Welcome to the North American Subaru Impreza Owners Club Wednesday June 19, 2019
Old 08-07-2018, 02:03 PM   #51
Tracy4381
Member#: 489824
Default NGK Spark Plug Wires - What Part #?
Hey there!! Our 2004 Subaru Legacy 35th Anniversary Edition recently underwent a similar engine swap by the previous owner, however, plugs and wires were not done. A Japanese EJ20 2.0 engine is what was installed.
We're wanting to put NGK wires and plugs on but with the engine swap, we're not 100% sure what part numbers we need. Two of the wires are longer than the other two - two are approx. 23" long and 2 approx. 18" long. We tried calling NGK direct, but wire lengths are not part of their specs and their parts reps couldn't tell me what set we'd need.
Could you please point us in the right direction for both plugs and wires?
Tracy4381 is offline   Reply With Quote
Old 08-09-2018, 04:49 PM   #52
NilesM
Member#: 489927
2009 Impreza 2.5i
I just did this swap. The JDM 2.0 had the coil mounted to the center of the intake and the wires were all the same length. I used the 2.5 intake which has the coil towards the back and off to the side. The spark plug wires were different lengths. This suggests to me that the previous owner likely used the 2.5 intake setup and the wires you order should be for the 2.5 not the 2.0.
NilesM is offline   Reply With Quote
Old 08-25-2018, 07:46 PM   #53
Leonardo
Consigliere
Super Moderator
Member#: 185
1999 Impreza wagon
Dark Gray Metalic
No one answer my question above about which spark plugs were used, same number as the ones that came with the jdm engine?
Also, anyone forced to run 93oct? I get pinging when I don't.
Leonardo is offline   Reply With Quote
Old 10-04-2018, 12:27 AM   #54
Jericho11
Member#: 381826
2002 forester L
white
Forester
so i literally just did this swap in my 2002 forester automatic and i swapped over everything from my ej25 except the sparkplugs. i left the ones that were in the jdm 2.0 block and i figured if it runs im good. and ill check their size/brand setting specifics in a few weeks and put fresh ones in.
Jericho11 is offline   Reply With Quote
Old 10-09-2018, 12:35 AM   #55
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Swap info? Maybe.
Side-note:The 2005 was the return of the EJ253 MAF-based engines BUT no i-AVLS on the cams that the '06+ engines had on the USDM models. (There's a post on here about using older w/newer - fairly recent - that helps w/that...Search.)
USDM to JDM:
1. Swap your USDM intake manifold - including all the wiring harness, injectors, etc - everything to the new(er) JDM EJ20. Get new IM gaskets.
2. Swap All the sensors - Cam(shaft), Crank(shaft), - anything that has a wire.*
>>>..Why? Because the USDM ECU/ECM must be different in how it 'reads' the signals, so those sensors must match>>>go to Japan and ask a Subaru engineer? :-)
3. Swap the Cam and Crank sprockets/gears. The 'triggers' must match the sensors, which must match the ECU. See #2.
4. Head Gaskets? If you're a savvy Subaru owner you know that you should ALWAYS replace the HG when swapping in a USED engine. Sounds like Cometic may be the best source?? Or find an Aussie site to order them?
5. Spark Plugs: Do NOT consider this 'the truth' but I grabbed this from a Russian (Google translate) Owner's manual for the 2005 EJ20/EJ25:
Engine models 2.0 liter without turbocharger and with 2.5 engine
- BKR5E-11 (NGK)
- RC10YC4 (Champion)
- Or just match whatever is in the EJ20.
6. Timing belt kit, water pump, oil pump "should" be the same as most every other EJ-Series SOHC engine - there are some different style WP's -check yours. SOHC EJ25~SOHC EJ20.
* I don't know whether the oil, Temp/CTS, Power steering (?), etc need changed but everything above states to change 'em all, so...yeah.
wtdash is offline   Reply With Quote
Old 10-19-2018, 04:13 AM   #56
Andrew1708
Member#: 492894
Default Sohc Swap
Originally Posted by wtdash View Post
Swap info? Maybe.
