06-13-2019, 01:08 PM | #1 |
Member#: 253442
Track Days and Dealing with High Temps
Hi All,
I did my first instructor lead track event yesterday at Sonoma Raceway. I was paired with a GT3 and a Alfa Romeo that was insane. We pushed the cars as hard as we could, WOT almost the entire time it felt like. Person gloating moment: we were his fastest group since January. woot woot. Anyways, I'm running flex, so e85 with supporting mods. Temps were good during the late morning, and around noon-1pm. However once we did our two last sessions around 3. I was seeing 215 and then 225 coolant temps, this may also be because i had to fill up on 91 as i didn't bring any jugs of e85 with me. Questions: Whats the best way for me to keep these coolant temps down? We're going to be doing another event in July, so most likely it will be another 100+ degree day. I've heard the following would be good, possibly.... -Radiator (apparently our 2015's are even slimmer) -Colder thermostat (Not typically good for DD? This is my daily driver) -Ducting (Not sure on this one would love some suggestions that don't require hacking up the bumper) -Oil cooler -Bring e85 to the track Looking for any and all suggestions from people who HAVE been to the track and dealt with similar issues. Edit: I also have a K&N CAI. I do not have the stock Ram Duct installed, would that help?
06-13-2019, 01:42 PM | #2 |
Member#: 408438
Vehicle:2016 WRX STi CBS |
So this guy had done a lot of work on the 2015+ chassis STI to get it to cool off in stock form, but couldn't get it there. I need to review it, but maybe you can start here with what works and what doesn't.
https://www.iwsti.com/forums/2015-st...ing-track.html My research so far has suggested that getting a solid undertray (the factory one has that little cutout by the drain plug that needs to go), modifying the front bumper to open it up, a radiator shroud, oil cooling + KB oil pan, and heat extractors on the hood seem to be a necessity. The best solution of course would be full V-mount but that's not street friendly at all. FMIC only gets you partially there anyway I believe. |
06-13-2019, 01:43 PM | #3 |
Member#: 422693
Tri-State
Vehicle:2016 WRX Premium Lapis Blue Pearl |
Out of all the options below the oil cooler is going to be your best bet. Odds are your oil temps are getting dangerously high if your coolant temps were at 215-220. I've read 250-260 is really about as high as you want to go. Aftermarket oil cooler will also take some load off the stock radiator as that also some what cools the oil
For radiators i believe there is mishimoto and koyo. I've heard mixed things about radiators for these cars and the fans not fitting properly and needing to go to slimmer fans which are less efficient. I'm guessing you would see increase in temps while on the street with these lower profile fans but track temps should decrease. A lower temp thermostat can be used on a daily if you live in a place that doesnt get too cold or snows. It will just take car longer to warm up. Some say this can increase wear on engine. This is a different platform, but my buddy has a ls1 camaro with a 160 degree thermostat and it gets to roughly 140 degrees about the same as stock thermostat but then slows down from there due to the 160 opening sooner. Not sure about any aftermarket ducting to force more air through the radiator |
06-13-2019, 02:14 PM | #4 |
Member#: 476573
MAIC
Vehicle:2008 Impreza WRX STi Silver |
Don't bother with a cooler thermostat, all that does is change the temperature at which it opens. If you really think about it, how would that help when your temps are up over 200 since the thermostat is definitely open at that temp either way.
Anything you can do to force the air through the radiator instead of around it will help a good bit, I've been working on completely ducting in the radiator on my 1,000whp Corvette and it is slowly but surely bringing the temps down as I forced all of the air through the radiator and not around it. Google radiator ducting and there are plenty of examples to help you come up with a simple DIY solution. They don't need to perfectly seal to the bumper but they do need to seal to the face of the radiator so no cool air can sneak by. Oil cooler will definitely help keep temps down. Heat reflecting tape on the oil pan will help a bit as well. Hood vents also work great. I've run rivet-on hood vents on my corvette for years and they extract a ton of heat. The trick is getting them in the right position to function most efficiently. |
06-13-2019, 03:22 PM | #5 |
Member#: 253442
Thank you everyone. Just got a $250 visa gift card. Where can i spend this to get the most "Cooling" help. Radiator? Oil Cooler seems like there's a ton of issues that can potentially come along with it.
