Welcome to the North American Subaru Impreza Owners Club Sunday September 27, 2020
Old 05-12-2019, 11:56 AM   #26
ChristopherWRX
Member#: 486706
2016 WRX
Lapis Blue Pearl
Looks good mpen97!
ChristopherWRX is offline   Reply With Quote
Old 05-18-2019, 05:00 PM   #27
Wolfman_Jack
Member#: 296372
mpen97, where did you get that fill in part for the DCCD?
Wolfman_Jack is offline   Reply With Quote
Old 06-02-2019, 02:16 AM   #28
c1em3ntchua
Member#: 459594
Looks to be 3D printed. I'm looking for one of these as well.
c1em3ntchua is offline   Reply With Quote
Old 06-05-2019, 09:14 PM   #29
crunktim
Member#: 245067
Just got this done through Jason at Overland designs. Did a great job.
crunktim is offline   Reply With Quote
Old 06-06-2019, 09:48 PM   #30
Jnak001
Member#: 456734
I swapped this in about a year ago in my 2017. I found a guy local who designed and 3D printed the coin tray to replace the DCCD controller. To keep coins from rattling to much I cut a small section of tool box tray liner and placed it in the bottom of the tray.
Jnak001 is offline   Reply With Quote
Old 06-14-2019, 12:19 PM   #31
crunktim
Member#: 245067
Finished product.
Old 06-19-2019, 05:26 PM   #32
lowvndslow
Member#: 498273
Wait so can I just buy the cup holder piece and swap it out? Do I just need to buy one item?
lowvndslow is offline   Reply With Quote
Old 06-19-2019, 07:52 PM   #33
dannyq86
Member#: 416919
@crunktim looks badass, and expensive
dannyq86 is offline   Reply With Quote
Old 06-20-2019, 12:45 PM   #34
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
https://parts.subaru.com/a/Subaru_20...10-930-01.html
Big-E is offline   Reply With Quote
Old 06-20-2019, 01:43 PM   #35
penak
Member#: 498498
Loving this thread, very interesting discussion
penak is offline   Reply With Quote
Old 06-21-2019, 12:14 PM   #36
Jnak001
Member#: 456734
If you have heated seats the switches and wire harness connections for the STI are different than a WRX so they are not plug and play. I had to cut the opening out to fit the stock WRX switches. I ended up buying a complete STI center console on eBay with the DCCD controller. I turned around and sold the DCCD controller and other parts that I didnít need to offset a majority of the cost.
Old 06-27-2019, 10:21 PM   #37
Lone Wolf 75
Member#: 2221
2018 Subaru WRX
Lapis Blue Pearl
Originally Posted by crunktim View Post
Finished product.
That's beautiful. I want one but it's hard to justify. I'm wrestling with this and the JDM leather shift console like the S4's.
Lone Wolf 75 is offline   Reply With Quote
Old 07-23-2019, 09:36 AM   #38
c1em3ntchua
Member#: 459594
Hey guys, some updates.
I chatted with mpen97 on Reddit, and he sent me the 3D model of the coin tray that he designed. I have made some improvements based on the model that he created (download links below):
  1. Slightly enlarged the tray.
  2. Contoured the "overhangs".
  3. Added 4 clips and 2 screw holes (based on the SI Drive design).
Things I did:
  1. Printed in ABS, 100% infill due to the clips and screw holes. Two clips (both on the same side) broke off while test fitting the model, but the other two clips and the screws held the tray in quite well.
  2. My model was printed at 102% scale, I'm guessing anywhere from 101-102% should be good as ABS contracts after printing.
  3. Sanded the top surface of the "overhang" and spray painted the tray matte black.
Download links to model:
  1. 3mf: https://www.dropbox.com/s/46kp09rwtq..._V4.2.3MF?dl=0
  2. stl: https://www.dropbox.com/s/stneiim4xp..._V4.2.STL?dl=0
Finally, some pictures!
https://i.imgur.com/NCsyT6r.png
https://i.imgur.com/aaMvCaB.png
https://i.imgur.com/Ev0l2LL.jpg
Old 08-05-2019, 11:01 AM   #39
LubeySubie15
Member#: 470452
Default Apologizing for the extremely late reply to this thread
Originally Posted by mpen97 View Post
Full swap complete on my 2016 WRX Premium! (Excuse the mess... overdue for a clean)
https://i.imgur.com/vcJXEf8.jpg
I have just swapped the STi shift trim and want the exact same setup you have for the sliding cup holder minus the DCCD controller, any guidance as far as how you went about getting that? I have a 16 wrx as well, thanks !
