Welcome to the North American Subaru Impreza Owners Club Tuesday December 10, 2019
Old 11-28-2019, 11:17 AM   #1
Dinner123
Member#: 503482
2010 impreza
Default Is it bad to let my car idle for extended periods of time?
Aside from the obvious greenhouse emission pollutants.
I sometimes work outside in below freezing temps and have to keep warm while I work and a car is the best option available to me.
So is it bad (mechanicaly) to let my 2010 impreza NA idle for extended periods of time to keep warm?
Dinner123 is offline   Reply With Quote
Old 11-28-2019, 06:00 PM   #2
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
I don't think there is a problem. When I use to carpool with my wife I found myself waiting for like an hour outside in the cold pretty frequently while idling. I just wasted fuel.
oichan is offline   Reply With Quote
Old 11-28-2019, 06:01 PM   #3
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Mechanically, I wouldn't think so. How long are we talking letting it idle?
Scorpius is offline   Reply With Quote
Old 11-28-2019, 08:43 PM   #4
08redWRX
Member#: 186068
2019 STi
As long as normal maintenance is completed you wont have an issue. I have utilized cars for work with tons of engine time but no where near the miles to match due to them sitting still non-stop idling. Just keep up maintenance and you're good.
08redWRX is offline   Reply With Quote
Old 11-28-2019, 08:51 PM   #5
Jersey Man10
Member#: 427632
2011 Impreza WRX
At least minimum 30 seconds. You're just wasting fuel if you're idling for longer amounts of time.
Jersey Man10 is offline   Reply With Quote
Old 11-29-2019, 09:43 AM   #6
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
'08 Mustang GT (the toy)
OP is not talking about idling to warm the car up. It's to warm him up while working outdoors in the winter. Note that he's in Canada . . .
Norm
Old 11-29-2019, 10:13 AM   #7
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Norm
It tends to get a wee bit nippy north of the border.
Old 11-29-2019, 05:02 PM   #8
honeybucket
Member#: 505996
I would do oil changes a little more frequently than normal during the winter months you're doing this extended idling.
honeybucket is offline   Reply With Quote
Old 11-29-2019, 05:19 PM   #9
Supraru
Member#: 23313
99' 2.5Rs
black
Get an engine block heater and find somewhere to plug it in!
Supraru is offline   Reply With Quote
Old 12-01-2019, 12:07 PM   #10
ThinWRX
Member#: 401876
2008 WRX
I usually wait until the rpms start to drop and the oil temp is over 100 before I start moving.
ThinWRX is offline   Reply With Quote
Old 12-01-2019, 12:57 PM   #11
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Did either one of you read OP's post?
Old 12-01-2019, 08:07 PM   #12
Rally344
Member#: 508929
I also live in Canada and did a fair bit of research on this topic. Like others have said, all you need to do is wait about 30 seconds before driving. That's to ensure that oil has reached the valve train. I do however let my car idle for about 1-1.5 minutes just cuz I like too lol, give the parts some time to expand a smidge. Just idling does take longer for the engine to get up to temp as opposed to driving. In the end it doesn't really make a difference, as long as you don't bounce off the limiter right after starting lol!
In regards with letting idle to keep warm, I don't think it damages anything. It was designed with sitting in traffic in mind when it's crazy hot out.
Rally344 is offline   Reply With Quote
Old 12-01-2019, 08:13 PM   #13
ThinWRX
Member#: 401876
2008 WRX
You will be fine, just wasting gas really.
Old 12-01-2019, 11:39 PM   #14
carsebuco
Member#: 482289
2018 STI
You could also do it like the other guy's dealership service guy did. Turn it on, immediately start driving and do a 2nd gear pull to redline to reach operating temps.
carsebuco is offline   Reply With Quote
Old 12-02-2019, 07:54 AM   #15
rtv900
Member#: 428511
2016 STI
oddly enough, this thread is not the "should I let my car warm up"
it is a "can I sit in it on a job idling so I can use the heat"
whether he can plug it in or not, he can't sit and run the heat with the engine off block heater or not
Old 12-02-2019, 08:05 AM   #16
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
So what's your solution for OP keeping warm when he's working outdoors in the winter . . . in Canada???
Seems to me "wasting gas" would be preferable to frostbite.
Norm
Old 12-02-2019, 12:23 PM   #17
raisingAnarchy
Member#: 408438
2016 WRX STi
CBS
Idle the car so you can stay warm, it is just a car after all. Maybe consider following the severe service schedule for maintenance instead of the normal one, just because idling can potentially increase fuel dilution of the oil. (e.g: if your manual says 6k mile oil changes, it might have another suggestion for 3-4k miles under severe service)
raisingAnarchy is offline   Reply With Quote
Old 12-02-2019, 01:05 PM   #18
Schoat333
Member#: 452248
2017 Base WRX
I have done it for years on all of my cars, and never had an issue. Like others have said, just do the maintenance regularly.
Schoat333 is offline   Reply With Quote
Old 12-02-2019, 03:46 PM   #19
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
I live in So Cal where it's 66 degrees F right now.
I got nothin.
Gallo2011 is offline   Reply With Quote
Old 12-02-2019, 05:16 PM   #20
rtv900
Member#: 428511
2016 STI
well, let's be honest, it's not when he's working outdoors, it's when he's sitting in his car doing nothing.
I'm guessing in Canada they don't pay people to sit in warm cars as jobs.
Old 12-02-2019, 08:12 PM   #21
pazzoduc
Member#: 493859
06 WRX TD Swapped
sorta black-ish
How do you know he is doing nothing? He could be catching up on computer work, making phone calls or who knows what that he does for a living.
pazzoduc is offline   Reply With Quote
Old 12-02-2019, 08:23 PM   #22
rtv900
Member#: 428511
2016 STI
the impression I got was that this was a solution for 'dead time' during working in remote outdoor locations. I'm not saying he's a bum and doesn't work at all.
sorry, just didn't seem like this was a question about a car being used as a mobile office
Old 12-02-2019, 11:00 PM   #23
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Well this thread took a turn for the worst.
Old 12-03-2019, 12:16 AM   #24
jeffambo
Member#: 507933
13 WRX Hatch
Its more difficult for the car to cool itself as it relies on the 'wind' from motion to cool the radiator but these cars nowadays can easily take it. I'd like to see someone just idle for as long as possible and see how long they can go.
jeffambo is offline   Reply With Quote
Old 12-03-2019, 07:13 AM   #25
rtv900
Member#: 428511
2016 STI
huh?
there are fans dude.
You can idle a car in 100 degree weather indefinitely and unless you have mechanical problems it will be fine