Was also looking into Hood vents? would that help with temps as well? |
06-13-2019, 07:15 PM | #6 |
Member#: 476573
MAIC
Yes hood vents do help but placing them in the correct locations is important. Check out this older thread where a couple guys tried a few different methods.
https://forums.nasioc.com/forums/sho....php?t=2803633 |
06-13-2019, 08:30 PM | #7 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
That_Boosted_Life hit your best first thing to do. Oil cooler. This should, of course be thermostatically controlled. Along with it, I'd run an oil temperature gauge so you can see where you are.
And I agree with Turpid Porpoise that a lower temp thermostat won't help as your thermostat should already be wide open. Bring more E85. This stuff has no energy, so the volume of it to make power is much more than 91 and that cools the charge. Run water with water wetter in the radiator. Water is more efficient at transferring heat than coolant is. Of course, if you are somewhere that it gets below freezing in the winter, remember to go back to anti freeze. I don't really think you're going to need more than that. If you're worried about coolant and when installed oil temp....turn on the heater. |
06-13-2019, 08:31 PM | #8 | |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
as for the raditator, yeah great idea, try to get the one with the most capacity. is this a straight race car or a street car that goes on the track? you can also look for stuff to cut out of the front of the car so more air moving in the front, you can also use water wetter and see if that helps Last edited by subaru_gc8; 06-13-2019 at 08:38 PM. |
06-13-2019, 10:14 PM | #9 | |
Member#: 253442
I'd rather avoid hacking up the bumper, don't mind the hood. Currently using stock TMIC. |
06-13-2019, 10:18 PM | #10 | |
Member#: 253442
The Oil Coolers are quite pricey. Could you point me to one that has everything i need and isn't braking the bank? I see a BUNCH of different versions, they all look the same to me. e85 - I'm bringing (2) 5 gallon jugs next time. I do think this will help tremendously. I was still hitting 210 easily while i was running pure e85. At our 3:00pm Session 100 degrees outside, i have 60/40 91 being the 60 and i hit the 225. I live in Sacramento, so it does get cold in the winter. SOMETIMES freezing. I would hate to have to change coolant all the time. It's so messy as it runs down the frame and gets over everything. |
06-14-2019, 06:28 AM | #11 |
Member#: 476573
MAIC
210-225 really isnt that hot to begin with. The boiling point of coolant with a 1 bar cap is 253* so you do have some headroom. That being said, cooling is always beneficial.
06-14-2019, 07:16 AM | #12 | |
Add Lightness
NESIC
I wouldn't be putting in hood vents because it's not reversible. If you decide in the future to run in time trials (or autocrosses), most rule books are going to cream you by bumping you way up in classes for body modifications. |
06-14-2019, 07:55 AM | #13 |
Member#: 476573
MAIC
Hes probably seeing the perrin kit priced at like $700, I've priced out putting together my own oil cooler kit and it comes out to roughly 55-65% of what Perrin charges.
06-14-2019, 10:24 AM | #14 | |
Member#: 253442
I think my first step to cooler temps should be a Koyo radiator and bringing e85 so i can avoid the 91 burn temps. I'm scared that the plastic reservoirs on the stock radiator will crack, had that happen to my built 06 wagon. I kind of like some of the vent look. I dont think i would be doing any competitive time trials or autocross. Really just out there to have fun. Buddy is trying to do another one July 13, we were out there June 12th. So far for maintenance I'm planning the following; -Possibly ordering a Koyo radiator -Oil change -Transmission fluid change -New brake fluid. (upgrading from stock fluid) -Some gloves as my hands got sweaty as **** in the heat. -Another 5 Gal jug to bring more e85. I'm getting some noise from the rear suspension now, sounds like spring bind or the sway bar which i installed not to long ago may be clunking. Sounds metallic and like what you would think spring bind sounds like a "Deap sounding Metallic TING mixed with a clunk". Any idea on possible culprits? ALso, my front brakes have started to squeal on 5%-20% brake force. Are they glazed from the track use? 80 grit sand paper fix noise issue? They were quiet leading up to the track. |
06-14-2019, 01:03 PM | #15 |
Member#: 251046
MAIC
Vehicle:2004 WRX Wagon Stage 5.1.2a.2 |
You're trying to solve a problem you don't have really. Had you had the correct fuel, this would have never happened. Unless you have a conservative 91 octane tune, you're gonna overheat at a track when you're pushing the car to the max for long duration.
