Welcome to the North American Subaru Impreza Owners Club Friday December 6, 2019
Notices
Old 12-01-2019, 01:55 PM   #1
Augustine864
Member#: 453838
Default I need extra clearance in foreign (non-Subaru) country
Hey all. I have a 2016 Impreza that we shipped to Ecuador for our two years of work down here. Well, the roads in Ecuador are ****, and even the speed bumps are insane. We scrape on every one.
I was thinking maybe spacers or something could help, like 1.5”, but I don’t know much about it. Additionally, there are no Subarus in this country. No dealerships or anything, so the locals will not have had experience working with Subarus. How complicated are spacers (or lifting of whatever kind)? Is it more or less the same across platforms, or would the Subaru be way too different for them as far as installation?
We need to do something, but I don’t want to put the car in jeopardy. I also thought I had previously read that adding clearance to the 2016 Impreza platform was not a good idea, but I don’t remember where I read that.
Any help you can offer would be appreciated greatly.
Augustine864 is offline   Reply With Quote
Old 12-01-2019, 02:21 PM   #2
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
You can lift it to be at the crosstrek height which is I think 2” higher.
Can’t remember what all is needed search the forum for it though it can be done.
DieselDorf is offline   Reply With Quote
Old 12-01-2019, 02:48 PM   #3
Augustine864
Member#: 453838
Thanks. I think a crosstrek is 3” higher, but in any case I’m more concerned with the latter portion of my post, which is why a forum search wasn’t sufficient. At least not in a way that I was able to search it.
Old 12-01-2019, 09:19 PM   #4
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
https://forums.nasioc.com/forums/showthread.php?t=2900637&highlight=impreza+lift
Old 12-02-2019, 10:04 AM   #5
Augustine864
Member#: 453838
This helps a little, thanks. At least insofar as indirectly answering whether or not the locals would be up to the task. It sounds like it’s fairly complicated, if I’m reading that correctly?
Old 12-03-2019, 02:20 AM   #6
IHaveAHorse
Member#: 507873
You could install lift spacers or lift springs (King springs maybe?) which would give you an inch to an inch and a quarter of lift, and then install larger tires depending on what size wheels you have right now. I was looking into that the other day and I saw one member here had installed larger tires, I think it was flyboy1100. I'm not sure how much more of a lift you can get without rubbing on something. At least half an inch, probably. Plus you have bigger tires to absorb shock from the bad roads and soften the ride a bit.
IHaveAHorse is offline   Reply With Quote
Old 12-03-2019, 04:18 AM   #7
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
205/70R15 winter tires lift my car by 0.7".
Old 12-03-2019, 09:27 AM   #8
Augustine864
Member#: 453838
Thanks. Yeah, I was thinking spacers also, I just don’t know if that’s something that the locals can do or what (because they’ve probably never seen a subaru in their lives), or if spacers are so simple that it is effectively the same installation on most cars (including subaru). I’m not a car guy, so I just don’t know what I can expect these guys down here to be able to do with regard to a subaru. I don’t even know what size tires I have. Whatever is stock on a 2016 sport Ltd.
Then the thread that the other forum-goer here linked me to talks about different trailing arms and all kinds of stuff if you add spacers, and that really makes me wonder if it’s too complicated. If it were just a matter of adding the spacers and doing a wheel alignment afterward, I’d do it. We are going to sell the car at the end of this anyway. But if I need all kinds of other stuff swapped out, I’m less confident in having someone do all that on a car (and AWD system) that they’ve never seen before.
Old 12-03-2019, 03:07 PM   #9
IHaveAHorse
Member#: 507873
It's pretty much the same on any car. The only thing with lift springs/spacers is you need an alignment after you have them installed. It shouldn't be too hard but it's an added cost, I wouldn't drive around without modified suspension in any way without also getting an alignment.
Old 12-03-2019, 08:40 PM   #10
ObewanKenobi
Member#: 428583
2017 Impreza Sport
Venetian Red Pearl
Sorry, posted this in the wrong place.
ObewanKenobi is offline   Reply With Quote
Old 12-03-2019, 09:51 PM   #11
Blktrax
Member#: 220971
2002 WRX 224K Mi.
So given its a stock Sport Limited, it should have 205/50-17 tires stock.
Replacing them with 205/55-17 tires will increase overall tire height by 0.8" , increasing ground clearance by 0.4"
Here is a complete kit with 1.0" of lift. This kit is straight forward to install to anyone that works on cars. 1.0" is the max lift without significant suspension changes needed.
https://www.subtle-solutions.com/pro...a1e62fb95f7495
This would give a total of 1.4" of lift, then the alignment should be able to be set with the factory adjustments.
More than 1.5" of lift of the suspension would need longer rear trailing arms, and the front would need longer c/v axles (Crosstrek axles), or they may bind or separate, when flexed and turned hard, like very steep driveway entrances/exits
Blktrax is offline   Reply With Quote
Old 12-05-2019, 03:07 PM   #12
Augustine864
Member#: 453838
Thank you very much for this explanation, as well as the judgment that it should be straight forward for a typical mechanic. I will take a look at the tires this weekend to confirm what they are and then will probably run with this.
