Welcome to the North American Subaru Impreza Owners Club Sunday May 19, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 05-15-2019, 03:07 PM   #1
michelle_lynn
Member#: 484798
2015 WRX
Default 2015 wrx burning oil??
Excessive blue smoke coming out of exhaust after acceleration.. I am catless but the blue smoke is way worse than it was a couple months ago. Oil level is at low mark by 3000 miles after oil change. Subaru claims that oil consumption test passed that there is no problem at this time... what are the possibilities ?
michelle_lynn is offline   Reply With Quote
Old 05-15-2019, 03:11 PM   #2
michelle_lynn
Member#: 484798
2015 WRX
I also have Perrin sump restrictor on the car as well.
I have an appointment to get it looked at but i was hoping someone would have some insight in the meantime.
Old 05-15-2019, 03:15 PM   #3
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Keep tabs on the oil level yourself. You should be able to gauge it if indeed consumption is above normal. We just got a short block in our Crosstrek. I waited to 90k miles to have it checked and it failed spectacularly (well over double the amount considered excessive down) and then drove through the winter because snow tires. I change oil at 5k and the oil light has always gone on before oil change time. Do you find this?
Oh, also, did they say how far down your oil level was when they did the test or just say it passed. The number is 10 ounces in 1200 miles for fail.
Old 05-15-2019, 05:09 PM   #4
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
If your compression and leak down tests come back good, it's probably the turbo.
jasonwrx86 is offline   Reply With Quote
Old 05-15-2019, 10:15 PM   #5
michelle_lynn
Member#: 484798
2015 WRX
I canít remember what the number was but it was just before winter when they did the test.
I donít know if this means anything but when I did the last oil change I only got about 3 1/2 quarts of oil that drained out.
Old 05-15-2019, 10:19 PM   #6
michelle_lynn
Member#: 484798
2015 WRX
The oil light came on once and thatís when I brought it to Subaru for the oil consumption test. They werenít concerned of course...
