Welcome to the North American Subaru Impreza Owners Club Thursday October 17, 2019
Old 06-30-2019, 10:47 AM   #201
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
^^ Huh.. 1st especially on my 16' STI is very aggressively geared and very quick to pickup speed. I love it. The car is so easy to shift smoothly too since the pause between 1-2, 2-3 is basically identical at 3000rpm.
oichan is offline   Reply With Quote
Old 06-30-2019, 11:28 AM   #202
F1EA
Member#: 448622
2019 STI SportTech
CWP
STIs are easy to stall. Especially in reverse or if you often play around with the SI settings. But once you get used to it (or when tuned) it's second nature. Same w hill assist.
Also don't understand about 1-2nd gear. They are very aggressive. Super fun when you want to gun it. Not so fun when you're dealing w stop and go.
Speaking of gripes... i had a little rattle evident only on cold starts. Turns out it was the sunroof trim. I thought it was coming from behind, then thought it was the centre console... but all I had to do was press firmly against the sunroof trim and the rattle is gone and not come back. I'm 100% rattle-less now. Victory!
F1EA is online now   Reply With Quote
Old 06-30-2019, 04:03 PM   #203
JonnyD91
Member#: 250084
2019 STI
Pure red
Default 2019 WRX and STI gripes/complaints/rattles
I guess its subjective. My 2010 wrx had a way more aggressive 1/2. This car pulls harder in 3rd. Or maybe my **** is broken \_(ツ)_/
JonnyD91 is offline   Reply With Quote
Old 07-01-2019, 10:41 AM   #204
F1EA
Member#: 448622
2019 STI SportTech
CWP
Ah you're probably referring to turbo lag... the STI turbo spools slower than the WRX. So the initial "feel" is a bit slower. This is not because of gearing, but because of the turbo and the early torque delivery in the STI vs WRX.
Your stuff's not broken
Old 07-01-2019, 11:01 AM   #205
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
Hill assist has caused me to stall more than once. I am used to switching to the gas pedal very quickly and immediately slipping the clutch to hold on the hill. This does not work with hill assist. Need to very casually move from break to gas keeping the clutch all the way in. Then start as normal.
I wish the hill assist could be turned off with a switch. There are times I would like it but mostly I hate it.
MountainMan10 is offline   Reply With Quote
Old 07-02-2019, 01:53 PM   #206
SARdog07
Member#: 503836
2019 WRX Premium
Default Some gripes, but no regerts.
Stereo won't keep my saved presets where I put them.
Volume display is annoying... overlays the whole screen.
Apple Carplay only works when plugged into USB
Stock tires are garbage, uber loud.
Can't turn off DRL
SARdog07 is offline   Reply With Quote
Old 07-02-2019, 01:59 PM   #207
SARdog07
Member#: 503836
2019 WRX Premium
You can turn it off. with car on, shifter in Neutral, ebrake on, press and hold traction control button for 30 seconds (until traction control light turns off, takes FOREVER) within 5 seconds, press traction control button once, you will see the hill assist light turn on. Light on = disabled. Turn car off then start again... Hill assist light should stay on.
http://www.subarumanuals.org/subaru-3339.html
Old 07-02-2019, 05:31 PM   #208
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
'08 Mustang GT (the toy)
VDC is too intrusive.
So far I've lost all of the radio presets a couple of times, and once the screen returned to the default setting for no apparent reason.
Can't move everything I want to take off the touchscreen home page, off the home page. Don't want to see what I'm not going to use.
Brake pad 'bite' is too weak/soft, doesn't always give good confidence on harder stops.
Directional signal/4-way flash module is way too quiet. Gets drowned out by tire noise, having a window open, even by the radio at low volume.
Turns have to be unreasonably tight for the turn signal to self-cancel. Right-angle turns on neighborhood or city streets, sure. Gentle bends onto highway entrance or exit ramps, usually not.
