#1 |
Member#: 92114
Vehicle:03 WRX (NAVY Camo) in"Special Ed." Run Group |
![]() I just ordered a set of BRIDE seats for my 03 WRX.
![]() They come with a set of "universal seat rails". Does anyone have any experience installing these. Is it as simple as I'm imagining or are there hidden problems just lurking around the corner. If someone's already installed these can you please give me an idea what to watch out for, i.e., side air bags have to be disconnected...does this cause a problem with the computer, etc., how easy is the fitup.. Thanks!
#2 |
Member#: 86175
Vehicle:2006 STI Steel Gray |
![]() i dont know if the universal brackets will work or not, ill let you tomorrow i have the same seats they just came in im going to install / modify the universal brackets to make them work TONIGHT so ill let you know what happens.... also as far as the air bag light yes it will throw a light, and to fix this go to radio shack and buy 2....3.3 ohm resistors make sure its not Kohm just OHM and basicall put it in the plug from one side of the plug to the other side of the plug and electrical tape it so it doesnt come off or OUT, and thats it.
#3 |
Member#: 72031
Vehicle:2017 SS 1LE |
#4 |
Member#: 62595
SCIC
Vehicle:04 WRX Cobb S2 World Rally Blue |
![]() arnt those Bride replicas?
#5 |
Member#: 111971
Vehicle:2002 WRX Aspen White |
![]() Nice seats!
#6 |
Member#: 69991
Vehicle:Leh Keen Approved '68 Volvo Amazon |
![]() get them from ebay? the varient brides! oh well nice looking seats
where in westerly are you, I live in Stonington right across the border. do i know u? |
#7 |
Member#: 17877
SCIC
Vehicle:2007 Exige S Storm Titanium |
![]() My Bride seats don't have "universal" seat rails. Mine are Subaru (WRX) specific. Sure those are really Bride? My local car shop owner says the new Brides are made in Taiwan.
San |
#8 |
Member#: 86175
![]() nice well, i just finished installing my seats, so for anyone that has universal rails that came with the seats..... i used them to put myn in and all i did was cut the lower tabs off the stock seat rails just the 4 tabs that stick down from the slide it self..... and i put all 4 of the tabs in the car and bolted them down set the seat on top of it got it where i wanted it to be tac welded it took it all out.. and welded it all together and that was it very simple if you have any kind of mechanical incline. but since you have the brackets for your car that made it easier, although i had the option to lower, or raise, and slant the seat forward and tip the seat backwords to give the bottom more of a bucket to sit in. due to i could cut weld, or adjust the tabs to how i wanted them.
#9 |
Member#: 17877
SCIC
![]() The Bride rails also give you adjustment capabilities, you just shim between the rails and seats. Again, are you sure you got Bride seats and rails? Never heard of Bride "universal" rails. Especially ones that need tabs welded on to make them work. Just because they say Bride, doesn't mean they are.
San |
#10 |
Member#: 508949
Vehicle:2013 WRX Hatch World Rally Blue Pearl |
![]() Hey guys, looking for a bit of help before I install my new Bride Stradia seats up front. I have a 2013 WRX Hatch and am curious about the passenger side air bag weight sensor. Does anyone know if I will need to remove the bladder weight sensor assembly from the OEM seat and reinstall it in the Bride, or if there is another solution. Bride makes a airbag seat canceller part but I am not sure if that works with what I am trying to accomplish. Basically, when I install the seats, I just want to make sure the passenger air bag still works like stock. Any feedback would be greatly appreciated!
#11 |
Member#: 243697
Vehicle:17.4 PSI ECUtuned 02 BLOD Cofounder|TopScoob31 |
![]() Look up the resister pin mod for the airbag plug
FS : 2006 STi Rear seats | theasianeffect | Interior/Dressup/Audio & Security | 9 | 06-05-2010 08:59 AM |
03 WRX tranny info wanted | claudem | Transmission (AT/MT) & Driveline | 2 | 01-14-2007 08:50 PM |
evo seats to wrx install with detailed instructions | hybrid gti 2 | Interior & Exterior Modification | 23 | 10-28-2006 09:03 PM |
captain chairs rear seats 03 wrx | abqkid | Interior & Exterior Modification | 16 | 03-29-2004 07:22 PM |
