Welcome to the North American Subaru Impreza Owners Club Wednesday January 29, 2020
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 09-04-2019, 02:14 PM   #26
pcampbell
Member#: 437670
2005 2.5 SC OB
I think they switched to returnless in 2006 for many cars, A return style has 3 lines. 1 is supply, 1 is return and 1 is Evap. You can tell by going to RockAuto and looking at the fuel pump module, or.... in engine bay 3 hoses would be return style. I have no idea how to tune a returnless system but I am sure many people have done it successfully.
pcampbell is offline   Reply With Quote
Old 09-04-2019, 03:53 PM   #27
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
I disconnected the hose I thought was return and it’s definitely evap, no fuel. I’ve had this car tuned multiple times, no one has ever mentioned returnless being an issue?
tipsymechanic is offline   Reply With Quote
Old 09-04-2019, 08:17 PM   #28
pcampbell
Member#: 437670
2005 2.5 SC OB
Yeah I don't think it will be much of an issue.
Old 09-07-2019, 11:38 PM   #29
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Video 1.5 is up!
Lots of work done today.. and more tomorrow. I'll have a video up next week of us actually working!
Some progress pics:
Installing the AWIC radiator and pump
https://i.imgur.com/K2iSZ7S.jpg
https://i.imgur.com/NSqzBOX.jpg
Pump and relay/fuse box 100% complete
https://i.imgur.com/SjFeaWK.jpg
Inside the pump relay/fuse box
https://i.imgur.com/TEgOqEL.jpg
Radiator complete
https://i.imgur.com/2H0bV5I.jpg
Hella horn mounting
https://i.imgur.com/lh5wnLl.jpg
Subimods Hella horn harness
https://i.imgur.com/IuJj89R.jpg
Rear galley plug used for turbo oil feed and AVLS oil temp sensor relocation
https://i.imgur.com/qhW1eyD.jpg
OEM turbo manifold sandblasted, painted, and ready for wrap
https://i.imgur.com/ne9fVTa.jpg
https://i.imgur.com/1L4ceMo.jpg
Old 09-12-2019, 09:03 PM   #30
koopascoob
Member#: 505486
2008 Subaru
Legacy
Hi tipsymechanic, awesome build.
I'm assuming you did engine management yourself. How did you adjust your ROM for the larger fuel injectors? Any guides anuwhere about this?
I'm going to slap on a used raptor SC kit soon with wrx injectors onto an ej253 and need help since I don't have a base map.
koopascoob is offline   Reply With Quote
Old 09-13-2019, 08:20 AM   #31
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Hey. You’ll need the flow and latency values for your injectors and you plug them into the respective tables in romraider.
There’s a lot of good newbie tuning info here: https://forums.nasioc.com/forums/showthread.php?t=1626520
Have you had your ECU defined yet, so it can be tuned? PM me if you need more detailed help.
Old 09-13-2019, 10:44 AM   #32
koopascoob
Member#: 505486
2008 Subaru
Legacy
There’s a lot of good newbie tuning info here: https://forums.nasioc.com/forums/sho....php?t=1626520
I have not had my ECU defined yet. Still waiting for my tactrix cable to arrive. I'm getting some stock WRX injectors so I'm sure it should be easy enough to find the flow and latency. Thanks for the help, I'll pm if I need more help as the project progresses.
Old 09-13-2019, 01:48 PM   #33
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Cool. You’ll also need to re-scale the tip-in fueling, cranking tables, and a few other things fuel related
Old 09-14-2019, 09:54 PM   #34
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Part 2 is up! In this episode, we tackle installing the air-to-water intercooler.
Old 09-18-2019, 09:52 PM   #35
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Stock Subaru BPV modified and mounted to the AWIC!
https://i.imgur.com/w8NIk8A.jpg
Old 09-19-2019, 12:38 PM   #36
pcampbell
Member#: 437670
2005 2.5 SC OB
Do you think the larger type 14 Awic would fit? I was thinking about upgrading.
Old 09-24-2019, 07:25 AM   #37
Boxcar80
Member#: 491471
2009 Impreza
Do you have to modify the stock BPV for the lower boost?
Boxcar80 is offline   Reply With Quote
Old 10-11-2019, 07:18 AM   #38
Boxcar80
Member#: 491471
2009 Impreza
Its been awhile. Anything new with your build?
Old 11-07-2019, 05:37 PM   #39
nvmylh
Member#: 243490
What happened to this thing??
nvmylh is offline   Reply With Quote
Old 11-08-2019, 07:39 AM   #40
pcampbell
Member#: 437670
2005 2.5 SC OB
Probably life! I’m sure he will be back
Old 11-11-2019, 08:33 PM   #41
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Man that'd be tough. Maybe if you could shave an inch off the throttle body and the IC.. you'd still have another inch to make up. Might be time to go with a custom one?
Old 11-11-2019, 08:34 PM   #42
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Nope, it works just fine!
Its running and driving, I'm trying to find time to edit videos.
still here! sorry, been super busy!
Old 11-11-2019, 11:16 PM   #43
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
PART 3!!
I apologize for the delay.. I got lazy/unmotivated/busy/etc..
This one isn't too exciting, just making some changes to allow the turbo inlet fitment, and turbo oil feed plumbing.
Old 11-25-2019, 10:27 AM   #44
awfulwaffle
Member#: 409332
2013 WRX
PBP
What are those topfeed rails with integral pulse dampers off of?
awfulwaffle is offline   Reply With Quote
Old 11-25-2019, 07:44 PM   #45
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Stock EJ253
Old 12-15-2019, 09:12 AM   #46
Boxcar80
Member#: 491471
2009 Impreza
Anything new? Can't wait to see a new video.
