12-28-2018, 01:12 AM | #8826 | |
Member#: 93750
MWSOC
12-28-2018, 02:37 AM | #8827 | ||
Member#: 73932
RMIC
Vehicle:2005 STi EFR 6758 04 S2000 EFR 7064 |
Is this for the Forester you picked up? |
12-28-2018, 06:05 AM | #8828 |
Member#: 220816
Vehicle:2018 Exotruck |
I for carberry I just increase cranking fuel 50% over the gas tables. Only time I have issues is when car sits and battery drops to 11ish volts and cranks too slow
12-28-2018, 06:49 AM | #8829 |
Member#: 272186
Vehicle:03 wrx csevo6 vf34 e85 salted peanut |
fuelab 818 6 micron
I've deleted the windscreen washer bottle as I never use it and replaced it with a 250ml 304 SS drink bottle that's BPA free....lol |
12-28-2018, 10:17 AM | #8830 |
Member#: 163648
MWSOC
Vehicle:2002 WRX V9 6mt R180 Brembos |
I like the washer fluid tank mod. Bought yourself some space.
12-28-2018, 12:17 PM | #8831 |
Member#: 272186
Thanks.
It was also one of a few weight saving mods. I keep around 50ml of water in their just in case the boys in blue pull me over and check my windscreen washers....lol Not that it would matter if they checked under the bonnet because the nanny state I live in only allows one intake tract mod. |
01-02-2019, 12:23 PM | #8832 |
Member#: 272186
OK. I feel like an idiot for posting about my fuel pressure drop.
Liquid filled turbosmart under bonnet gauge gets hot, pressure inside gauge increases and the gauge reading decreases. This is my 6 - 7 psi pressure drop. I only ever used this gauge twice tee'd on feed to check base pressure before, but never left it on there long enough to notice this. Didn't think to vent the gauge to reset it. My ignition on, fuel pump prime went from 29 psi to 43 psi today after venting. What fuel pressure senders are e85 compatible?......looking for an in cabin gauge that won't crap out a sender. Happy New Year! |
01-02-2019, 12:54 PM | #8833 | |
Member#: 220816
01-02-2019, 03:52 PM | #8834 |
Member#: 73932
RMIC
I don't understand how the masses likes to be regulated on every aspect of their life.
01-02-2019, 04:03 PM | #8835 |
Member#: 468117
SCIC
Vehicle:2017 WRX DMG |
awesome , thanks man.
01-03-2019, 12:19 PM | #8836 | |
Member#: 272186
Last time I checked in my state you couldn't even do an engine conversion anymore. I have an old Holden Gemini (4cyl isuzu) sitting in a paddock and a 13b sitting in the garage that i wanted to fit into it, but couldn't get it registered. |
01-03-2019, 12:30 PM | #8837 |
Member#: 395275
RMIC
Vehicle:2012 STi SWP |
heres mine. Fuel lab 6 micron fuel filter. I'm still running stock lines and had to improvise where to put a fuel filter
01-03-2019, 12:32 PM | #8838 |
Member#: 468117
SCIC
awesome, so you just cut your fuel line and clamp it onto a barbed fitting to an fitting to the fuel filter? what kinda clamp are those?
01-03-2019, 12:35 PM | #8839 |
Member#: 395275
RMIC
I am running stock fuel lines, ID1300s, Radium FPR and Cobb Flex fuel.
basically had to run a new line from the firewall to this filter, which uses -6AN on the end. I bought some -6AN to 5/8 hose barb from Summit Racing. 1 90 degree and 1 45 degree. Then I ran the hoses and clamped them using fuel clamps. |
01-03-2019, 12:37 PM | #8840 |
Member#: 395275
RMIC
My buddy and I made a "Custom" bracket out of some aluminum, and Silicone Intakes sells a bracket for fuel pumps that you can just bolt to a firewall if you wanted. so i used one of those. its solid as hell.
02-08-2019, 11:28 PM | #8841 |
Member#: 497530
Vehicle:2017 WRX Premium 6MT Pearl White |
This Threads Been Alive forever
Damn This Thread is old
02-26-2019, 04:10 AM | #8842 |
Member#: 179846
NWIC
Vehicle:07 STi Limited EFR 8474 TS EWG |
Haven't posted in ages but I'm currently working on 8 injector setup, I hated running at 12 afr on pump gas with id1700 and crap gas milage
04-03-2019, 07:22 AM | #8843 |
Member#: 220816
Just watched this video. While its not apples to apples, it shows MBT on gas and ethanol are about the same as far as ignition timing. Maybe even less timing on ethanol. The e85 advantage being that you can reach MBT in knock limited areas that you cant on gas, giving the illusion e85 "needs" more advance than gas.
04-05-2019, 08:32 AM | #8844 |
Member#: 220816
07-17-2019, 12:33 PM | #8845 |
Member#: 397954
MAIC
Vehicle:2015 STI Launch Ed. WRB |
2015 STI
Mods: -COBB Cold Air Intake -COBB EBCS -COBB Catted DP -Borla S Type Catback -IAG Street Series AOS -NGK One Step Colder Spark Plugs -AEM 320 Fuel Pump -ID 1050X Injectors -COBB Flex Fuel Kit -COBB Fuel Pressure Sensor -COBB Fuel Pressure Regulator Majority installed and tuned by TPG Tuning. Mustang Dyno: 315WHP and 351WTQ on e70 blend 295WHP and 310WTQ on 93 Tuned at 19.5 PSI. I've had the tune done for about 6 weeks now. I've exclusively filled up with e85 with the exception of one tank on a longer drive where I couldn't find any. I average E73-76 most of the time from one gas station that is close by me. Personally I think the car pulls great, love it. That corn is addictive for sure especially compared to the noticeable difference from filling up once on 93. My question for you guys is do you think my numbers look a bit low? I mean like I said, I think the car pulls pretty strong especially compared to the Stage 1+ OTS Map I was running up until my protune, but compared to a lot of other numbers I've seen on this page they seem a bit low. Just curious what you guys thought. Thanks! |
07-17-2019, 12:59 PM | #8846 |
Member#: 395275
RMIC
those numbers are solid for that setup. especially on a mustang dyno
Remember the numbers themselves don't mean much, unless you baselined here Most stock STi's baseline around 200 whp on a mustang dyno. so you have gained 115 whp over a stock setup a stock STi will dyno 220 to 240 whp on a dynojet, so take the numbers from other with a grain of salt |
07-17-2019, 01:24 PM | #8847 | |
Member#: 397954
MAIC
07-17-2019, 06:28 PM | #8848 | |
Member#: 220816
07-18-2019, 12:30 PM | #8849 |
Member#: 397954
MAIC
07-18-2019, 01:16 PM | #8850 |
Member#: 220816
ya and it could actually go up a bit as you get closer to e85 in the tank (probably never get higher than e80 though from pump). Flex fuel tunes are a blend of two maps. at e70, the volumns only up like 85%
Similar Threads | ||||
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
