Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Closed Thread
Old 10-29-2019, 08:33 AM   #901
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by blurred View Post
Dyno graph was pretty much identical and driving experience favoured the g30.
This is about what I would expect. Not really bigger gains (according to plots), but a better driving experience. Boost onset characteristics, low load boost response, and transient response are not seen on WOT dyno plots, but most definitely felt during the driving experience.
KillerBMotorsport is offline
Old 10-29-2019, 12:16 PM   #902
vicious_fishes
Member#: 158864
2003 SOHC destroker
Even the most rudimentary understanding of centrifugal force should tell you to expect this.
But the exducer is 5mm smaller, so I'd expect a tiny bit sooner spool than the 3071.
Anyways, g30-660 spoolinator when?
vicious_fishes is offline
Old 10-30-2019, 02:56 AM   #903
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I think you mean angular momentum. But let's do some math on this...
A rudimentary understanding would say that it's probably more-or-less proportional to radius-squared for compressor wheels, so...
67mm diameter divided by two is a 33.5 radius, squared is 1,122
71mm diameter divided by two is a 35.5 radius, squared is 1,260
...or a difference of 12%.
But note that at a pressure ratio of 2.5, and 55 lb/min of flow, a GTX 3071 has to spin about 132k RPM, and the G30-660 has to spin just over 145k. Or a difference of about 10%.
So a net 2% in favor of the G30. Roughly. Very, very roughly.
By the way, while looking up the compressor maps for this little thought experiment, I noticed that there's now a G30-770. Similar diameters as a GTX3071, but the compressor map extends just past 70 lb/min. Looks very promising:
https://www.garrettmotion.com/racing...eries-g30-770/
NSFW is offline
Old 10-30-2019, 04:36 AM   #904
vicious_fishes
Member#: 158864
2003 SOHC destroker
Yeah but the turbine can only take so much. The 3076 has always been choked by the turbine.
The 3071 is about as much flow as you can get before the turbine is overwhelmed, and due to the better flow, you get excellent power from a step smaller compressor wheel too.
You have to err on the side of bigger turbines with these things. Hence why the 3576 blew everyone's minds and is the animal of a turbo that it is.
Really hoping that other dude can get the 30-660 vs 3071 dyno plots.
Old 10-30-2019, 07:34 AM   #905
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Can not agree more with all of the above!
I'm personally REALLY looking forward to the G30 and G35s. Patiently waiting
Old 10-30-2019, 10:47 AM   #906
vicious_fishes
Member#: 158864
2003 SOHC destroker
soooo g30-660 spoolinator when?
Old 10-30-2019, 11:00 AM   #907
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'm told I'm on the short list when they are available. Seems the IWG turbine housings are the hold-up.
Then I just need to get a tuner here, which can sometimes be time consuming
Old 10-30-2019, 05:28 PM   #908
vicious_fishes
Member#: 158864
2003 SOHC destroker
https://www.ebay.com.au/itm/Garrett-...S/254388800432
Old 10-31-2019, 08:34 AM   #909
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Need IWG
Old 10-31-2019, 12:14 PM   #910
vicious_fishes
Member#: 158864
2003 SOHC destroker
Need IWG
Er, your OP isn't? O_o
Old 10-31-2019, 12:32 PM   #911
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Oh Yes. We've done 3067 up to 3576 on that kit listed in the OP w/Tial and EWG.
The G-Series testing will be IWG. I thought I had posted pics in here, but I don't see any...
Old 10-31-2019, 12:52 PM   #912
subaru_gc8
Member#: 29292
2004 WRX wagon
so are you planning on making it a adapter like the original spoolinator or a actual up pipe with the vband?
subaru_gc8 is offline
Old 10-31-2019, 01:23 PM   #913
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You guys are wanting all my secrets
When we test the G-Series, we will also be testing a new turbo adapter (which is really the heart of the Spoolinator being able to mount where it does). All of the headaches with installing the previous kit should be eliminated. It will still be an adapter ON the up-pipe's turbo flange. I wouldn't want to change that as the versatility, with no performance downside, is one of the selling points.
Old 10-31-2019, 03:41 PM   #914
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'd still like to see the v band/ewg version in the meantime tbh
Old 10-31-2019, 03:54 PM   #915
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It's only going to perform better
Old 10-31-2019, 03:56 PM   #916
camber
Member#: 128746
Need IWG
The next version of the spoolinator turbo kit will be IWG? Starting to really love my EWG
camber is offline
Old 10-31-2019, 04:12 PM   #917
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
Some of us have much interest in the IWG versions and do not want to deal with EWG packaging and longevity issues. I look forward to how these end up performing. Otherwise my next upgrade path is only one direction (EFR) oh which I do not enjoy having to change headers and an unsupported uppipe
JarHarms is offline
Old 10-31-2019, 06:40 PM   #918
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It can be either.
If you want EWG you need to pick an EWG capable turbine housing or lock down the IWG if it comes with one. You also need to run an EWG up-pipe (any that you want or already have will work).
If you want to want to run IWG, then you need to make sure you select a Garrett V-Band IWG turbine housing.
Old 11-01-2019, 11:31 AM   #919
camber
Member#: 128746
It can be either.
Sounds good!
Looks like no change on the intake side but maybe the downpipe?
camber is offline
Old 11-02-2019, 07:42 PM   #920
subaru_gc8
Member#: 29292
2004 WRX wagon
Sounds good!
probably a shorter down pipe, it looks alot longer than ewg version..
Old 11-02-2019, 08:46 PM   #921
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
It's crazy how the trend for turbos goes back and forth from iwg to ewg. How do you know the iwg is going to suit your needs until you try the turbo? You can tweak or change the actuator, but can't change the iwg size much without extensive work.
2slofouru is offline
Old 11-02-2019, 08:57 PM   #922
subaru_gc8
Member#: 29292
2004 WRX wagon
the iwg will probably suit most people better, I know when I went to a ewg, i lost my low end, so.. I would like to go back to a stock uppipe and see who that does on spool.
Old 11-02-2019, 09:09 PM   #923
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
A properly sized ewg that uses proper springs and is properly tuned will not cause a low end loss. The iwg version will still need proper tuning.
Internal is more compact and less complex no doubt and will suit most people better for that reason though.
Old 11-02-2019, 09:47 PM   #924
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It will be either
Old 11-04-2019, 01:43 PM   #925
vicious_fishes
Member#: 158864
2003 SOHC destroker
Can you get working on the EWG one in the meantime? And give us a dyno of the 30-660?
You know, for science.
Closed Thread
