Welcome to the North American Subaru Impreza Owners Club Saturday December 14, 2019
Old 09-29-2019, 06:48 PM   #1251
AmericanJager
Member#: 487006
2015 WRX
CWP
General maintenance today; cabin filter, intake filter, and oil change.
AmericanJager is offline   Reply With Quote
Old 09-29-2019, 10:28 PM   #1252
Assyr
Member#: 506894
2013 STi
Grey
I tore out my stock IHI VF48 turbo to do a swap. Turns out the replacement turbo has a chip on the compressor side turbine. I also installed a tomei turbo inlet tube!
So now the car is sitting in the garage in pieces!
Assyr is offline   Reply With Quote
Old 09-30-2019, 06:40 PM   #1253
IndecisiveS12
Member#: 463349
2017 WRX Sport
World Rally Blue
I decided to cover up that fake carbon fiber trim and flock it.
IndecisiveS12 is offline   Reply With Quote
Old 10-01-2019, 11:04 PM   #1254
arempee26
Member#: 491364
After over a month of waiting, I finally received and installed the non resonated mid pipe.
arempee26 is offline   Reply With Quote
Old 10-03-2019, 12:25 AM   #1255
Solow_rx
Member#: 506642
2017 WRX
crystal white pearl
Finally went stage 2 with my 2017 WRX install went smooth no broken studs or stripped nuts also installed q300 catback. I thought a j pipe would increase the loudness of a q300 it did but still to quite for me unfortunately.
Solow_rx is offline   Reply With Quote
Old 10-03-2019, 12:51 AM   #1256
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Installed the snow performance meth kit for my rotated setup. I put it in the spare tire well. Had to cut out that bump first. Hammered out the well in two spots. Carved a contour into some foam and then strapped down the tank. Ran the lines and got most of the wiring done. The top panel fits over the tank with about 1/2 inch to spare. Iím going to build a metal frame so that when closed, I can still put stuff in the trunk.
bdubblu is offline   Reply With Quote
Old 10-03-2019, 08:56 PM   #1257
Waterguy71
Member#: 496168
2019 WRX
Series.Gray
In the last few days I have swapped out my brakes to StopTech slotted rotors, performance pads, and ss braided lines, installed a Invidia Q300 CB exhaust, added a vortex generator, and installed a CS style front lip. Its been a busy couple of days, but the car is finally getting to were I want it.
Waterguy71 is offline   Reply With Quote
Old 10-03-2019, 10:23 PM   #1258
BlackMajik57
Member#: 507023
2005 2.5RS Impreza
35J - Regal Blue Pearl
When I got my 2.5RS it came with Forester wheels on it for some reason.
A few days ago I got and installed WRX rims, and got new tires all around.
In the next week or so I'll be doing better break pads. Then I think I'll need to do the struts soon, the rears are leaking a tad, or should I replace struts first then do break pads. I mean, the car stops and all.
BlackMajik57 is offline   Reply With Quote
Old 10-04-2019, 08:32 AM   #1259
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
'08 Mustang GT (the toy)
Inspect the pads at least for remaining friction material thickness and absence of extreme amounts of taper wear and let that be your guide.
A little late this time, but changing (or rotating) tires is a great opportunity to make at least a quick and dirty brake inspection.
Norm
Old 10-04-2019, 09:41 AM   #1260
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Got my WRX and STI a new to me home.. it's got a large attached finished garage and I absolutely love it. Been giving the garage my finishing touches (epoxy floor, large LED overhead lights, new wifi enabled garage door openers, new shelves, workbench, etc etc) the last few weeks and hope to finish by end of the month.
oichan is offline   Reply With Quote
Old 10-04-2019, 01:43 PM   #1261
aqtruong
Member#: 457131
2011 WRX Sedan
Changed spark plugs and decided to do a leak down test as well: 4% on cyl 1 and 2, 8% on cyl 3 and 4. Not bad for 98k miles.. I think. Could be worse!
aqtruong is offline   Reply With Quote
Old 10-04-2019, 04:15 PM   #1262
MAD WRX
Member#: 472279
2015 WRX ( traded )
2019 WRX WRB
I also have the non resonated mid pipe , paired with their muffler deletes. Sounds great
MAD WRX is offline   Reply With Quote
Old 10-04-2019, 08:12 PM   #1263
arempee26
Member#: 491364
Which muffler delete did you get? I paired it with the double wall burnt tips. Somehow, this mid pipe is more quiet than the stock especially on idle IMHO but it does have a nice roar when you step on it.
