Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2019
Old 08-31-2019, 06:08 PM   #1
Alex.Ter
Member#: 494915
2008 Wrx
Default V3 not connecting
Ok I really need some input on this issue I have, I'm very sorry if I posted this somehow wrong, I'm new here. So I bought a ap from Ebay, installed it and installed tunes on it, and it worked perfectly fine, then this year at around January in Spokane it was very cold freezing temps at night, and then in the morning I go to my car and my ap isnt connecting, It gets power, but when I press on gauges it just stays on the verify ignition is in the on position, and yes I did verify. And i can't change any tunes right now, and cant get a protune. So I contacted cobb, sent them my ecu, ap, and cord, they said buy a new cord, I did still same issue, then they said to check out the obd2 port pins, I had a new obd2 port wired In, still same issue, at this point I'm very annoyed of this, so I tried with a multi meter checking the pins from obd2 port to the pins that go to the ecu, the grounds, and all the other pins checked out perfectly fine, and yet the ap doesnt connect, I tried connecting a code scanner also and it works! Wtf!?!? And this is why I'm really confused, because a scanner works but the ap doesnt, I have absolutely no clue what I can try or do now to try and fix this issue, so I decided to turn to you guys if you guys have any ideas of what I could check. I also checked the ignition switch with a multimeter and works fine, I'm thinking its something with the ignition switch wires if only I could figure out what pin the ap uses to verify that the ignition switch is on, but cobb wouldn't tell me that. Really any help would be amazing!
Alex.Ter is offline   Reply With Quote
Old 08-31-2019, 08:49 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
was it new? if so talk to Cobb
Old 09-01-2019, 03:16 AM   #3
Alex.Ter
Member#: 494915
2008 Wrx
No I bought the accessport from ebay, and I have sent the ecu, the ap, and the cord to cobb and they checked it all out and said that the problem is with my car
Old 09-01-2019, 01:51 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
maybe try to unmarry it and remarry it and see what happens
Old 09-01-2019, 04:37 PM   #5
Alex.Ter
Member#: 494915
2008 Wrx
I cant connect the ap to my ECU so I cant unmarry it, it gets power but when i click gauges or try to read codes, it goes to the verify your ignition is in the one position and that's it.
Old 09-01-2019, 07:16 PM   #6
ifearnoevo
Member#: 475635
2016 WRX STI
Wrb
Have you tried a different cable from the obd port to the accessport? Maybe it has a short in it?
ifearnoevo is offline   Reply With Quote
Old 09-01-2019, 07:18 PM   #7
ifearnoevo
Member#: 475635
2016 WRX STI
Wrb
[quote=ifearnoevo;46113794] maybe there is a short in the ignition wiring? Enough for the obd2 port to not read the correct voltage maybe
Old 09-02-2019, 03:13 PM   #8
Alex.Ter
Member#: 494915
2008 Wrx
[quote=ifearnoevo;46113796]
How would I check that? And I have my dash off currently and theres a bunch of wires that come from the ignition Idk which one to check, also would that result in my car not starting?
Old 09-02-2019, 03:14 PM   #9
Alex.Ter
Member#: 494915
2008 Wrx
I sent my cord with my ap and my ECU to cobb, they checked everything and it's all fine.
Old 09-02-2019, 11:58 PM   #10
ifearnoevo
Member#: 475635
2016 WRX STI
Wrb
[quote=Alex.Ter;46114260]
Maybe. Is it cranking but not starting? Or is it not even trying?
Old 09-03-2019, 02:38 PM   #11
Alex.Ter
Member#: 494915
2008 Wrx
[quote=ifearnoevo;46114534]
The car starts and drives perfectly fine. That's why I doubt it's something with the ignition cables
Old 09-03-2019, 11:13 PM   #12
ifearnoevo
Member#: 475635
2016 WRX STI
Wrb
[quote=Alex.Ter;46115009]
Yeah I'm with you on that one. Hmm hopefully someone with more knowledge than me will chime in. I hope you get it straightened out though.
Old 09-03-2019, 11:49 PM   #13
Alex.Ter
Member#: 494915
2008 Wrx
[quote=ifearnoevo;46115511]
Yea hopefully, I'm pretty done with it at this point, I really dont want to send it to a shop and spend a ton of money for then to find the issue, but at this point looks like thats my only option
Old 09-20-2019, 02:04 AM   #14
Alex.Ter
Member#: 494915
2008 Wrx
So I think I might have figured it out, couple months ago my car started dying after it got up to temp, I replaced a bunch of stuff, and then also put in a new battery because I realized that my battery was very old and almost dead. And after that I never tried to connect my accessport again. I'm thinking my accessport wasnt connecting because of a bad battery, and that might explain why it stopped connecting after a very cold night. So I'm putting my car back together, hopefully tomorrow I will try to get it running and try to connect the ap. I'm really really hoping that, that's the issue!
Old 09-20-2019, 05:45 AM   #15
wiggleharris
Member#: 505974
Did you try a different cable from the Obd port?
wiggleharris is offline   Reply With Quote
Old 09-20-2019, 11:15 AM   #16
Alex.Ter
Member#: 494915
2008 Wrx
Yes, the first time I sent my cobb accessport to cobb they sent me a new cable, that still didnt work, and when I sent my accesport to cobb again with my ecu, they said the cable is working fine, so is the ecu and accessport.
