#3976 |
Member#: 111755
![]() ouch!!!! u get too close to a semi or something? there has gotta be a story behind that!
ok, for bumper since rare, you may have to jimmy your old one or repair from the backside. same with retrofitting the headlight.. I know they have come down in price a bit but still expensive. what happened to the grill? ur car looks pretty spotless, wow.
#3977 | |
Member#: 375976
Vehicle:2002 WRB STi |
![]() Quote:
Deer jumped from the weeds, didn't stand a chance. ![]() |
#3978 |
Member#: 151814
SCIC
Vehicle:2014 WRX SWP |
![]() Wow! really sorry to see this. My suggestion is get it quote from the adjuster instead of getting it repaired from an insurance agency shop. Just have them cut you a check and you purchase all the parts.
I wouldn't rely on the insurance company to match all the JDM pieces you need. Good luck I hope to see her up and running soon. |
#3979 |
Member#: 183181
Vehicle:2005 Forester XT Aspen White |
![]() I hit a deer in my forester, and just had the body shop give me a quote on fixing it. My insurance cut me a check, then I went and bought all the JDM front end pieces to replace the stock stuff.
#3980 |
Member#: 306719
MWSOC
Vehicle:2003 Sti Wagon @jn_garage |
![]() Awww
That is awful I love that car |
#3981 | |
Member#: 132
Tri-State
Vehicle:05 WRX, 15 WRX 6mt '02 WRX- ShinjiTuned |
![]() Quote:
Ugh, so sorry to see this! My favorite bugeye sedan on Nasioc. ![]() But, could have been worse! At least the wheel is OK? In terms of insurance, our insurance told us to keep any receipts for aftermarket parts added and they would take care of it(within reason I suppose). Hoping they can help you at least a little. |
#3982 |
Member#: 375976
![]() After doing a little closer inspection, somehow the hood avoided getting damaged.
The drivers headlight mounting points are broken off (all three locations), so that is in need of a replacement. The wiring harness/ballast will need to be replaced as some parts didn't survive. The bumper is cracked in a couple of spots, probably can be fixed but not 100% sure. the fog light cover is cracked as well, will have to be on the lookout for another one of those. The JDM bumper beam is damaged as well, not sure sure how bad as I don't want to take it apart yet. The wheel appears to have avoided damage, I will want to take it to a shop to confirm that it's straight. The Prodrive grill, the mounting tab on the driver side pulled part of the grill with it, probably can repair that from the backside. |
#3983 | |
Member#: 253498
SCIC
Vehicle:02 RSTI MURK'D |
![]() Thanks Boost!! 18x11 & 305's
#3984 |
Member#: 132
Tri-State
![]() Swapped out the STi Version 7 grille for an STi Prodrive grille to match the bumper. Got some "jdm-style" 50/50 tint installed, too.
#3985 | |
Member#: 347474
Vehicle:0219 Bug,bug,coup,va mbp,sr,wrb |
![]() Quote:
Those wheels are so good |
#3986 |
Member#: 253498
SCIC
![]() Looks good Shik
#3987 |
Member#: 25768
RMIC
Vehicle:2003 GEN2 GTX35 40++ 2.3 slobaru |
#3988 |
Member#: 253498
SCIC
![]() That's a dope grill, which is it?
#3989 |
Member#: 504580
NESIC
Vehicle:2002 RS :( |
![]() I need some headlights for my bugeye. I think these are actually new, but I can't tell if I like them. What do you guys think?
http://oemassive.com/fits-2002-2003-...ck-headlights/ ![]() |
#3990 |
Member#: 175624
MWSOC
Vehicle:0304 WRX WRX SY WRB |
#3991 |
Member#: 375976
![]() Heard back from the insurance and I am getting enough money that I should be able to replace all my parts.
![]() Now the fun part of trying to track some of these parts down. Anyone know of a drivers side fog cover and/or MC fog for sale? eBay has some of the true covers, but I need one of the fog light ones. https://forums.nasioc.com/forums/sho...rodrive+bumper |
#3992 |
Member#: 111755
![]() sounds awesome, let the hunt begin!
#3993 | |
Member#: 306719
MWSOC
![]() Quote:
I have some UK300s that need a new home |
#3994 |
Member#: 87542
SCIC
Vehicle:2002 Bugeye PSM |
#3995 |
Member#: 25768
RMIC
#3996 |
Member#: 504580
NESIC
#3997 |
Member#: 504580
NESIC
#3998 |
Member#: 243697
MAIC
Vehicle:2002 TOPSCOOB031 HighwaystarGarage |
![]() I would actually argue that the DEPO headlight lenses may be a bit more durable than than JDM ones... albeit nothing looks as good as JDM black chromes TBH.
#3999 |
Member#: 175624
MWSOC
![]() I have the halogen versions, so a bit cheaper than the HIDs, but still not too crazy for a JDM style unit.
I can tell you the wiring and connector quality isn't that great on the DEPOs. Especially the main 3 pin connector (the big blue one). I also actually had the low beam ground wire burn up on one of them because the blade terminal connection shook loose (not off, just not tight). I cant imagine how bad an even cheaper headlight must be ![]() |
#4000 |
Member#: 253498
SCIC
