Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 10-17-2019, 01:05 AM   #1
Imp18
Member#: 498766
2018 Impreza
Island Blue
Question 30k Service??
Hey guys,
I have a new 2018 Impreza with 34k miles. I've been quoted from $350-$953 to perform the following "30k" services:
- Replace: Air cleaner element
- Replace: Brake Fluid / Clutch Fluid (Manual Only)
- Replace: Engine oil
- Replace: Engine oil filter
- Perform: Rotate and Inspect Tires
- Inspect: Fuel systems, lines and connections
- Inspect: Engine Coolant Systems, hoses and connections
- Inspect: CVT Fluid
- Inspect: Drive belt(s) [Except camshaft]
- Inspect: Transmission/Differential (Front & Rear) lubricants (Gear oil)
After speaking with a family mechanic, he told me that pretty much everything is bull**** and that I don't need any of it other than a oil change and a few basic things. He said engine oil and filter would only be needed. Since it's a new car.
What do you guys think? Honestly, it sucks not trusting any of these mechanics..
Imp18 is offline   Reply With Quote
Old 10-17-2019, 06:07 AM   #2
rtv900
Member#: 428511
2016 STI
he's right
the diff will be filthy at 30k on a new car, but the rest does not need done
Mine has 95k on it and I'm still on the factory belts
brake fluid is more like a 100k flush, not 30k
and fuel system lines and connections????? what are they going to do??
rtv900 is offline   Reply With Quote
Old 10-17-2019, 06:08 AM   #3
rtv900
Member#: 428511
2016 STI
he's right
Old 10-17-2019, 07:29 AM   #4
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Are you capable of changing the oil? If so, do it. If not, bring it to an independent mechanic and have it done.
Are you capable of driving to Auto Zone and picking up an air filter and changing that? If so, so it. If not, bring it to an independent mechanic and have it done.
If you want to really take very good care of your car, replace diff and tranny fluid. You can use the exact same stuff, so the # of bottles will be an even number. This can be a pain, but it isn't really super difficult. If you can't do it, bring your car to an independent mechanic and have them do it.
Old 10-17-2019, 08:20 AM   #5
Supraru
Member#: 23313
99' 2.5Rs
black
It clearly says inspect next to it.
To the OP, this is what we do for our 30k services at the dealership.
-oil chance
-rotate and balance the rear tires going to the front
-air filter
-pcv
-battery service
-check over the vehicle to make sure there's nothing abnormal going on
CVT fluid when if first came out was supposedly "lifetime fluid". It's rare that someone wants to flush or do a drain and fill on a cvt. We used to do drain and fills every 30k on the older auto's.
Supraru is offline   Reply With Quote
Old 10-17-2019, 09:06 AM   #6
rtv900
Member#: 428511
2016 STI
-battery service
what exactly is a battery service?
Old 10-17-2019, 09:19 AM   #7
Supraru
Member#: 23313
99' 2.5Rs
black
Test the battery, clean the top from dirt/debris, clean terminals and cable ends, spray terminals and cable ends with sealer.
Old 10-17-2019, 03:13 PM   #8
Imp18
Member#: 498766
2018 Impreza
Island Blue
So should I just do the following services?
- Inspect differential
I've been doing engine oil, engine oil filter, and rotate and inspect tires every 6k and it seems wasting money for them to inspect other stuff every 12k... Then I should just treat this like a normal service and do only the usual?
For 60k, they told me I'd need to cough up $1k for more services.. lol
Old 10-17-2019, 03:36 PM   #9
Jedi03
Member#: 491095
2009 STi Blue
keep receipts in a journal of sorts if you care to maintain factory warranty
Jedi03 is offline   Reply With Quote
Old 10-17-2019, 03:41 PM   #10
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Brake (and clutch) fluid is not a "lifetime" fluid; have the system flushed.
Replace the cabin air-filter.
Big-E is offline   Reply With Quote
Old 10-18-2019, 09:31 AM   #11
rtv900
Member#: 428511
2016 STI
saying something is not a lifetime fluid and saying it needs to be flushed every 30k are pretty far off of one another.
total waste of money to do brake and clutch fluid that early
Old 10-18-2019, 12:00 PM   #12
Big-E
Member#: 123843
2016 STI LTD CWP
Your previous post suggests that brake fluid is effectively a lifetime fluid when the FSM states to change every 30k miles.
he's right
Regardless, I'm not looking to get into a kerfuffle over this.
With regard to differential or transmission fluids, what is the definition of "inspect"? Send out for a lab analysis to determine whether the fluid/oil is still viable?
Old 10-18-2019, 12:06 PM   #13
rtv900
Member#: 428511
2016 STI
I guess we have very different opinions on what the 'lifetime' of a modern car is. I would say 100k is at most half, if not a third of the life of a vehicle that isn't totaled in an accident or abused badly.
Does the manual really say every 30k for brake fluid? I can't believe that.
