Welcome to the North American Subaru Impreza Owners Club Tuesday June 25, 2019
Old 05-13-2019, 09:58 AM   #8101
kaeknows
Member#: 357191
2016 WRX
ISM
@stoleyourboard, sheesh is that the first 9.5 +22 255 on VA on coils? tucking meat too?
kaeknows is offline   Reply With Quote
Old 05-13-2019, 10:11 AM   #8102
Stoleyourboard
Member#: 483007
Congrats on the 2019 WRX Kae!
Stoleyourboard is offline   Reply With Quote
Old 05-13-2019, 10:33 AM   #8103
1SIKLGT
Member#: 345648
O.g. bbs
1SIKLGT is offline   Reply With Quote
Old 05-14-2019, 01:31 AM   #8104
forzaosaka
Member#: 438347
2017 WRX
CWP
Thumbs up
Originally Posted by Stoleyourboard View Post
Car handles great imo, I could raise it up and probably run around -2 rear camber, but i love the way the car looks too much.
looks good!
forzaosaka is offline   Reply With Quote
Old 05-14-2019, 02:09 AM   #8105
96JZA
Member#: 463078
2018 WRX Limited
Crystal White Pearl
2018 WRX
Volk TE37 Diamond Black 18x9.5 +22
255/35/18 Yokohama Advan AD08R
Bc Racing Extreme Low Coilovers 14KF/14KR
Racer X RUCA
Cusco LCA
Racer X Toe Arms
SPC Camber Bolts
-3.5 Rear
-4 Front
No Rub
....I'm in love
96JZA is offline   Reply With Quote
Old 05-16-2019, 12:29 AM   #8106
bamx
Member#: 501386
hey, can someone please help me identify these wheels? thanks in advance
http://www.subispeed.com/chargespeed...i#.XNzmM6d7EWo
bamx is online now   Reply With Quote
Old 05-16-2019, 01:09 AM   #8107
jdmct9mr
Member#: 289223
2015 STI
CBS
Looks to be Work Emotion D9Rís.
jdmct9mr is offline   Reply With Quote
Old 05-16-2019, 01:56 AM   #8108
bamx
Member#: 501386
Default 2015 WRX/STi Aftermarket wheel and tire fitment
Thank you !
Edit: and of course they weigh 25 lbs per wheel..
Old 05-17-2019, 02:13 AM   #8109
jdmct9mr
Member#: 289223
2015 STI
CBS
Thank you !
Yeah thatís usually the downside to most Work wheels. I had a set of Work Emotion 11Rís in 18X8.5. Those things weighed about 23LBS each. I would maybe suggest some Enkei RPF1ís. They are strong, light weight, made in Japan, and they are reasonably priced.
Old 05-18-2019, 01:28 AM   #8110
bamx
Member#: 501386
Yeah RPF1ís are definitely in contention, ideally I would get ze40ís but I need to find a seller who would accept my kidney for them
Old 05-18-2019, 02:49 PM   #8111
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
WedSport makes some nice wheels that are lightweight, and will be a bit less expensive than ZE40, although pricier than RPF1s. Nice middle-ground as far as lightweight "legit" wheels go in terms of cost.
YungBoba is offline   Reply With Quote
Old 05-19-2019, 04:56 AM   #8112
bamx
Member#: 501386
Yeah just discovered the tc105n/x! They looked quite nice too. Does anyone know how these fit on the 18+ STIís?
Old 05-20-2019, 04:14 PM   #8113
Kami Speed
Member#: 96479
2006 WRX STI
Obsidian Black Pearl
TC105N is discontinued. But the TC105X are available! Great size for these cars is 18x9.5 +35 though depending on what tire you want, you may need to roll the rear fenders. And yes, they clear 2018+ 6POT Brembos. Let me know if you are interested in a set and I can help
Kami Speed is offline   Reply With Quote
Old 05-20-2019, 09:27 PM   #8114
rst.ack
Member#: 500326
2015 WRX Premium
Even though they're discontinued, if you look hard enough you can still find the odd set of TC105Ns in 18x9.5 +35 or +45. I haven't seen any of those in black though unfortunately, and I'm not a huge fan of the hyper black looking TC105Xs.
rst.ack is offline   Reply With Quote
Old 05-22-2019, 12:46 AM   #8115
Stickers
Member#: 301428
2015 WRX
CWP
Ohlins R/T Coils
TE37RT - 18x10 +29
-1.6 camber all around
SPL Rear LCA
Dunlop Direzza DZ102
255/35R18
Stickers is offline   Reply With Quote
Old 05-22-2019, 02:00 AM   #8116
tawheed
Member#: 124413
2006 Impreza WRX
18x9.5 +40 with firestone indy 500 265/35 on swift springs - will I need to roll rear fenders?
tawheed is offline   Reply With Quote
Old 05-22-2019, 02:00 AM   #8117
forzaosaka
Member#: 438347
2017 WRX
CWP
they will
Old 05-22-2019, 02:04 AM   #8118
forzaosaka
Member#: 438347
2017 WRX
CWP
no need
Old 05-23-2019, 10:03 AM   #8119
bamx
Member#: 501386
so im thinking of going with TC105x in 18x9.5 +35 (2019 STI)
I want to run michelin PS4S in 265/35/R18 but it appears these will rub on RCE yellows
do you guys recommend 18x9.5 45 with the above tires OR should i just go 255/35/r18? with +35 offset?
Old 05-23-2019, 11:03 AM   #8120
rst.ack
Member#: 500326
2015 WRX Premium
If it were me, since it seems like you want a meatier setup (because of 265s on 9.5s), I would go with the +45 instead of downsizing the tyre.
Full disclosure, I have no prior experience with wheel/tyre fitment - I'm only giving my opinion based on the research I've done looking at similar setups for my 2015 WRX where I've been inclined to lean towards the 18x9.5 +40/+45 over 18x9.5 +35/+38 so I can run more tyre.
One other thing to consider which I can't advise on (because I don't own an STI) is that by going with the +45 offset you are potentially raising the risk of the brembos rubbing.
Old 05-26-2019, 03:13 PM   #8121
rymaggi
Member#: 253442
Anyone running RPF1's 18x9.5 +38 w/ 255 or 265 tires on a STI?
I know they'll work on the WRX. However on the STI they require a 10mm? upfront which could lead to clearance issues?
I'm assuming rolling is required.
Would like this setup, but haven't seen much of it on the STI. Need it to be functional too at the track.
Might just end up getting the Konig Hypergram's 18x9.5 +35. Can't seem to confirm fitment on the STI thought. Sooooo many wheels and more than half don't fit in that size due to the damn Brembos.
rymaggi is offline   Reply With Quote
Old 05-27-2019, 10:48 AM   #8122
kaeknows
Member#: 357191
2016 WRX
ISM
@stoleyourboard
Old 05-27-2019, 07:45 PM   #8123
fox4834
Member#: 502131
2019 STI
Default rota slipstream 18x9.5
has anyone tried using this set up on the 15+sti i had the on my 17 fiesta st and loved them been searching for any advice/pics if someone has used them. thanks!!!
fox4834 is offline   Reply With Quote
Old 05-28-2019, 08:59 PM   #8124
dpetro1
Member#: 487500
2018 WRX
And what setup would that be exactly...
dpetro1 is offline   Reply With Quote
Old 05-29-2019, 07:50 AM   #8125
fullah
Member#: 233053
fullah is offline   Reply With Quote
