Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Old 01-29-2019, 09:49 AM   #826
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Originally Posted by KillerBMotorsport View Post
We're shooting for 2 months.
Waiting to see what data we get back from this first.
The G-series is a new turbo. Check out the turbine and compressor maps for flow specs and comparative data. In short, the G-Series are a smaller turbo with improved flow capabilities. So at the same peak power numbers it will respond better. Or, at the same response RPM, it will make more power.
About an inch longer with the IWG.
Yes, this^ and see my comments above
Is this a bolt on change for existing spoolinator kits?
ShinjiML is offline   Reply With Quote
Old 01-29-2019, 11:03 AM   #827
subaru_gc8
Member#: 29292
2004 WRX wagon
Do you know if the regular vband g25 will fit your original kit?
Old 01-30-2019, 06:45 PM   #828
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
From the adapter side possibly... probably.
On the downpipe side, no. The G-series is a longer turbo.
I'm sorry... I meant if you compared original Spoolinator to the IWG G-Series here. EWG to EWG pretty good chance. See below.
Old 01-30-2019, 06:56 PM   #829
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Good question. The dimensions of the Tial And Garrett are off in relationship from inlet to outlet distances to each other. The v-bands themselves are VERY close and very well likely will be swappable. The biggest difference I see is that the height of the outlet is different by ~1/4". My gut feeling is that there is at least this much available wiggle room in the cat back to still get them to bolt up.
Old 01-30-2019, 09:22 PM   #830
subaru_gc8
Member#: 29292
2004 WRX wagon
So... we're on our own to see if it will fit
Old 01-31-2019, 08:45 AM   #831
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Only if you want an answer sooner than later. The car this will eventually go into will not be ready for a month or so.
Old 01-31-2019, 03:18 PM   #832
wrxhard
Member#: 108091
Is there more, less, or equal block clearancing with the g25?
wrxhard is offline   Reply With Quote
Old 02-02-2019, 12:05 PM   #833
Boxer112
Member#: 78751
2017 Sti
ISM
Subscribed for g25 info
Boxer112 is offline   Reply With Quote
Old 02-02-2019, 05:41 PM   #834
subaru_gc8
Member#: 29292
2004 WRX wagon
Cool deal thanks
Old 04-05-2019, 09:00 AM   #835
DrHeLpErZx
Member#: 216003
Any updates?
DrHeLpErZx is offline   Reply With Quote
Old 04-10-2019, 11:41 PM   #836
Jared M
Member#: 374045
Very interested in these developments as well.
Jared M is offline   Reply With Quote
Old 04-11-2019, 08:27 PM   #837
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I haven't even assembled my spoolinator setup and these guys are already sweating over something new being built. Have any of the people asking ran the spoolinator kit yet? Sheesh, it appears I'm not keeping up with the trends.
Old 04-12-2019, 08:14 AM   #838
eaglehunter
Member#: 216747
2009 STi
Dark Grey Metallic
I for one have been planning on purchasing a spoolinator kit for a while now but would like to know the results, pros cons etc of the new options first before deciding which one to buy for my needs...
eaglehunter is offline   Reply With Quote
Old 04-12-2019, 01:36 PM   #839
subaru_gc8
Member#: 29292
2004 WRX wagon
pros? stock location and the use of the tial turbine housing.
cons you have to grind away part of the block to get the compressor housing to fit.
I have the gtx 3067 on my 2.1 stroker, its great once you get past the 4000 mark. I am also using the .82 ar housing so that might have something to do with it. but yeah I honestly havent see anyone use like a atp gtx 3067 stock placement turbo to compare but yeah its good
if it were up to me, I would wait til the g25 660 comes in a kit
Old 04-12-2019, 02:38 PM   #840
eaglehunter
Member#: 216747
2009 STi
Dark Grey Metallic
Old 04-12-2019, 10:20 PM   #841
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Are we there yet?
Are we there yet?
No?
How about now?
Are we there yet?