As for 'what does inspect mean' for tranny fluid. It means the tech smears some on his fingers and checks a box.
Old 10-18-2019, 02:16 PM   #14
Fndragn
Member#: 470845
2011 Sti
Brake fluid can get compromised. Brake fluid boils when it gets to hot, creating moisture which causes rust. There are test strips and fluid testing devices that are less than $10. Brake fluid is cheap and easy to flush. Hell throw speed bleeders on and you can have your kids do it while you watch it's so easy. I like to follow the guidelines and service my vehicles accordingly.
Fndragn is offline   Reply With Quote
Old 10-18-2019, 02:28 PM   #15
rtv900
Member#: 428511
2016 STI
a) this sentence hurt my brain to read
b) you don't think you can boil brake fluid on the street right? So you must be referring to ultra extreme track use, in which case sure, maintenance schedules are not even close to a street vehicle
Old 10-18-2019, 02:39 PM   #16
Fndragn
Member#: 470845
2011 Sti
How the hell would you know what this guys driving conditions are, most of your comments hurt my brain to read, most are off the cuff nonsense. I clearly stated CAN BE, as in it's a possibility. There are other situations besides "ultra extreme track use" aren't there?
Old 10-18-2019, 02:44 PM   #17
rtv900
Member#: 428511
2016 STI
ha
the part that hurt was saying it boils and creates moisture, which is ludicrous to say that brake fluid creates water by boiling ok.
How would it create water?
And don't you think he would have mentioned if he was tracking in extreme conditions?
But feel free to let me know which comment of mine hurt your brain and I will respond to the part that was painful.
Please let me know how brake fluid creates water in the meantime.
Old 10-19-2019, 03:07 AM   #18
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
If he wants to keep the warranty he has to follow the maintenance schedule whether he agrees with it or not.
My question is how there is a $600 discrepancy between these services, and on what planet could these services possibly add up to nearly $1k?? $350 for everything is pushing it, how in the world did they arrive at $953 for this 15 minutes of work?
Jesus Christ man, find a Subie shop in your area, you live in California that's ground zero for ****ing Subaru shops.
GlarryHoodDIT is offline   Reply With Quote
Old 10-20-2019, 09:22 PM   #19
Imp18
Member#: 498766
2018 Impreza
Island Blue
I found a local Subaru shop and decided to do the following for $120:
- Replace engine oil
- Replace engine oil filter
- Perform rotation and inspect tires
The only difference between this and my regular 12k service is the diff.
I drove 30k in one year in california, so hopefully that gives more context on my driving conditions. I don't drive like an idiot and I average 28-30 mpg.
My car has 36k mile warranty and I'm already on 34k, so I figured screw paying an extra $500-$900 and screw the dealerships all together.
Would love to hear if the information I just provided changes things or not and what you guys think about those services. Appreciate everyone's help!
Old 10-22-2019, 05:43 PM   #20
Big-E
Member#: 123843
2016 STI LTD CWP
Yes, the service manual does say to change the brake/clutch fluid every 30k miles or 30 months.
Brake fluid is hygroscopic, which means it tends to absorb moisture from the air. No, the cap on the master-cylinder (or clutch-cylinder) does not fully seal the system, so that means there is a likelihood of some, perhaps negligible, perhaps more than negligible moisture absorption.
I get it about the gear-oil. Regardless, 'they' don't define "inspect". Inspect most-likely means to make sure there are no leaks or that the factory did in deed fill the differential/transmission than to test its remaining effective life.
Old 10-22-2019, 05:49 PM   #21
Big-E
Member#: 123843
2016 STI LTD CWP
In general, I agree with this.
Are they breaking up the work into a-la-carte items? Dealerships and independent shops in my area start at $150 per labor hour. It would be interesting to see a quote for this and not a generalized quote with a $600 spread in the middle. Define it.
If one were willing and able to pay say $750 for this service, I would expect that all of the fluids would also be changed and be included in this price.
Old 10-22-2019, 07:08 PM   #22
Supraru
Member#: 23313
99' 2.5Rs
black
We used to recommend diff changes at 60k mile intervals. It’s pretty dirty by then and it gets pretty nasty the longer you wait.
Old 10-22-2019, 07:10 PM   #23
Supraru
Member#: 23313
99' 2.5Rs
black
I’d have to double check but I believe our 30/90k services run $500-$550. Our labor rate is $120 an hour. 1k was probably a private shop that had no clue what they were doing.
Old 10-22-2019, 08:07 PM   #24
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
Your car has a 3/36 bumper to bumper warranty, but you also have a 5/60 Powertrain warranty too. Those apply to all new Subarus. If you have a CVT that specific warranty has been increased to 10/100,000.
You'll need to replace the brake/clutch fluid in order to keep the 5/60 warranty. I'd add that to your $120 service and call it good.
Old 10-22-2019, 08:26 PM   #25
Supraru
Member#: 23313
99' 2.5Rs
black
That’s not true at all....
