#11826 |
Member#: 239731
NWIC
Vehicle:90s ejs rainbow |
![]() whats the best option for sourcing a v7 ej207? I have a 04 wrx wagon and want to buy a motor that I can just drop in and go. ej205 has a burnt valve and just does not seem worth it to rebuild...
#11827 | |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
![]() Quote:
#11828 | |
Member#: 34226
![]() Quote:
Since the VF42 is a ball bearing turbo like the VF36, I expected it would be paired with the same oil feed pipe and bolt (15192AA470 and 15194AA130) as the VF36. However, I have found that Subaru uses the same oil feed pipe and bolt (15192AA480 and 15194AA110) witht he VF42 as the ones used with the VF37. In other words, the S204 which comes with the VF42 (ball bearing, twin scroll) uses the same oil feed system as the standard JDM STI which comes with the VF37 (journal bearing, twin scroll). Only the JDM Spec C which comes with the VF36 (ball bearing, twin scroll) uses a different oil feed. I thought the ball bearing turbos need less oil pressure hence the different parts for the VF36, but it is interesting that the VF42 uses the same parts as the journal bearing VF37? Any ideas why? |
#11829 | |
Member#: 50586
International
Vehicle:2017 Tacoma TRD 4x4 |
![]() Quote:
#11830 |
Member#: 34226
![]() Yup I guessed as much too, but don't you find it strange that the S204 (with a ball bearing turbo) has the same pipe and banjo bolt as a standard JDM STI (with a thrust bearing turbo)? I would have thought the S204 turbo would require less oil pressure.
#11831 |
Member#: 50586
International
![]() I am not surprised, since the inner dimensions of the turbo housing/cartridge center are the same...
#11832 |
Member#: 34226
![]() Perhaps. Conventionally, one would expect a thrust or journal bearing turbo would require more oiling compared to a ball bearing turbo, but maybe in the case of these factory IHI turbos, the difference is minimal. Maybe the different part number for the Spec C models is due to other design differences in the engine bay rather than the VF36 being a ball bearing turbo.
#11833 | |
Member#: 50586
International
![]() Quote:
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 08:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 05:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 10:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 04:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 02:56 AM |