After my experience with Mishimoto radiators, the only one I'll get is the high end Koyo if my stock unit can't keep up. The stock radiator with it's crimped on plastic end tanks, is superior to most aftermarket radiators when it comes to cooling. As someone mentioned above, you can easily piece together an oil cooler kit. It's not problematic unless your craftsmanship is poor. And I agree with a previous poster: whereas you take the load off the coolant when you're cooling your oil. It's a no brainer for a car going to the track. |
06-14-2019, 06:29 PM | #16 | |
Member#: 253442
I also don't know anything about oil coolers or where to start when sourcing correct parts.. |
06-15-2019, 04:16 PM | #17 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
We used to tow our boat with a 6-cylinder Jeep through the Rockies, going up some steep grades with 100 degree temps. Heater was -- painful but incredibly effective, as it is a ducted radiator.
06-17-2019, 08:57 AM | #18 | |
Member#: 253442
Currently tracking on Continental DWS's and i'll say, these things have held up great. I got put into the fast group with a GT3, Alfa Romeo (which was stupid fast) and i had no issue staying right on their asses. Later after our 4th lead/follow session, our instructor told us we were 1 of 2 fastest groups they've had this year which was pretty cool. I couldn't even imagine how much faster I could have pushed it with 265/35 summer tires. |
06-17-2019, 09:11 AM | #19 |
Add Lightness
NESIC
Don't focus on who you're grouped with. Focus on what the instructor is telling you and do that. I'll say with full confidence that your instructor could go out with a stock Miata and be running faster lap times than a n00b in a GT-3 RS. The line works, when you understand where it is and how to use it.
06-17-2019, 10:26 AM | #20 | |
Member#: 253442
Um, I’m not sure the impression I gave with that comment but I’m going to go ahead and say you took it the wrong way.... |
06-18-2019, 05:24 PM | #21 |
Member#: 408438
Simply doing a bigger rad isn't necessarily going to improve cooling by leaps and bounds. Research the impact of a thicker rad core in a stock location without any supporting mods for air flow. A lot of discussion in that link I shared in post #2.
Oil cooler would be best bang for your buck. Even if you just bought a core from summit racing, some hoses, an oil filter adapter from somewhere like Perrin, and figured out your own mounting solution. Point is, off load the stock radiator by cooling your oil first, especially if you're not going to do anything to help with radiator flow (like hood vents or a front splitter). |
06-18-2019, 06:26 PM | #22 | |
Member#: 475983
Vehicle:2018 WRX Limited Silver |
Water temp is hot but not excessive as stated above. If your running all out on 100 degree weather with those temps I think your fine with just proper servicing. Not sure if you mention oil temps? |
06-18-2019, 08:02 PM | #23 |
Member#: 99707
MWSOC
Vehicle:2018 WRX Premium CWP |
hell ill hit 217 just going to and from work on a hot day. Seems very controlled so far.
06-19-2019, 12:40 PM | #24 | |
Member#: 253442
I do want to do hood venting and ducting. However i don't know where to find, not home made, ducting. I see that theres 1 radiator cover that ducts and directs air into the engine bay, but its $270. That seems extremely steep. The Cobb radiator shroud looks like, but i'm not sure how much these "Standard" ones help. |
06-19-2019, 12:41 PM | #25 | |
Member#: 253442
Also, staying up on servicing. Going to change my oil. Do my first transmission fluid change (Motul 75w90) and rear diff (Motul 75w90 LS). Also, upgrading brake fluid. Anything else that i should be doing? next track day is July 13th. |
