#1 |
Member#: 485226
![]() So I threw a rod on cylinder 2 recently commuting to work one morning. It’s a 2018 with approximately 11k miles with a moderate spirited driving history. Oil changes done every 2,500 miles with Motul 8100 X Clean.
Modified for nearly 8k miles with no issues. Mod list includes: Perrin Intake Perrin Motor Mounts Perrin Header MAP 3” J Pipe w/ HFC MAP Exhaust w/ Muffler Deletes Perrin Trans Mount Cobb AP Perrin Strut Tower Brace Cruising to work doing 55MPH when all of a sudden I heard a loud tapping noise coming from my engine bay. No visible leaking of oil. Had it towed to PRO COM Racing in Toms River New Jersey for inspection and confirmed diagnosis. A timing chain inspection initially was performed. Next a compression test which failed miserably. On not only cylinder 2 but cylinder 4. Upon opening up motor they found the culprit a thrown rod on cylinder #2. Timeline for build is 3-4 weeks which includes break in period. Build will be capable to holding 500HP. Engine build is as follows: -New OEM FA20 Case Valves -Manley Platinum Series 86mm Forged Pistons -Manley H Tuff Connecting Rods -ARP Rod Bolts -King Rod / Main Bearings -New OEM FA20 Crankshaft -ProCom Proprietary Block Strengthening and Oiling System Modifications -Motul 300v 5w40 Syn Oil -ARP2000 Head Stud Kit -OEM Engine Seal Kit -OEM Oil Cooler -OEM Oil Pump -OEM Timing Chains -OEM Guides / Tensioners -OEM Water Pump -OEM Thermostat -AOS Separator -Perrin Front Mount Intercooler -Perrin Boost Controller -NGK 1 Step Colder Plugs -EGR Delete -TGV Delete -Big Oil Filter Kit -Machined Cylinder Heads Resurfaced, Valve Seal Replacement, Valve Lash Adjustment, Clean / Sonic Blast of Cylinder Heads Upon completion of engine build there will be another compression test, 1k miles break in period and a full Mustang Dyno Tune. ENGINE COST BREAKDOWN: ![]() *Engine will have a full warranty* There is no additional charge for any additional parts I wish to add on during the build. Such as a FMIC, TIP etc. https://www.procomracing.com
#2 | |
Member#: 485226
![]() Quote:
I will posts pics and updates as the build goes on. Thanks |
#3 |
Member#: 448185
Vehicle:2016 WRX DGM |
![]() I'd say modified for 8k with no issues is wrong if the engine blew haha
That's going to be a pretty sweet build, but it sucks that you now just eclipsed STi pricing for your low mileage car. |
#4 | |
Member#: 485226
![]() Quote:
Yea totally. I sick to my stomach but excited at the same time. When I initially threw the rod driving I said “That can’t be my car” sounded like a baseball card on a bicycle spoke flicking. Epic fail ![]() |
#5 |
Member#: 477489
Vehicle:2018 WRX Limited CWP |
![]() Yikes, sorry to hear that man.
What tune were you running? And what did the shop quote you for the build? |
#6 | |
Member#: 485226
![]() Quote:
Thanks. Cobb Stage 2+ OTS Map Engine Tear Down 714.00 ProCom Racing Short Block 3,499.99 Engine Fit Up Package 1,849.99 Machine Cylinder Heads 525.00 Engine Assembly 1,968.75 Engine Removal / Install 880.00 Engine Break-In 399.99 Dyno Tune 600.00 |
#7 | |
Member#: 447898
BAIC
Vehicle:2016 WRX (traded) 2019 STI CWP |
![]() Sorry to hear about your loss. At least you'll have to worry about the block a bit less now. Just make sure that you have a quality tune for your parts.
You had a Cobb Stage 2+ OTS map with this mod list? Quote:
We all make mistakes and learn from them.. that was just a very expensive $10k lesson. At least you're willing to admit it. Most people would make excuses, blame Subaru, and try to commit warranty fraud in hopes that Subaru would cover it. Last edited by WRXnick16; 08-21-2019 at 06:46 PM. |
#8 |
Member#: 477489
![]() Good luck with your build. Please post updates of your build, hopefully you have some interesting updates as it progresses. Will be following this thread.
#9 |
Member#: 477489
![]() This ^. Thanks for posting and sharing the experience so others can learn.
#10 |
Member#: 473848
W. Canada
Vehicle:2015 Wrx White |
![]() OTS map???Really? Were you trying to blow it up?
#11 | |
Member#: 460907
RMIC
Vehicle:2016 WRX |
![]() Quote:
No blaming Cobb, no trying to blame a shop, no trying to pawn this off on Subaru to fix. Respect to OP for handling this like it should be. |
#12 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
![]() That price breakdown isn't that bad considering, but you are gonna need a new clutch too.
#13 |
Member#: 447898
BAIC
![]() Since you're in New Jersey, maybe reach out to Prime Motoring for a quote to do a FA24DIT swap
![]() https://forums.nasioc.com/forums/sho....php?t=2907007 |
#14 | |
Member#: 485226
![]() Quote:
I for sure made the mistake of thinking “it can happen to me”. As time went on mileage wise I felt more assured I was bullet proof. And for 8k miles I was. Had a lot of fun along the way lol ![]() Appreciate the comment. At the end of the day there is no one to blame but myself. |
#15 |
Member#: 485226
#16 |
Member#: 485226
#17 |
Member#: 485226
![]() Not at all. Ran it for so long like this it became normal for me. Didn’t even think about throwing a rod or spinning a bearing. Just turned the key and drove. With all the information on this site I should have known better. You live and learn. And I certainly did. My first Subaru too ![]() |
#18 | |
Member#: 485226
![]() Quote:
No data logs however starting getting enormous feedback knock and fine knock learning before my incident. The racing shop stated the spark plugs were toasted. Compression test failed on multiple cylinders. I’m thinking more of a detonation issue. Creating too much pressure in the crankcase. Leading to failure. |
#19 |
Member#: 485226
#20 | |
Member#: 460907
RMIC
Vehicle:2016 WRX |
![]() Quote:
#21 | |
Member#: 485226
![]() Quote:
I was getting knock at both WOT and cruising speeds. Before it gave 12.xxx knock. No feeling of lost power. Lots of backfire from exhaust. My AFR were bouncing around cruising prior as well. |
#22 |
Member#: 460907
RMIC
Vehicle:2016 WRX |
![]() Were you consistently monitoring during the entire time it was tuned? Like did these numbers just start to appear from looking otherwise healthy, or did you just start monitoring when you suspected an issue?
#23 | |
Member#: 485226
![]() Quote:
I always had my AP plugged in monitoring live data. Occasionally would get knock. But never that high. And my AFR would jump up from 14.7 ish while cruising to 17 ish. Which isn’t good. Under full throttle AFR were spot on. Only when cruising did I experience the AFR bouncing lean. My DAM was always 1.0. Temperatures for oil and coolant were spot on. Boost PSI was normal as well. No difficulty starting. No erratic idling. |
#24 | |
Member#: 485226
![]() Quote:
Maybe next time around ![]() |
#25 |
Member#: 447898
BAIC
![]() You won't need a new clutch with your low mileage and power levels. Obviously you'll need to look for an upgrade if you go with a larger turbo and start pushing higher power levels later on. It really just depends on your plans for the car and if you would rather replace it now while the engine is out or wait and pay the labor cost again down the road.
