Welcome to the North American Subaru Impreza Owners Club Tuesday December 10, 2019
Old 11-10-2019, 05:34 PM   #1
drave199
Member#: 500229
2007 WRX
Default Pennzoil euro 5w40?
2007 wrx 68k miles. TBE and intake, custom tune
Anyone have experience with this oil? I have only done one oil change since I bought the car and they (shop that did my tune) put in Castrol gtx 5w30. Iíve had to add about 1 qt to it since the change (about 4K miles) From what Iíve read, these cars seem to like the higher weight so thatís what Iím looking at. Seem the 5w40 castrol edge is a thin oil so I crossed that off my list. Iím not opposed to using the Rotella t6 but is there any concern with the new formula and it not being labeled with the api rating? It does get cold where I live in the winter, lows will average in the 20s for a few monthís and can get lower. I donít race the car, just the occasional spirited driving around town. I just want an oil that may not burn so much and my engine will like. Basically Iím between the pp euro 5w40 and Rotella t6. Thanks for the help
drave199 is online now   Reply With Quote
Old 11-11-2019, 10:05 AM   #2
bluesubie
Member#: 767
04 FXT
Edge 5W-40 is actually a little thicker at 100C than PP 5W-40 (14.1 cSt vs 13.3) but either is a good choice. The PP meets the same specs as Edge 0W-40. MB 229.3/229.5, Porsche A40, VW502, etc. Edge 5W-40 doesnít have the MB 229.5 but this is all splitting hairs between the three I mentioned.
And you should run synthetic in a Subaru turbo.
Old 11-11-2019, 03:41 PM   #3
drave199
Member#: 500229
2007 WRX
Thanks for the comment. Iíve seen your name on a lot of the oil threads Iíve read recently. So what would be your recommendation based on my application from these
Redline 5w30
Motul xcess 5w40
Pp euro 5w40
Rotella t6 5w40
Rotella t6 mv 5w30
Old 11-11-2019, 07:28 PM   #4
bluesubie
Member#: 767
04 FXT
Redline 5w30
Motul xcess 5w40
Pp euro 5w40
Rotella t6 5w40
Rotella t6 mv 5w30
Any except for Rotella MV. The reduced ZDDP is preferable for a DIT but not needed with port injection unless youíre trying to maintain warranty on a newer stock WRX/STI.
Old 11-11-2019, 11:40 PM   #5
drave199
Member#: 500229
2007 WRX
Fwiw after 3 different places I ended up at Summit and to my surprise they had Motul oil. I ended up getting the xcess 5w40. It amazing how much quieter the engine runs. I was going to get the redline. I read that the 5w40 was a very thick oil so thatís why I was looking at the 5w30, whatís your thoughts on that? I also have seen that apparently itís not API certified, is that a big deal? Thanks for the help
Old 11-12-2019, 08:57 AM   #6
bluesubie
Member#: 767
04 FXT
Red Line has a high HTHS so the 5W-30 acts like a 40 weight in the bearings. Itís not API certified due to the high anti-wear additives and detergents. Itís great oil though but probably overkill unless youíre tracking the car.
Old 11-18-2019, 12:12 PM   #7
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Truth about oil: Changing it at the proper interval is far more important than any other aspect (as long as proper viscosity). Especially if your built. I'm looking for an article written by one of the guys over at bobistheoilguy which articulated it so well.
I guess what I'm getting at here, is that you've chosen some pretty good and well known oils there. Any of them will be likely as good as any other of them. That being the case, a strict interval is your best friend.
bdubblu is offline   Reply With Quote
Old 11-20-2019, 11:41 PM   #8
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Use an OEM oil filter while you're at it. OEM filters are good, even the blue ones everyone hates on.
Scorpius is offline   Reply With Quote
Old 11-25-2019, 09:26 AM   #9
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Oem filters are bottom tier man... might as well get the cheapest filter you can find if you gonna go that route.
Watch this video and let me know if it changes your opinion:
Old 11-25-2019, 06:07 PM   #10
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
https://youtu.be/18ctlBsRcGs
Watched that months ago. All just opinion. Anyone can open up a filter and make a youtube video. Many engine builders require you use oem blue oil filter. If you're changing it out at 4k miles or less it's a good filter.
Old 11-26-2019, 12:09 AM   #11
danger1138
Member#: 279525
06 Fxt
^^better than a purolator boss oil filter made for our cars?
danger1138 is offline   Reply With Quote
Old 11-26-2019, 04:25 PM   #12
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Seems like you're dismissing the quality of the internals / construction. Why's that?
Edit: and I agree... a regularly and/ or more frequently changed filter is the key. Some have the same opinion on oil... that if you change your oil in short intervals, you can run a "lesser" oil with basically the same results.
Old 11-28-2019, 05:52 PM   #13
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
IIRC Purolater Boss doesn't filter down to the micron rating of an OEM filter. If you're okay with less filtering for long filter run intervals then you're good to go.
Old 11-28-2019, 05:56 PM   #14
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
I couldn't care less about what the end caps are made of or if some pleats are not perfectly spaced. Subaru did a good job with packing as much material into their filter as they could. I only run my oil between 3500-4000 miles anyways so an expensive filter is a waste to me.
If it works for Subaru and it works for Subaru engine builders who am I to complain about an OEM oil filter on a daily driven stock vehicle.
Old 11-28-2019, 08:55 PM   #15
Jersey Man10
Member#: 427632
2011 Impreza WRX
If you change it at low intervals it doesn't matter what oil or filter you use honestly.
I still run 5w40 t6 and sometimes Mobil1 0w40 with oem filter sometimes Wix.
Jersey Man10 is offline   Reply With Quote
Old 12-01-2019, 06:25 PM   #16
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Gotta be open to change though. Everyone used to run T6 including builders. Now itís been lesson learnt and Motul is the choice oil as far as most shops I know of.
Old 12-01-2019, 07:40 PM   #17
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Gotta be open to change though. Everyone used to run T6 including builders. Now it’s been lesson learnt and Motul is the choice oil as far as most shops I know of.
I was running Wix XP for years until I found they only filter down to 25 microns and are made for extended drain intervals, but everyone on the internet got a boner off these due to the 23 psi bypass rating.
I'm in the Redline oil camp right now.
Old 12-02-2019, 02:20 PM   #18
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
I don't get the bypass thing... If you think about it, it really doesn't matter. The oil could go through the filter once out of every 4 "passes" and you'd end up with the same filtration as it going through every pass.
Old 12-02-2019, 07:32 PM   #19
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Subaru engineers obviously disagree with you wholeheartedly.
Old 12-02-2019, 08:20 PM   #20
Waddlz
Member#: 395275
2012 STi
Subaru blue filters are where its at. 6$ a filter and spec'd for our car. The micron rating is great and you can buy a ton of them on Amazon and shipped to your door.
I dont use anything else on both my STi and my wifes WRX.
IAG says to use Motul, but I tried xcess 5w40 in my built engine and it doubled my wear metals after 3k miles compared to my Amsoil 10w-40/0w-40. YMMV. I won't ever use that stuff again.
Waddlz is offline   Reply With Quote
Old 12-02-2019, 10:11 PM   #21
Miles901
Member#: 436453
2009 Wrx
I have a 09 wrx with a IAG stage 2 going on 3 years already. I'm no expert what so ever when it comes to motor oils, but I've been using Castrol edge 5w40 for a little over a year (used to use motul 8100 xcess recommend by IAG)I changed my oil every 3k miles no exceptions. So far it's been decent but I might try Valvoline MST 5w40 just because I can obtain it locally.
Miles901 is online now   Reply With Quote
