Welcome to the North American Subaru Impreza Owners Club Friday December 6, 2019
Old 09-12-2019, 07:12 PM   #1
richaarizard
Member#: 505370
Default Micropolishing a crankshaft?
I have a crankshaft from my last build it lasted 10-15k miles and went down from a bent rod. No spun bearings, had the crankshaft mic'ed and everything is within spec stil, no deep scratches nothing.
Planning on balancing the crankshaft as well. So my question is should I micro polish the crankshaft or is it not needed and I can just slap on the new bearings and get then measured for clearances?
richaarizard is offline   Reply With Quote
Old 09-12-2019, 08:43 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We do it here on the more expensive builds where people are chasing every last bit of time. We a bit lower oil temps compared to not polishing so I say do it if you have time.
If you're super mega baller send it out for REM polishing.
Old 09-12-2019, 10:02 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Second the REM process. If you're going to do it, do it right.
Old 09-12-2019, 11:19 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Oh! Well in that case lets do this!!
REM polish and then DLC
Crank
Cams
Lifters
Valve stems
I think the last time I got lifters quoted it was something like $40 each. Then I ordered lifters for a VQ35 and got DLC from the factory... for cheaper than Subaru lifters. Dammit Subaru!!
Old 09-13-2019, 10:01 AM   #5
Bansheeboy11
Member#: 182415
1999 RS
REM is a great option, also look into WPC treatments as well its a little more cost effective for a car that doesnt have sponsers on the sides.
Bansheeboy11 is online now   Reply With Quote
Old 09-15-2019, 11:10 AM   #6
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Rem and WPC pricing is about the same if anything REM would be cheaper but I do believe WPC has better results
Old 09-15-2019, 06:17 PM   #7
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Someone has been using tinder too much
user1029 is offline   Reply With Quote
Old 09-15-2019, 07:15 PM   #8
subaru_gc8
Member#: 29292
2004 WRX wagon
being that you bent a rod I would see if the balancing has been thrown off first. then move forward. but in the same token, a new one is probably less than what you would pay to get yours all balanced and polished.. just saying
