Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2020
Old 11-03-2019, 01:34 AM   #1326
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Default What'd you do to your subie today?
Wired up AEM methanol failsafe. It will trigger a relay that Iíve wired to my ECBS. If the methanol isnít spraying, itíll defeat the ecbs circuit and cut boost to wastegate spring pressure and save the motor. Well... thatís what itís supposed to do anyway. Just trying to protect the bajillion dollars I just spent under the hood.
bdubblu is offline   Reply With Quote
Old 11-03-2019, 09:06 AM   #1327
pcampbell
Member#: 437670
2005 2.5 SC OB
Motor out for delta 1500 cams and other little stuff. Really hoping for 10 plus % HP gains
pcampbell is offline   Reply With Quote
Old 11-03-2019, 09:24 AM   #1328
JoeDe
Member#: 507575
Default leather seat cleaning
anyone have good tricks to restore the leather seating, particularily if it is taupe?
JoeDe is offline   Reply With Quote
Old 11-04-2019, 12:35 AM   #1329
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Took apart, put back together, took apart, put back together, took apart, put back together..... wiring multiple gauges for methanol and failsafes is tiring.
Old 11-04-2019, 02:22 AM   #1330
9521Cody
Member#: 465978
2019 Subaru WRX
Dark Grey Metallic
Installed a Kartboy shift stop in my 19 WRX. Definitely worth the 30 bucks. No more searching for 2nd when itís cold outside. (Also got a candy with it before I took my kid trick or treating)
9521Cody is online now   Reply With Quote
Old 11-06-2019, 01:14 PM   #1331
daviesgeek
Member#: 473766
Default Finally got my exhaust rattle taken care of
I have always had a heat shield rattle around 2500-3000 rpm (second owner). I didnít know this until yesterday when I took it in to the mechanic for another issue. They stuck a hose clamp on the heat shield and my car sounds SO much better.
However I still have a clutch squeal so I gotta get that taken care of :/
daviesgeek is offline   Reply With Quote
Old 11-06-2019, 02:06 PM   #1332
MAD WRX
Member#: 472279
2015 WRX ( traded )
2019 WRX WRB
Originally Posted by arempee26 View Post
Which muffler delete did you get? I paired it with the double wall burnt tips. Somehow, this mid pipe is more quiet than the stock especially on idle IMHO but it does have a nice roar when you step on it.
I got the Remark muffler deletes , stainless steel single wall.
MAD WRX is offline   Reply With Quote
Old 11-07-2019, 09:28 PM   #1333
sayunkl
Member#: 302548
2019 Golf R
2018 High Country
Originally Posted by Akrexak View Post
Worth the wait!! Heck yes!
Thanks again for the part numbers!
Finally put them on.
sayunkl is online now   Reply With Quote
Old 11-07-2019, 11:56 PM   #1334
Akrexak
Member#: 100607
2019 STI-His
14 XT-Hers
Looks much better!
Akrexak is offline   Reply With Quote
Old 11-08-2019, 03:23 AM   #1335
bumbaclot
Member#: 505503
Finally got my accessport. However, it ASSUMED my car's gender!!!
bumbaclot is offline   Reply With Quote
Old 11-08-2019, 07:39 AM   #1336
pcampbell
Member#: 437670
2005 2.5 SC OB
Ha. It is a manual?
Old 11-08-2019, 08:19 AM   #1337
bumbaclot
Member#: 505503
Originally Posted by pcampbell View Post
Ha. It is a manual?
no, its cvt , I just found it funny the wording "your car identifies as" under one of the menus options from Cobb
Old 11-12-2019, 08:34 AM   #1338
MyNameIdeasWereTaken
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
First order of business has been to upgrade all the front facing lights to LEDs. Tested the H8 LED fog light kit from my 987 in the Subie's low beams. Light output is significantly better than the stock halogen bulbs and the cutoff is surprisingly sharp even with the stock projectors. I'm just pleased to find that these cars don't have PWM lights (or they're at least not throwing any codes for me).
We disabled the DRLs by modifying the relay, just like I had done on my Outback. DRLs aren't a legal requirement here and I don't like the way the high beams glow.
Ordered another LED kit for the fog lights.
Swapped the license plate bulbs and the front running lights to LEDs.
Swapped the interior dome light to an LED.
The steering wheel has a dent in the leather, so I ordered a new perforated skin.
