. He wanted to try the starter bump method, and I didn’t have enough foresight to lock the breaker bar in place instead of using a human arm. He was holding the bar while I hit the starter. Now I know to never do this and have purchased a crank pulley removal tool. Thanks for the comments. (BTW he’s ok)
Old 04-17-2019, 12:53 AM   #44
CosmoTheCat
Member#: 3409
98 My FMIC
D'oh.
Yeah you gotta have a kung-fu grip to just arm wrestle it.
Old 04-17-2019, 10:43 AM   #45
Nabox_27
Member#: 500247
2006 Impreza OBS
Evergreen
D'oh.
Crank pulley removal tips - engine out of car. boostinms Normally Aspirated Powertrain 17 04-18-2010 04:40 PM
Crank Pulley Removal Roy Service & Maintenance 12 06-09-2009 11:45 PM
Stock crank pulley removal questions blueandgold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 06-17-2007 02:07 PM
Crank Pulley removal pilfflip Service & Maintenance 10 12-29-2003 10:54 PM
Crank Pulley removal pilfflip Legacy Forum 12 12-26-2003 11:27 AM
