Welcome to the North American Subaru Impreza Owners Club Wednesday August 21, 2019
Old 08-07-2019, 01:13 PM   #26
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
pearson222 is offline   Reply With Quote
Old 08-07-2019, 01:13 PM   #27
Waddlz
Member#: 395275
2012 STi
Originally Posted by pearson222 View Post
Since the hole lines up with the rear exhaust cam lobe - the only thing that I can think of is that something was loose inside the valve cover and eventually got pinched by the cam lobe and forced out the side of the casing. That would at least explain my FBK/FKL anomalies.
interesting.
well keep us up to date when you take it back out. I'm curious what you find
Waddlz is offline   Reply With Quote
Old 08-07-2019, 01:15 PM   #28
motorbykemike
Member#: 273868
wow , that sucks !
been lurking here on this thread since the beginning and wondering
I have a single b25 rh head if you need
pm me
motorbykemike is offline   Reply With Quote
Old 08-07-2019, 01:17 PM   #29
motorbykemike
Member#: 273868
that all makes sense
FOD foreign object debris
Old 08-07-2019, 01:23 PM   #30
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
Appreciated. Pm incoming
Old 08-07-2019, 01:23 PM   #31
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
I will get it on stands and pull the valve cover and inspect the cams and buckets for wear/damage. I can see a crack also that will need to be investigated. If the clearances and everything look healthy and the hole is small enough, I am honestly considering throwing some JBWeld in the hole and seeing if it will hold haha. I hate this f'n car.
Old 08-07-2019, 01:25 PM   #32
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
It would be like having a 3rd half moon!
Old 08-07-2019, 01:30 PM   #33
Waddlz
Member#: 395275
2012 STi
Jbweld that sumbitch
Old 08-07-2019, 01:34 PM   #34
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
Seriously - if the structural integrity of the casing isn't compromised and their arent huge cracks in addition to the hole, I don't see any downside to giving it a try.
Old 08-07-2019, 01:38 PM   #35
Waddlz
Member#: 395275
2012 STi
I once cracked the CHRA on my EFR6758 when i cross threaded the coolant bolt. it crumbled and fell apart.
I had 3 threads left, so I carefully threaded the M14x1.5 to 6AN fitting in there and high temp JB welded around it.
It held for years until the dude I sold it to blew the turbo up by not giving it enough oil.
Old 08-07-2019, 01:51 PM   #36
motorbykemike
Member#: 273868
or just get it welded
Old 08-09-2019, 10:12 PM   #37
1stinlastout
Member#: 504461
Try that aluminum brazing rod.
1stinlastout is offline   Reply With Quote
Old 08-09-2019, 11:49 PM   #38
subaru_gc8
Member#: 29292
2004 WRX wagon
my buddy tried that and he said it didnt work for him, so he gave it to me but I havnt had a chance to try it yet.. kinda looks too good to be trure though
Old 08-14-2019, 12:09 AM   #39
stu
Member#: 25768
2003 2.34 Long-Rod
SL performance, Slowbaru
Did they at least tell you your ptwc, and ring gaps? This sounds like the issue to me
stu is offline   Reply With Quote
