Welcome to the North American Subaru Impreza Owners Club Friday February 26, 2021
Old 07-10-2019, 01:51 PM   #3626
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Wiring. I have a merged harness (courtesy of iWire), just haven't installed it yet. 5 cars and too many projects!
Old 07-10-2019, 03:29 PM   #3627
Kito818
Member#: 480045
2009 3.0L Impreza
Dark grey/light black?
Lol, okay that I can relate to, the driveway at my last house held 8 cars and I used that space at times.
Kito818 is offline   Reply With Quote
Old 07-16-2019, 03:04 AM   #3628
vicious_fishes
Member#: 158864
2003 SOHC destroker
so for those that have converted the 30r over to cable throttle, how'd you do the mounts for the cables themselves? i'm keen to see pictures
Old 09-01-2019, 02:37 PM   #3629
Kito818
Member#: 480045
2009 3.0L Impreza
Anyone with an EZ30 going through crank sensors? I replaced the one that came with my engine about 3 months ago when it wouldn't allow me more than 1500RPM and was STILL missing like crazy, now the 3 month old sensor is starting to skip, I'm getting the engine position error, which means crank sensor, but I don't understand why a new one died after only 3 months...
Old 09-14-2019, 11:04 PM   #3630
Kito818
Member#: 480045
2009 3.0L Impreza
Update for anyone that ends up looking for issues here, it was not the crank sensor it was the cam sensors(it could have only been one of the two but I replaced both since rock auto had them for 15$).
New question though, whats the difference between 10921aa070, 10921aa060, and 10921aa040 AVCS solenoids(the rear solenoids on the EZ30R)? Is it JUST the clicking of the connector, since the orientation of the ports clocked to the hold down screw is the same and they all have the 2 ports on one side and 3 on the other? Does anyone know if there is a functional difference?
Old 11-06-2019, 04:52 AM   #3631
vicious_fishes
Member#: 158864
2003 SOHC destroker
So I finally weighed the ez30. First picture is the engine minus ancillaries and injector covers, second picture is including the ancillaries (alternator, power steering pump, air conditioning pump) and the injector covers, i.e full weight. The injector covers weigh a combined 2.5kg. There was 2kg of oil in the engine without ancillaries (going to check the other one soon), and both still had the oem oil cooler/warmer attached, which is about 500g if you want to remove it.
Old 12-01-2019, 05:08 PM   #3632
jvangelder
Member#: 358395
05 STI
White with Rubber marks
Im mocking up plumbing for a turbo coolant and oil feed / return on an ez30'r'
Can I just use the heater core plumbing for feed and return? I will remove the TB circut as well when I modify everything
Oil feed from a sandwich adapter and return is planned though the passenger side valve cover, any reason I shouldn't go this way?
-Jacob
jvangelder is offline   Reply With Quote
Old 12-01-2019, 05:10 PM   #3633
Kito818
Member#: 480045
2009 3.0L Impreza
-Jacob
This is good information, if you find the answer somewhere else please let us know here too.
Old 12-01-2019, 10:47 PM   #3634
vicious_fishes
Member#: 158864
2003 SOHC destroker
-Jacob
yeah, though i'd use the oem oil cooler/warmer line personally.
valve cover is also fine.
Old 12-01-2019, 10:50 PM   #3635
jvangelder
Member#: 358395
05 STI
Can I just remove all the heatercore plumbing then? Or is that a necessary circuit and just loop it?
Car does not nor will it ever have a heater
Old 12-02-2019, 03:55 AM   #3636
Kito818
Member#: 480045
2009 3.0L Impreza
Yes, you can, when your HVAC controls are set to cool the heater core is bypassed anyway. If you'll never use the heater you can remove the circuit, but make sure you remove the internal ducting and heater core. Volume wise you lose about a gallon of water, and you will have to loop the heater core ports on the engine, just connect them together, or route them in and out of your turbo.
Old 12-03-2019, 09:04 PM   #3637
vicious_fishes
Member#: 158864
2003 SOHC destroker
uhhh not so sure about this dude, I'm pretty sure the heater core inlet comes from a Y connection between the heads. I'll go & check later today.