Old 10-05-2019, 01:03 AM   #1264
closevo
Member#: 268031
2006 Forester XT
Started her up for the first time today.
https://i.imgur.com/qQDD9Am.jpg
closevo is offline   Reply With Quote
Old 10-05-2019, 06:33 PM   #1265
jdm05
Member#: 180155
05 Jdm Sti 2.0
jdm05 is offline   Reply With Quote
Old 10-05-2019, 08:57 PM   #1266
007SubaGuruEJ
Member#: 507100
Default TRADED my 12 in :(
I traded my 2012 WRX in today . Luckily I still have my fully built 2014 STI though
007SubaGuruEJ is offline   Reply With Quote
Old 10-06-2019, 03:50 AM   #1267
Jokerhotpocket
Member#: 507114
Oil and filter change, added winter -20 washer fluid.
Bled brake fluid & added fresh clean fluid, topped off coolant. Rain X'd windshield.
Washed car. Fresh coat of wax. Resurfaced headlights.
Rotated tires. Properly torqued lug nuts. Checked tire pressures.
Drove 80 mile round trip to pick up some business related items. Several hours later rechecked the tire psi and hit up the lug nuts again to ensure all torque specs are still in range.
Kind of an over-achiever. She's almost ready for winter.
Jokerhotpocket is offline   Reply With Quote
Old 10-09-2019, 01:30 AM   #1268
knate14
Member#: 498242
Default Drove form Reno, to Virginia City, 1.5 times.
I started to drive to Virginia City in my 02 WRX wagon this afternoon, I got about halfway and my TMIC coupler came loose. I lost boost and drove home very slowly. I fixed the coupler back to the intercooler and tightened it up. I tried the drive again, and everything held up fine (my rotors did get a little warm towards the end). I had a blast.
02 WRX wagon
AEM cold air intake
MaXpeedingrods Coilovers
Tomei equal length headers
Tomei up pipe
HKS turbo-back exhaust
Lightened flywheel
Extreme calipers with drilled n slotted rotors
PnP TD04
Grimmspeed boost controller
knate14 is offline   Reply With Quote
Old 10-09-2019, 10:13 PM   #1269
sayunkl
Member#: 302548
2019 STi
2018 High Country
sayunkl is offline   Reply With Quote
Old 10-10-2019, 07:46 AM   #1270
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
So what is it
Old 10-11-2019, 12:00 AM   #1271
MedicMoses
Member#: 470679
2018 WRX
Pure Red
Originally Posted by Norm Peterson View Post
So what is it
F1 brake light with PNP adapter
MedicMoses is offline   Reply With Quote
Old 10-11-2019, 08:02 AM   #1272
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Thanks; I never would have guessed.
Is it brighter than OE or is there some other advantage?
Norm
Old 10-11-2019, 08:02 AM   #1273
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Norm
Old 10-11-2019, 12:22 PM   #1274
tmnc09
Member#: 397956
2009 WRX
Norm
There is no OE F1 brake light for US market. JDM comes with them but we have to buy aftermarket.
tmnc09 is offline   Reply With Quote
Old 10-11-2019, 12:32 PM   #1275
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
Thanks again.
If I do this, I'm wondering if I might want to put it on a toggle-switch arrangement so that it doesn't have to illuminate every time the car is in reverse (potentially attracting unwelcome official attention).
Many moons ago I adapted a fog light to improve reverse lighting in dark areas, so there's a chance I might actually do this.
Norm