USDM to JDM:
Does anyone know if Years/Generations can be swapped? ie: 2001-2004 EJ20 into a 2005-2009 EJ25 car? These JDM 2.0s are 1500$ cheaper than than the 2.5s but only for Earlier models. The 1 difference I know of is the AVLS sensors on 2.5 heads, but can I maybe swap my heads onto the 2.0?
Andrew1708 is offline   Reply With Quote
Old 11-30-2018, 11:51 AM   #57
JuNacy
Member#: 351305
Default EJ20 in an EJ22 equipped car
Would the process be similar if this motor was going into an ej22 equipped car (01 Impreza OBS)? Thanks.
JuNacy is offline   Reply With Quote
Old 11-30-2018, 12:48 PM   #58
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Yes...you'll need the dual-port exhaust header ( I think) from a 2.5.
Old 12-11-2018, 09:45 PM   #59
Leonardo
Consigliere
Super Moderator
Member#: 185
1999 Impreza wagon
Dark Gray Metalic
Yes, which is what I did on my 99 and as above, only difference needed was the dual port exhaust manifold so I went with an uel header.
Old 05-10-2019, 07:36 AM   #60
J_wrxnxx
Member#: 501389
So Iím looking at doing a timing belt kit with my ej25 to ej20 swap are the timing kits all the same between these engines
J_wrxnxx is offline   Reply With Quote
Old 05-11-2019, 09:47 PM   #61
DArth Legacy
Member#: 501381
Default Sorry I need help with my ej25d
Ok Iíve been the victim of a robbery. A illegal repossession. My friend was nice enough to give me a 1999 legacy outback limited. But it had a bad rattle. Thought it jumped time and kissed the valves. But after pulling the engine ej25d frankenmotor. The heads were fine. But the bottom end has metal in it from losing rod bearings and the crankshaft has barely rubbed the block. From sliding back and forth. My question is if my block canít be rebuilt. What can I do?? What shortblock can I buy were I can use my intake heads Ecu. Something plug and play. I donít need anything that rips up pavement but I donít want my wagon lagging up these Arkansas hills. I just need to not walk to work and get my wife to her kemo treatments. Bless you all for even reading this. Any advice is welcomed and appreciated.
DArth Legacy is offline   Reply With Quote
Old 05-12-2019, 01:13 AM   #62
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Originally Posted by DArth Legacy View Post
But after pulling the engine ej25d frankenmotor. The heads were fine. What can I do?? What shortblock can I buy were I can use my intake heads Ecu.
Frankenmotor = 2.5 block w/2.2 heads. Is that what you pulled out?
The easiest and cheapest? Get another 2.2 full longblock. What exhaust manifold - Single or Dual-port?
'90-'95 are Dual; '96-'98 are Single; '90-'94 won't be EGR but can be made to work.Use your IM on it. '95-'98 are plug and play 'as is' -it'll plug in but must match header.
Old 05-12-2019, 01:13 AM   #63
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Where'd you get the EJ20...They should know....but it's likely on here or other Subaru forum.
Old 05-12-2019, 01:53 PM   #64
DArth Legacy
Member#: 501381
Sorry I saw someone on here say the ej25d was Subaruís frankenmotor. Itís just a ej25d. 1999. I think the crankshaft has too much slop just to replace the bad bearings. But this is the only boxer engine Iíve worked on that didnít come out of an airplane. So I could be wrong. The crank got into the block and wore a spot but it just barely got into it
Old 05-12-2019, 02:47 PM   #65
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Read this first: https://www.subaruoutback.org/forums...c-vehicle.html
Old 05-14-2019, 03:25 AM   #66
DArth Legacy
Member#: 501381
Default Thank you!
The reverse frankenmotor it is. Does the 2.2 block with 2.5 heads have enough power to pull hills well in the outback wagon?
Old 05-14-2019, 10:01 AM   #67
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
What?
I haven't read that thread in awhile, but you don't want that 'reverse' engine if that's suggested..just get a 2.2 FULL engine and drop it in....exhaust manifold needed if '96-'98.
Old 05-23-2019, 12:42 AM   #68
CBDslappy
Member#: 491899
quick bump what head gasket do I use for an ej201
CBDslappy is offline   Reply With Quote