I also did some research on the parts currently installed on this car, as it's not stock.
  • Perrin Master Cylinder Support
  • Perrin Lightweight Crank Pulley
  • Perrin Pulley Cover
  • Cobb Big SF Intake System
  • Invidia J Pipe
  • Invidia Racing Catback
  • Stage2+ Protune
My C30 was dyno'd at 272whp and current weighs around 3000lbs. 0-60 is consistently at 5 seconds, occasionally sub-5 once the tires are warm. This WRX can pull about 1 car length on the C30 by the top of 2nd gear, so I'm pleased with where it currently is power-wise. No plans to add anything else in the performance category and since I already have two cars with track setup coilovers, we'll be leaving the suspension stock until it needs to be replaced.
My wife filled up her shopping cart with the aero parts and vinyl, so the plan is to "finish" this family-car build by the end of the year and then enjoy it for many years to come.
MyNameIdeasWereTaken is offline   Reply With Quote
Old 11-12-2019, 06:17 PM   #1339
Baskyabhai
Member#: 507321
Hello i am a new member, but have pilfered much information from the site over the past year. i have a 2006 outback xt limited turbo that i recently did an engine swap for a jdm ej20x. this is my first subaru.
snaptube.cam/ syncnet.onl/telegram-web/
i was wondering if someone could provide some wisdom to identify a engine harness plug? i guess i have to make the minimum posts in order to post photos. if someone can help me, i certainly am willing to compensate them for their time. thanks in advance.
Baskyabhai is offline   Reply With Quote
Old 11-12-2019, 07:14 PM   #1340
Kochi_STi
Member#: 369411
2002 WRX STi Limited
Originally Posted by MyNameIdeasWereTaken View Post
That C30 looks pretty sweet. I see a few driving around here and always imagined they would look like neat in race trim.
Kochi_STi is offline   Reply With Quote
Old 11-12-2019, 09:25 PM   #1341
_BD_
Member#: 508208
2008 2.5i 5MT
Having an electrical issue with my car right now. I am researching a fix for it, and didn't do anything to the car today. It sat in the parking lot and collected snow
_BD_ is offline   Reply With Quote
Old 11-14-2019, 10:53 PM   #1342
MedicMoses
Member#: 470679
2018 WRX
Pure Red
Actually was yesterday, but put my winter wheels on
MedicMoses is offline   Reply With Quote
Old 11-15-2019, 02:03 AM   #1343
arempee26
Member#: 491364
Removed the OEM spoiler with the gurney and put this on today...
arempee26 is offline   Reply With Quote
Old 11-15-2019, 11:32 AM   #1344
blue sedan
Member#: 311622
2020 WRX
Lapis Blue
That looks great ! Who makes that ??
blue sedan is offline   Reply With Quote
Old 11-16-2019, 02:00 AM   #1345
arempee26
Member#: 491364
https://www.rallysportdirect.com/par...ill-spoiler-v2
Old 11-17-2019, 01:32 AM   #1346
Walleye74
Member#: 508372
2017 Wrx sti
What did i do hmm just purchased a 2017 sti and couldnt be happier....now the wife not so much happier lol shes an evo enthusiast
Walleye74 is offline   Reply With Quote
Old 11-19-2019, 12:43 AM   #1347
jdm05
Member#: 180155
05 Jdm Sti 2.0
Ordered some new cusco engine mounts and transmission mounts for the gd sti
jdm05 is online now   Reply With Quote
Old 11-22-2019, 04:16 PM   #1348
OTTERMATIC
Member#: 508493
93 Legacy L wagon
Peacock blue
Nothing super impressive, but I put in a new windshield sprayer so now I can clean my window properly. I had a hose just sticking out of the hood before, so it's a big improvement for such a little part.
OTTERMATIC is offline   Reply With Quote
Old 11-22-2019, 05:47 PM   #1349
carsebuco
Member#: 482289
2018 STI
Just ordered a ffk, fuel pump and ebcs. Lawld help me
carsebuco is offline   Reply With Quote
Old 11-22-2019, 11:56 PM   #1350
drbwrx
Member#: 506193
Finally got the weighted grimmspeed knob I ordered. I like how the feels now but it's slightly higher. That will probably just give me an excuse to get a short shifter 😁. Ordered the Crawford aos.
drbwrx is offline   Reply With Quote