Norm
Norm Peterson is offline   Reply With Quote
Old 07-02-2019, 05:39 PM   #209
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
There is a software update for the radio. Might fix the losing of radio presets.
Old 07-02-2019, 05:47 PM   #210
grafton
Member#: 187936
19 WRX & WRX STi
Got the Radio update on my wife's WRX she got it last fall, seemed to fix the issue, when I got my STi, same dealer now says "...SOA says the update doesn't fix it..." and wouldn't do the update.
grafton is offline   Reply With Quote
Old 07-02-2019, 05:54 PM   #211
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Wouldn't/shouldn't a December 2018 build have been late enough in the model year to have gotten that fix as a running production change?
Norm
Old 07-02-2019, 09:34 PM   #212
semtexs
Member#: 502176
2019 WRX
WR Blue
500 miles on my 19 wrx and already a rattle coming from the dash lmao
semtexs is offline   Reply With Quote
Old 07-02-2019, 09:40 PM   #213
lugz
Member#: 499923
2019 WRX
gray
Just one?
lugz is offline   Reply With Quote
Old 07-03-2019, 05:32 PM   #214
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Lucky duck, only one rattle...
Scorpius is offline   Reply With Quote
Old 07-04-2019, 04:32 PM   #215
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
See if it stops by pushing the cluster lens when it rattles. My STI did that early on and it was an easy fix.
Old 07-05-2019, 12:07 AM   #216
sub_1319
Member#: 503928
noticed a thud/thug when you put it in 1st gear. very noticeable. Doesnt happen all the time though. Had dealership checked it, they test drive it but according to the master mechanic Subaru transmission are indestructible. I doubt that. Not noticing it now a days since I dont pay attention to it anymore.
I find my 13'wrx faster and pulls harder than my 19' sti.
sub_1319 is offline   Reply With Quote
Old 07-05-2019, 12:16 PM   #217
xtremsiege2
Member#: 232721
2015 wrx premium
ICM
That can be changed with minimal investment..stage 1 it and you'll wake her up.
xtremsiege2 is offline   Reply With Quote
Old 07-05-2019, 12:38 PM   #218
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
Norm
Mine was an April 19 build and it still needed the update. I don't know any details about the update, other than mine needed it and it was newer than yours.
Old 07-05-2019, 12:41 PM   #219
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
Thanks for the info. Will give it a try today!
Old 07-05-2019, 01:25 PM   #220
F1EA
Member#: 448622
2019 STI SportTech
CWP
So do the 2015-2019 WRX. They FEEL faster up to 3,500 rpm or so.
But I felt the top end on an unmodified WRX....... unacceptable. After some modifications it was ok.
If custom tuned yes. If Stage 1 OTS, no. The OTS 1 makes it feel slower.
Old 07-05-2019, 02:00 PM   #221
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
.. or just get lighter wheels. The Prodrives can be had for cheap, ~20lbs, and they fit the car perfectly with no lowering.
My 19 WRX feels heavy vs my 16 STI due to gearing. If your 19 STI feels slower than my WRX, you're missing out A LOT!
Old 07-05-2019, 04:44 PM   #222
sub_1319
Member#: 503928
Car is still under warranty. Just thought it would be much faster since its an STI already. Both cars are stock.
Old 07-05-2019, 04:49 PM   #223
sub_1319
Member#: 503928
I have the 19 STI but prefer my 13 WRX. It pulls way harder even if its stock.
Old 07-05-2019, 05:00 PM   #224
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
So this is means it's a dealership reflash of some sort?
Norm
Old 07-05-2019, 05:08 PM   #225
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
Norm
Yes.
I had an issue where I got kicked out of the satellite radio and back to FM. The screen was not responsive. Selecting a different station with the dial unfroze the screen. It's not quite was you had happen, but it is not totally dissimilar either.
It happened to me 3 times on 3 different days, then never again. The dealer updated the software after it happened. Not sure if the update made any difference.
