Welcome to the North American Subaru Impreza Owners Club Sunday September 20, 2020
Old 04-09-2019, 01:49 PM   #501
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Originally Posted by jigga View Post
Thanks for the response
To answer your question, the answer is "both". I do have a standalone running the car most of the time, but my stock ECU does have to go back in occasionally for emissions purposes (and will have to go back into the car in a few weeks again actually), hence part of the desire to keep the stock FPC in the loop.
As is now, I can switch the stock ECU back in easily by just plugging it in and it is able to run the primary pumps on the car without issue, as it can power up the relay running the primary pumps, and run them at a constant speed.
I understand the issue - personally, I just register my car in a rural area at a family member's address. As long as you store the vehicle there now and then (and can reliably receive mail there), the DMV should allow it. I would NOT do this at an out-of-state address or a friend's address.
However - to continue with your current process, you can pull this off by sourcing a second FPC and making a jumper harness out of the 8 inch sub-harness it comes with.
A good trick to make sure you never mess this up is to make the standalone trigger the fuel pump relay using an opposite electrical signal when compared to the OEM ECU. For example:
If the stock ECU is sending a 5V 'enable' signal to the FPC (common to most 32-bit Subaru models), you set the relay up to close when the ECU sends a grounding signal.
-or-
If the stock ECU is sending a ground 'enable' signal to the FPC (which is how SOME 16-bit Subaru models work), you set the relay up to close when the ECU sends a 12V signal.
Side note - the 5V-active controllers WILL accept a 12V signal without any issue. I did it for years on a 2006 STI using a MoTeC M800 before converting to a relay.
mrsaturn7085 is offline   Reply With Quote
Old 04-12-2019, 07:17 PM   #502
jdarrow12
Member#: 465527
2006 wrx sti
dw sells a hardwire kit for $35, but not sure how it would compare to a homemade option
jdarrow12 is offline   Reply With Quote
Old 04-24-2019, 01:27 PM   #503
veritasaequitas
Member#: 333964
2005 sti
aspen white
So I was having parasitic draw issues with this setup as someone had previously mentjoned(of course I didn't see it till after I did all of my diagnosing and testing). Like previously stated you need to get a switched ignition from another source other than the fuel system. I had used a add a circuit kit to achieve this. First I taped into a circuit that was hot switched but turned off when in start position. I wound up using the srs light fuse spot inside the cabin(05 STI).
veritasaequitas is offline   Reply With Quote
Old 04-28-2019, 11:49 AM   #504
Self_Control_Me
Member#: 311034
2011 STi
Originally Posted by Self_Control_Me View Post
i'm thinking the power-io suggestion is the best option. especially for people that want maintain PWM for their fuel pump like me. i dont want my oversized fuel pump pumping 100% and heating my fuel while im setting in the parking lot at walmart.
why not wire the power-io module to the factory FPC where fuel pump used to be. then let the power-io module power the fuel pump/s. the HDD-06V75E is good for 75amps and dont forget the freewheeling diode across the load.
this is what i plan to do. in my case i have a lift pump in the tank and a surge pot pump in the trunk. i'm going to power both pumps from the 1 power-io module.
thanks for the clue above - i hope my plan works - i'll try to remember to post back after i test this out.
ok - this works fine, a bit pricey and wiring intensive but works great to maintain pwm of the fuel pump.
your wiring skills have to be pretty good if your going to do this. if anyone is interested, i will text mesage or email you my diagram. im not posting it on here because i doubt anyone really cares as much about keeping the fuel pump screaming as i do.
i just figured i'd support John at Power-io because he was so nice and actually gave me an extra free pwm relay.
Self_Control_Me is offline   Reply With Quote
Old 05-05-2019, 12:00 AM   #505
Self_Control_Me
Member#: 311034
2011 STi
here is the diagram i was referring to, i got a few messages about this. i have confirmed that the pump does slow down when the ECU tells the fuel pump controller to. It is alot of work and alot of soldering but the pwm of the pump is preserved and the relay is capable of a whopping 75amps.
Old 05-05-2019, 12:05 AM   #506
Self_Control_Me
Member#: 311034
2011 STi
https://photos.google.com/album/AF1Q...8tpUY3XISM.jpg
godam filing sharing
note that this is on a 2011 sti
https://photos.app.goo.gl/UKgMAwNWMMqcJnoi8
Old 05-20-2019, 09:11 AM   #507
Self_Control_Me
Member#: 311034
2011 STi
here is an update to this wiring diagram. i switched the zener to a 3.3v zener which really doesnt matter but that part number is mouser #863-1N5333BRLG.
the most important update is disconnecting the Lgr wire that goes from pin 9 on the fpc to pin b10 on the ecu. that is a diagnostic wire that does something like transmit actual motor duty cycle to the ecu/gives the ecu feedback of some sort but im not really sure. after disconnecting the diagnostic wire, the ecu output reading via accessport and the sound of my aem 50-1005 is more normal. it simply switches from 66% to 100% when i give it a little bit of throttle. when the diagnostic wire was still connected, it would do some funny surging of the pwm signal that i could hear and see via pwm output reading on the accessport, probably trying to compensate for a pure resistive load rather than an inductive motor load is my guess.
also, p0230 would need to be disabled.
im going to drive it around for a while. i need to get a new tune done after installing the swirl pot setup and the aem 50-1005 but im going to drive it around a bit before i do. i know im running just crazy rich, so i should be alright.
i'll report back if i make any changes for anyone thats crazy enough to put this much soldering and install time into making your pump not run 100% all them time. LOL :-)
Old 05-29-2019, 07:18 AM   #508
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Info.....................
BlueSTI4Me is offline   Reply With Quote
Old 09-11-2019, 03:31 PM   #509
00redobs
Member#: 325233
1999 Impreza
Originally Posted by brazzl61 View Post
Hope this better helps. If not feel free to ask questions.
Also, someone asked about amperage somewhere, reason that amperage is able to flow is by creating a thick short path to ground. The amperage can travel through small gauge wire and FPC if the path is short enough. This is why I did not skip on putting that extra ground directly off the FPC.
NVM, figured it out.
00redobs is offline   Reply With Quote
Old 04-29-2020, 09:29 PM   #510
Chip_04sti
Member#: 434474
Default Sorry to bring this back..
So this wonít help me if my fuel pump controller is already bad right?? I would have to get a new controller first. Anyone know?
Chip_04sti is offline   Reply With Quote
Old 04-30-2020, 05:59 AM   #511
subbi7
Member#: 241967
02 wrx
if you rewire the fuel pump you bypass the controller...
subbi7 is offline   Reply With Quote
Old 04-30-2020, 06:55 AM   #512
Chip_04sti
Member#: 434474
I know my fuel pump controller is bad, I try to hardwire the pump by using ops original post and itís still not working, could it be because itís drawing power from a bad FPC?
Old 04-30-2020, 02:04 PM   #513
subbi7
Member#: 241967
02 wrx
i got the oem fuel pump relay to trigger relay that feed direct from the battry to the pump.
