Welcome to the North American Subaru Impreza Owners Club Friday September 18, 2020
Old 04-18-2019, 11:53 AM   #51
CursezZz
Member#: 414974
2006 Subaru WRX STi
Obsidian Black Pearl
Originally Posted by 1VIPWRX View Post
where did you put the small coolant tank that was on the intake manifold?
in the trash lol i deleted it. my turbo is oil cooled only and when it broke on me i just sent the line from the block directly into the turbo coolant feed and was goldennnnnnn
CursezZz is offline   Reply With Quote
Old 04-22-2019, 09:55 AM   #52
2000SubaruImpreza
Member#: 499227
2000 Impreza
Blue Ridge Pearl
Love that body style, wish they still made this type of body nowadays. I feel like a lot of cars are starting to look way to similar.
2000SubaruImpreza is offline   Reply With Quote
Old 04-22-2019, 03:32 PM   #53
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Good Looking Build! Cant Wait To See What It Will Run Now.
robbieshonda is offline   Reply With Quote
Old 04-23-2019, 09:43 AM   #54
CursezZz
Member#: 414974
2006 Subaru WRX STi
you and me both!!!!
Old 05-20-2019, 12:53 PM   #55
CursezZz
Member#: 414974
2006 Subaru WRX STi
with Ocean City Cruisin Week coming up i decided to do a small paint correction. this would be the first time i did this completely on my own with just some guidance from friends lol i did the old reliable Meguiars 105 and 205 Compound and Polish. and finished it off with some Sonax Profiline sealant.
and just my luck as soon as i finish up......it rains!! but thats ok it allowed for some gratuitous water beading photos!
After they sat around for sometime mainly because i was dreading that the lateral link bolts would seize in the bushing sleeves (which they did) thanks for carnz-pj-410 for breaking em loose! (something his 3/4" impact couldnt do) i got the DSS 800HP rear axles in!
Old 05-20-2019, 01:04 PM   #56
CursezZz
Member#: 414974
2006 Subaru WRX STi
here are a few cellphone shots of my time at OCMD, i didnt take nearly enough photos lol
Fueling up for the trip down!
https://i.imgur.com/l9wROyr.jpg
The stable of jalopys!
the path leading to the house is a great place for pics!
Carnz-PJ-410 and i needed some corn refills!
a quick shot from breakfast the last day there sans a Mustang and one broken swapped coupe lol
Old 05-28-2019, 11:29 AM   #57
96accord
Member#: 145105
2015 Honda Accord
Originally Posted by CursezZz View Post
After they sat around for sometime mainly because i was dreading that the lateral link bolts would seize in the bushing sleeves (which they did) thanks for carnz-pj-410 for breaking em loose! (something his 3/4" impact couldnt do) i got the DSS 80HP rear axles in!
I hope they handle more than 80hp!
Old 05-30-2019, 10:49 AM   #58
CursezZz
Member#: 414974
2006 Subaru WRX STi
solid catch!
Old 06-06-2019, 11:00 AM   #59
CursezZz
Member#: 414974
2006 Subaru WRX STi
finally got to go to the track on the new setup!!!!!
Did what i wanted to the first time out, i beat my previous 12.4 time on the first run too!
This was my best for the night (only got 3 runs in) Next time will be much better i finally kinda got the launch dialed in and upped my flat foot shifting from 5800rpm (like an idiot) to 7300rpm and there is no drop off between shifts! hoping for a much lower 11 sec pass next time out!
Old 06-06-2019, 01:32 PM   #60
96accord
Member#: 145105
2015 Honda Accord
<Here for videos>
Old 06-06-2019, 01:45 PM   #61
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
<Here for the gangbang>
Turpid Porpoise is offline   Reply With Quote
Old 06-06-2019, 01:50 PM   #62
96accord
Member#: 145105
2015 Honda Accord
Originally Posted by Turpid Porpoise View Post
Whoa. You might be here for that but I'll pass. CursezZz isn't my type
Old 06-07-2019, 01:08 AM   #63
MGigantelli44
Member#: 234591
2004 STI
At what RPM do you shift? I have been trying different things to dial in my flat-foot. Best pass it was set to 6700 and I shift at 74-7500.
Fun thread to just read through. Nice car
MGigantelli44 is offline   Reply With Quote
Old 06-10-2019, 07:16 AM   #64
CursezZz
Member#: 414974
2006 Subaru WRX STi
thanks! i shift at 7500rpm, my new FFS setup is 7300rpm. feels like a completely different car!
Old 09-11-2019, 08:52 AM   #65
96accord
Member#: 145105
2015 Honda Accord
Bump.
Have you beat your 11.754 1/4 mile time yet?
Old 09-25-2019, 09:10 AM   #66
CursezZz
Member#: 414974
2006 Subaru WRX STi
Bump.
not yet poop faceeeeeee. hopefully once this leaning out issue is resolved (this weeked) ill hit the track!!
Old 09-25-2019, 12:59 PM   #67
96accord
Member#: 145105
2015 Honda Accord
Glad you finally replied.
Keep us updated on the track! I want to go
Old 10-02-2019, 07:27 AM   #68
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Very tidy setup!
CEEBEE is offline   Reply With Quote
Old 10-02-2019, 12:50 PM   #69
CursezZz
Member#: 414974
2006 Subaru WRX STi
Originally Posted by CEEBEE View Post
Very tidy setup!
Thank you! i appreciate that! it could always be better though!
Old 10-25-2019, 10:28 AM   #70
CursezZz
Member#: 414974
2006 Subaru WRX STi
UPDATE!
i was having some issues where the car was leaning out WOT and the fuel pressure was reading all over the place, so i removed the in tank paper filter, and switched to an engine bay mounted WRX style filter, that fixed the issue for a a few days, the car wasn't leaning out and the base pressure was great. then the issue came back so i swapped to an Jegs in line steel media filter and no change. so i decided to slam a new fuel pump in, and huzzah that fixed it! but my base fuel pressure which should've been 60psi was now reading 75psi, so im assuming a failing pump (likely stressed from the clogged in tank filter) was the main culprit. so i dialed it back down to 60psi and the car was running like a champ! AFR were perfect.
Now for the bad news....
i went to start the car, put the clutch to the floor (as you do) and heard a click, and the car started but wouldn't go into gear while running or roll in gear when the car was off, so I'm assuming the throw out bearing on my ACT setup has failed and the car is immobile. So now i must decide if i should buy a twin or triple disc clutch! if the trans is coming out to repair i might as well upgrade eh?!
Old 10-27-2019, 03:33 PM   #71
96accord
Member#: 145105
2015 Honda Accord
Needs to get fixed so it can race more before winter
Old 10-28-2019, 12:15 PM   #72
CursezZz
Member#: 414974
2006 Subaru WRX STi
that is very unlikely lol
Old 10-28-2019, 01:12 PM   #73
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
damn i've missed so much. Great power coming out of this thing! Glad you're still building it.
and I'd say go for the twin disc.
JDMJNKY is offline   Reply With Quote
Old 10-28-2019, 06:41 PM   #74
JoeDe
Member#: 507575
Holy moly, very nice build
JoeDe is offline   Reply With Quote
Old 10-28-2019, 07:05 PM   #75
Drivez
Member#: 280995
2019 STi
Crystal Black Silica
Great build! Do you have a final goal for where you want your car to be?
Funny how that Subaru itch can't be fulfilled by any other cars. A similar story on my side, had an M235, C63S, and C7 GS but nothing could fill the void of these damn Subaru's lol.
Drivez is offline   Reply With Quote
