Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 08-20-2019, 12:44 AM   #51
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
New brake line
I actually ended up flipping the brake line since it kinked funny the way it was
Take a break to install the new tensioner and idler that came in. Tensioner didn’t say Subaru on it and instead had a Bando label. It was made in Japan so I’m okay with it but I did laugh at the Chinese knock off where the just shaved away the engravings on their product.
Old 08-20-2019, 12:45 AM   #52
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
Installed for a second time
Old 08-20-2019, 12:45 AM   #53
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
Ordered in a new PCV at the same time
After that was done start on the passenger side stuff. This time it’s easier since I didn’t the wheel bearing.
Old 08-20-2019, 12:46 AM   #54
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
This was sufficient enough to release the tension
Had to grease it up again. Maybe because the new rubber was sticky?
The reason I have more struts than necessary is I put some “drop in” struts in a pinch a few years back. I had the OEM ones sitting around. The springs on the drop in units were alright but very hard. Notice the quantity of coils between the 2 units. To give the same ride height the cheap ones have to be harder (bigger k factor).
Old 08-20-2019, 12:46 AM   #55
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
Broken tie rod boot
New one installed
This side all done with new brake line
Old 08-20-2019, 12:47 AM   #56
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
One of our front parking sensors took a rock into it on the highway. I figured now was the time to change it. Plus having the bumper off gave me more room to work with and less worry about “leaning” on it
Old 08-20-2019, 12:47 AM   #57
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
The sideskirt was also a bit loose on the front. It turns out the closest clip had come out and started to “fold” over. I stuck a pair of pliers in there over night and it was enough to keep it straight until the clip got pushed in.
Most of my clips on the underside were missing. I ordered new ones
I sprayed over this part to hopefully keep some rust away
Bleed the brakes and drop the car down
Old 08-20-2019, 12:50 AM   #58
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
Tighten the axle nut and let it run on it’s 4 wheels for the first time
Hose off any bits
…and done
Can you tell I like wagons???? S4 is the 6 speed manual (the wife prefers the Subaru)
Old 08-23-2019, 08:43 PM   #59
Boxcar80
Member#: 491471
2009 Impreza
Just curious, what was the cause of the sticky brake caliper, the pistons or the pins?
Boxcar80 is offline   Reply With Quote
Old 08-26-2019, 11:59 PM   #60
99 rs
Member#: 100994
2005 Acura NSX-T
2002 IS300 Wagon
It was definitely the slide pin. I could still see the pistons try to move but the pin (singular) was seized solid. I returned them for a core charge.