LubeySubie15 is offline   Reply With Quote
Old 08-05-2019, 11:22 AM   #40
gmasters428
Member#: 464431
That looks great
gmasters428 is offline   Reply With Quote
Old 08-09-2019, 09:40 AM   #41
mpen97
Member#: 501048
2016 WRX Premium
I went to a local wrecker and bought the centre console, which includes the sliding cup holder. Pretty simple removal. One screw underneath the handbrake boot and two screws at the bottom of the centre console, inside the arm rest. Pop that off, unplug the 12v socket from underneath before yanking the console out and it's as easy as that.
In terms of replacing the DCCD. See c1em3ntchua's just above yours. We worked on the coin tray and, I guess, perfected it, to fit. A download link is available for the .STL file within the post, however, requires 3D printing. If you have a 3D printer, knock yourself out. Alternatively, you should be able to find a local business that does 3D printing. Send them the .STL file and ask to have printed in ABS material, this way it can withstand the heat. And then you can sand/paint to match, which is a simple matte black.
mpen97 is offline   Reply With Quote
Old 08-10-2019, 12:53 AM   #42
BeAboveAverage
Member#: 505128
Originally Posted by heymonroe View Post
Yeah this is a good question, I would like this in my '17
Yes itís possible.
BeAboveAverage is offline   Reply With Quote
Old 10-06-2019, 03:59 PM   #43
Gardo
Member#: 507126
Is anybody selling the 3D printed pocket to finish off the swap
Gardo is offline   Reply With Quote
Old 10-06-2019, 09:32 PM   #44
TheModfatherInc
Member#: 492499
2010 2.5i
SSM
The dude who designed it is in this thread a few comments up, but if he doesnt want to print one, i'd be willing to for a few bucks assuming hes got no objection.
TheModfatherInc is offline   Reply With Quote
Old 10-07-2019, 09:40 AM   #45
c1em3ntchua
Member#: 459594
Please do go ahead. I'm based in Singapore so it doesn't make sense for me to print it and ship it over to the USA. The design is open-source anyway, so enjoy
Old 10-09-2019, 11:11 AM   #46
TheModfatherInc
Member#: 492499
2010 2.5i
SSM
In that case, any suggestions on print orientation/settings? Thinking standing on the thin flat edge or 45 degrees may be easiest. Lots of overhangs/support to deal with
Old 10-18-2019, 10:14 PM   #47
c1em3ntchua
Member#: 459594
Apologies for the late reply. I'm not very active here.
My printer had it printed in two orientations for me to choose - (1) standing on the thin edge, and (2) normal orientation - see first picture of this post.
I found that (1) was more ideal for sanding later on as you don't have to deal with layers (the overhangs are slightly contoured), but (2) was a better fit. Not too bad though, since (1) ended up slightly larger so I just had it sanded down to get it to fit.
Old 10-22-2019, 05:10 PM   #48
subiesenpai
Member#: 506576
@c1em3ntchua Thx for sharing this! I've been waiting ever since I got my 2015 for this kind of mod!
I got mine made by AnT 3D Printing and paid $45 after tax w/ free shipping. They did an amazing job! Finally took some time to sand and paint it. Also trimmed an extra Subaru Weather Mat Coster I had lying around to fit the inside for some grip.
Overall, I absolutely love it and can finally cross this off my mod list. Thx again!
subiesenpai is offline   Reply With Quote
Old 10-24-2019, 09:46 PM   #49
TheModfatherInc
Member#: 492499
2010 2.5i
SSM
i ended up printing it on a 45 degree angle to avoid the longish bridge across the top
Old 11-03-2019, 10:36 AM   #50
travisalyer
Member#: 485776
Big thanks to everyone who contributed in this thread. I sti interior swapped (seats, center console, shift surround) my 2018 base WRX a few months ago and have been wanting to do something like this since then. I just ordered ($41.xx) this last night from AnT based on the recommendation above.
Can't wait to install it.
Thanks again all!
travisalyer is offline   Reply With Quote
