Welcome to the North American Subaru Impreza Owners Club Sunday September 27, 2020
Old 12-01-2019, 02:35 AM   #1
siickwrx
Member#: 508913
Default Exhaust Leak
Hey guys,
I'm having trouble with an exhaust leak. I have an invidia downpipe mated to a greddy catback (I believe its the Revolution RS). I put a 3" flat gasket between the downpipe and greddy catback but it seems like there is a gap on top and it's producing a fat exhaust leak. How do I get rid of this leak? Car is an 07 WRX
siickwrx is offline   Reply With Quote
Old 12-01-2019, 08:43 AM   #2
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
3in flat flange to flat flange?
Sometimes the angles don't quite line up.
What can help:
Using different exhaust hangers
Using a spacer
Using 2 gaskets
Soapy water to test the fix. Good luck.
shadowsports is offline   Reply With Quote
Old 12-01-2019, 10:15 AM   #3
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
What can help:
Using a spacer
Using 2 gaskets
Quite right.
There are three hangers. I'd try to go into some theoretical thinking like:
If the back of the exhaust (2 hangers at rear) were lower, would that make the angle of the flanges line up better?
Same for the front hanger. That might need to go a little lower to enable the flanges to be parallel to each other.
I've also used Grimmspeed's exhaust gaskets to make things fit better. They're thicker so it makes it a little bit easier.
BeastianSTI is offline   Reply With Quote
Old 12-01-2019, 01:38 PM   #4
kopele
Member#: 363007
2008 STI
I've good success with RTV gasket maker, it's a little messy but does a good job.
kopele is offline   Reply With Quote
Old 12-02-2019, 01:53 AM   #5
siickwrx
Member#: 508913
Thanks for the advice guys! I put that red high temp rtv I had lying around on both sides of the gasket. It's working so far. Don't know how long that will last tho.
Old 12-02-2019, 09:20 AM   #6
MortonCharbo
Member#: 487057
2002 WRX Wagon
I used a remflex 8006. It's just a thick graphite gasket that forms to the two flanges when you tighten them together. I payed 8 bucks for it on Amazon.
I tried the GS gaskets with no luck. I used the rtv stuff and it lasted about a week.
MortonCharbo is offline   Reply With Quote
Old 12-02-2019, 09:26 AM   #7
BeastianSTI
Member#: 310506
2005 WRX STi
I've used those too. Worked well in my case, but I think it's difficult to fix exhaust leaks if the flanges just aren't lining up.
@OP - if you want to share some pictures of what we're talking about, that could be helpful (of the flange currently, and maybe the tip of your exhaust).
Old 12-02-2019, 11:26 AM   #8
raisingAnarchy
Member#: 408438
2016 WRX STi
CBS
Stick a shop vac hose in reverse flow setting in the tail pipe to test your fixes. That's how I did the leak troubleshooting on my Tomei expreme catback with those damn slip fittings.
raisingAnarchy is offline   Reply With Quote
Old 12-03-2019, 01:59 AM   #9
siickwrx
Member#: 508913
I'll try the remflex 8006 once my ghetto rtv fix fails haha. I'll try to post pics of the flanges whenever I get a chance to.
Old 12-03-2019, 10:26 AM   #10
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
Soapy water, best way to check for leaks and easy too.
Old 12-03-2019, 05:47 PM   #11
Jedi03
Member#: 491095
2009 STi Blue
get the seal for good gaskets from autozone...they are super thick and work great!
Jedi03 is offline   Reply With Quote
Old 12-04-2019, 11:42 PM   #12
metalheadsunite
Member#: 163465
I am not sure what the Greddy catback uses but I have Invidia downpipe and Cobb catback and had to use the Grimmspeed adapter with a flat gasket on one side and a donut gasket on the other. Ended up fixing my issue.
Like here: https://www.subispeed.com/2015-subar...5-wrx-2015-sti
metalheadsunite is offline   Reply With Quote
Old 12-05-2019, 01:36 AM   #13
siickwrx
Member#: 508913
I actually have that adapter. Does the cobb catback have a 3" flange or 2.5"?
Old 12-05-2019, 01:41 AM   #14
siickwrx
Member#: 508913
Also does anyone think it could be the way I bolted it up? If I were to torque the downpipe to midpipe first, would it eliminate the gap? I'll try that next but I want to see if anyone fixed a leak that way.
Old 12-05-2019, 01:13 PM   #15
MortonCharbo
Member#: 487057
2002 WRX Wagon
When I had my Cobb catback, 2.5, it used the stock donut gasket.
As for torque sequence, start at the front and work your way back. Dp to midpipe first. Then midpipe to axle back. That should minimize possibilities for leaks. It should also make it apparent if you need different length hangers in different spots to get everything lined up right.
Old 12-06-2019, 01:39 AM   #16
siickwrx
Member#: 508913
Thanks for the input, i'll try torquing in that sequence. I would much rather move my exhaust leak to the axle back to save my lungs lol