Old 06-18-2019, 12:32 PM   #842
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Update
We'll have the turbo mounted and start testing after Wicked Big Meet in two weeks
Thanks for being patient!
The Dude
Old 06-18-2019, 01:44 PM   #843
eaglehunter
Member#: 216747
2009 STi
Dark Grey Metallic
The Dude
Excellent!
Old 06-22-2019, 07:35 PM   #844
Dinner123
Member#: 503482
2010 impreza
Default Looks god
Prerty decent if you ask me
Dinner123 is offline   Reply With Quote
Old 06-28-2019, 12:53 AM   #845
FASTERISBETTER
Member#: 224419
2005 WRX
I've been spending way too much time agonizing over Spoolinator vs rotated... Love the idea of the GTX3071 gen 2 running in the "stock" location minus the crappy turbine housing the factory setup uses. One question I haven't really seen an answer to is the fitment of the turbo inlets to this kit. A lot of the stock location turbos with 3" inlets kink the crap out of the inlet tube trying to get around the tgv bodies. Does this setup move the turbo over slightly and get a straighter shot under the manifold? The other question I have is EWG recirculation... Any reason you don't design these downpipes for recirculation?
FASTERISBETTER is offline   Reply With Quote
Old 06-28-2019, 06:53 PM   #846
subaru_gc8
Member#: 29292
2004 WRX wagon
its not the fitment of the inlet that is the problem its the amount you have to grind down to get the turbine housing to fit that is the question to be asked, if you want send me a pm and you can look at mine. in im HB
Old 06-28-2019, 09:08 PM   #847
FASTERISBETTER
Member#: 224419
2005 WRX
I'm not super concerned about the grinding part. There are enough points of contact between the engine and the trans and the factor of safety in that for any type of failure should be large. I'll send you a PM, I'd love to see a better angle of the inlet than I've been able to find.
A big selling point for a rotated setup is getting a smoother inlet, straight shot with no pinch points. The stock location turbos with 3" compressor inlets generally get badly pinched by the tgv which disrupts flow and loses power, not as much loss as the turbine housing but still not insignificant. Plus it's a b*$ch to put on. I'm wanting to know if the spoolinator setup either sets the turbo back slightly, shifts it towards the driver side(LHD) slightly or rotates it slightly so it isn't pointing straight at the tgv. More reason to use an aftermarket or jdm intake manifold with no tgvs I guess.
Old 06-28-2019, 09:13 PM   #848
FASTERISBETTER
Member#: 224419
2005 WRX
PM sent.
Old 06-28-2019, 09:35 PM   #849
NSFW
Member#: 140444
05 Stage Free LGT
Inlet position varies more than you think between different "stock location" turbochargers.
I have an ATP GT3076 with an APS 3 inch metal inlet pipe, and the edge of the turbo inlet is next to the TGV housing, but the flow path isn't bad. It's a tight fit, but everything does fit.
I've seen photos of turbo installs where the incoming air has to zig-zag drastically around the TGV housing on its way to the impeller, and the coupling between the turbo inlet and the inlet pipe gets horribly tortured. Those are the ones that gave stock location turbochargers such a bad reputation. Painful to install and sub-standard results.
The turbo centerlines look like they're a half-inch to the right of where ATP's exhaust housing puts their centerline. And maybe a half-inch forward as well, mashed right up against the TGV housing.
I have not seen photos showing the placement of the turbo inlets and the TGVs on any Spoolinator setups, so I'm curious too.
At some point I'm going to want to replace my GT3076 with a GTX30something.
Old 06-28-2019, 10:16 PM   #850
FASTERISBETTER
Member#: 224419
2005 WRX
Yup exactly. Some are really really bad to the point where people are grinding away at their TGV housings to get enough clearance to get it on at all and then it's kinked and barely has the clamp on it.
I know some are much better than others. But if the Spoolinator is a straighter shot it should be part of the marketing gimmick cuz really that's the only major downside to having the inlet under the intake manifold. The Spoolinator fixes the poor turbine housing problem so if it fixes the poor inlet angle problem then why bother going rotated.
