Welcome to the North American Subaru Impreza Owners Club Wednesday December 11, 2019
Old 07-27-2019, 07:17 PM   #11801
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Originally Posted by gm4classic207v9 View Post
Great info, I'll up ECT to 220, OILT to 240, and OILP up from 5 to about 20, I've not seen it drop that low, but I'll keep my eyes on it, thank you!
Fyi those settings were from the track
If you hit any of those on the street I would be amazed
Temps are normally like 190-205 for Oil and 180-200 for coolant for me on the street
Gigs90 is offline   Reply With Quote
Old 07-29-2019, 01:59 AM   #11802
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Found out some decent enough info for now.
ECT shouldnt be over 250, 180 to 230 preferred.
OILT, with my setup and oil choice, should be no higher than 350. 200 to 250 preferred.
Set both of those warnings to 210 and will call it good.
OILP shouldnt be less than 5.
Alarms set!
What are you concerned about? Daily driving or track days?
Old 07-30-2019, 01:56 PM   #11803
gm4classic207v9
Member#: 504582
1996 Impreza
White, black, and red
Thanks for the assistance.
Yeah, daily driving profile and autox profile.
We live in Seattle area and it's been hot lately. Got really nervous when I mistakenly got caught in traffic.
gm4classic207v9 is offline   Reply With Quote
Old 07-30-2019, 02:22 PM   #11804
Fierysun
Member#: 82745
2005 Subaru STI
Keep an eye on your oil pressure, especially on super hot days. If it drops to around 25psi or lower at idle and below 65psi-ish at speed. Take it super easy until you get home and let the engine cool off with the hood open. You do this by turning the ignition key to the on position after shut off (but don't restart the engine), the fans should turn back on. Let the fans run until it turns off, remove the key, and close the hood.
Old 07-30-2019, 05:04 PM   #11805
oren
Member#: 31193
2003 WRX Wagon
You mean hot for Seattle... it's still not much.
oren is offline   Reply With Quote
Old 07-31-2019, 05:17 PM   #11806
gm4classic207v9
Member#: 504582
1996 Impreza
Sounds good, thank you very much!
Old 08-05-2019, 06:51 PM   #11807
sdh7711
Member#: 150593
2004 Impreza WRX
JDM V7 Sti
Default What to do
So I have an EJ207 V7 dropped into my 04 WRX with the JDM 6 speed and R180 rear differential, 4 pot 2 pots for brakes with the sti axles and knuckles on the rear.
Was on the throttle good heading up the Route 2 WB hill out here and bam lost power started blowing white smoke out the rear. Towed it over to the mechanic and will do compression test tomorrow but its burning oil and he thinks I may not be getting compression on one or two cylinders the way it sounds when cranking.
Tryinging to weigh my options right now. Continue trouble shooting the block or just weigh options of dropping in another V7 or V9? Thoughts suggestions would be appreciated.
sdh7711 is offline   Reply With Quote
Old 08-05-2019, 07:03 PM   #11808
suprabats
Member#: 357908
How much boost were you hitting and what turbo? I'd figure out why you blew it before you drop another engine in or you'll be right back where you started.
suprabats is offline   Reply With Quote
Old 08-05-2019, 07:13 PM   #11809
sdh7711
Member#: 150593
2004 Impreza WRX
JDM V7 Sti
The stock turbo that came with the V7. The VF34. Boost was setup for peak of 21psi, with a dump at 25 if it ever over boosted.
Wicked Performance up in NH did the swap and tune when it went in originally back in 2014
Old 08-06-2019, 01:06 PM   #11810
sdh7711
Member#: 150593
2004 Impreza WRX
JDM V7 Sti
Default Mechanic update
So the turbo blew on my v7. Oil all in the ic etc. Compression test shows 0 psi in cylinder 3. 145 to 150 on all others. So looks like I am into a rebuild. Had already gotten a dom 1.5 with fuel lines and rails a 3 inch inlet and new upipe as well as ID 1000s for a planned upgrade. Might as well salvage all this planned effort. Any advice appreicated on those that had rebuilt their v7.
Old 08-06-2019, 01:11 PM   #11811
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Source a new bottom end from Australia
Old 08-07-2019, 12:09 PM   #11812
my name is joe
Member#: 171412
Does anyone know if the killer B oil pan would clear the twin scroll manifold?
my name is joe is offline   Reply With Quote
Old 08-07-2019, 12:13 PM   #11813
oren
Member#: 31193
2003 WRX Wagon
It does. I found more info here and there and got some from Killer B as well. I had the oil pan installed last month on my V9. You may have to trim some heat shielding.
Old 08-07-2019, 12:29 PM   #11814
my name is joe
Member#: 171412
Thank you for replying so quickly! I'm currently using a 2.5l pan and figured it would work. I'm not too worried about heat shielding. I was thinking about removing and changing it to BMW/Porsche waffle type anyway.
Old 08-07-2019, 01:08 PM   #11815
oren
Member#: 31193
2003 WRX Wagon
EJ207 already has what they call a 2.5L pan making it more confusing when doing the research.
Old 08-07-2019, 01:34 PM   #11816
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
2.5 pan and twin scroll should almost be the same pan. Now the killer b is designed on that same idea.
Old 08-07-2019, 06:04 PM   #11817
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Its the same part number for the Twinscroll pan and the EJ257 pan , But that being said I would not put any Killer B part anywhere near my car.
Old 08-13-2019, 06:15 PM   #11818
mephistomarius
Member#: 330895
2002 Impreza wrx
blaze yellow
From my experience the answer is...kinda. I had to take my dremel and cut out a bit of flange out of the factory header heatshield to clear the version 1 style pan.
mephistomarius is offline   Reply With Quote
Old 08-20-2019, 02:43 PM   #11819
grangepack2
Member#: 428757
1994 Impreza v9 207
Default V8 vs v9 cylinder heads
Guys. I need some help.
I need to know if the ej207 V8 cylinder heads are identical to V9 ej207 heads.
Thanks in advance.
grangepack2 is offline   Reply With Quote
Old 08-20-2019, 03:29 PM   #11820
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
yes they are
Hyper is offline   Reply With Quote
Old 08-20-2019, 04:15 PM   #11821
Bansheeboy11
Member#: 182415
1999 RS
It should clear the factory manifold, i can fit my hand between the pan and my tomei manifold
https://i.imgur.com/SYm5Eq4.jpg?1
Bansheeboy11 is online now   Reply With Quote
Old 08-21-2019, 10:41 AM   #11822
breadandbutter
Member#: 398488
Do v9 e
breadandbutter is offline   Reply With Quote
Old 08-29-2019, 07:11 AM   #11823
grangepack2
Member#: 428757
1994 Impreza v9 207
Originally Posted by Hyper View Post
yes they are
other forums are claiming the v9 had slightly better cams.
Internet myth?
Old 08-29-2019, 10:02 AM   #11824
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
Internet myth?
Internet Myth, they are the same.
Jeff Sponaugle once posted the JDM Subaru part numbers that proved that the cams were the same. Ill see if I can find it.
This isnt Jeffs post, but this has corresponding information. https://forums.nasioc.com/forums/sho...6#post10671156
This post from Vlad shows what the lift is
https://forums.nasioc.com/forums/sho...96&postcount=3
86Dreams is offline   Reply With Quote
Old 08-30-2019, 02:11 AM   #11825
subaru_gc8
Member#: 29292
2004 WRX wagon
Thanks in advance.
pretty much, they both use the t20 castings
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