I'd just loop it.
Old 12-03-2019, 10:12 PM   #3638
Kito818
Member#: 480045
2009 3.0L Impreza
I'd just loop it.
On my engine it's two hoses from the right side of the engine(if youre in front of the car and staring at the engine), even if they are off a Y/T connector you just replace the Y/T connector with a straight one and you're done.
Old 12-04-2019, 08:08 PM   #3639
vicious_fishes
Member#: 158864
2003 SOHC destroker
yeah but i'm pretty sure if you trace one of them back it Y's out into the heads.
Old 12-05-2019, 07:01 AM   #3640
vicious_fishes
Member#: 158864
2003 SOHC destroker
yeah just checked, it Y's out of the heads. you have to loop it.
Old 12-06-2019, 02:50 AM   #3641
vicious_fishes
Member#: 158864
2003 SOHC destroker
Ok so I got some exact DRY weights of the ez30. Exactly 136kg without ancillaries, exactly 145kg with. This is with oil coolers removed and then all ancillaries/brackets/idlers/etc. Oil capacity is 6L.
Old 12-08-2019, 05:53 PM   #3642
vicious_fishes
Member#: 158864
2003 SOHC destroker
Hey gang, a couple of years ago I had a lightweight pulley for my EZ30 fabbed up by a local machinist and tried to get a group buy running on the forums but it never really took off.
I've had a couple of people message me about it since mentioning it around here and I can actually get a production run of them done but being a totally custom thing in a small number they're not going to be cheap... I'd need to get 10 ordered and they'd be $275USD each with post & paypal fees.
I just thought I'd make a post here in case anyone on this page might be interested - factory is 1756 grams and mine is 582 so the pulley I had made reduces the weight by two thirds whilst remaining exactly OEM sized, i.e not underdriven.
If you're interested, I'd need to get a $100USD deposit from ten people, so make a post in this thread if you are
Old 12-08-2019, 06:19 PM   #3643
jvangelder
Member#: 358395
05 STI
from the looks of it, the heater core loop is just like a 257 aside from the return y's to both heads ontop of the engine. I am going to loop the heater core circuit like I did on my 2.5 which never caused a problem. I am going to use the oil cooler / heater coolant lines for the turbocharger coolant circuit.
Old 12-09-2019, 01:21 AM   #3644
jacky4566
Member#: 358980
vicious_fishes what shop are you using for the CNC? Custom pullies shouldn't be more than $200 from a shop that knows what they are doing. Put your model into Xometry.com and see if they can give you a better price.
jacky4566 is offline   Reply With Quote
Old 12-09-2019, 10:07 AM   #3645
vicious_fishes
Member#: 158864
2003 SOHC destroker
that price does include paypal fees & post from here in aus though.
Old 12-09-2019, 09:16 PM   #3646
vicious_fishes
Member#: 158864
2003 SOHC destroker
yep there's another one that goes around through the OEM oil cooler and then into the side of the block down near the sump too and i'm pretty sure both are critical for proper cooling.
the hardlines weigh like a couple of hundred grams though so I wouldn't stress about weight savings.
Old 12-19-2019, 05:25 PM   #3647
jvangelder
Member#: 358395
05 STI
Forgot to post these up from ealier., i know its not ideal for a gravity drain, but if anyone wants one of these im making extra's and a few other sizes as they were requested
-Jacob
Old 12-21-2019, 11:00 AM   #3648
jvangelder
Member#: 358395
05 STI
For those with standalones, are you using a low side driver or highside for the ACVS solenoid?
Old 12-28-2019, 05:57 PM   #3649
S2 13BT
Member#: 366651
2006 Forester XT
Obsidian Black Pearl
I'm considering an EZ30R for my 2006 Forester XT. Essentially for the noise and to be a bit different, also something to do. Power goal is not crazy (300 wheel kw's, so 400hp). Obviously could be achieved with a build of the EJ255, but whatever. The Foz has a full STI drivetrain swap.
Couple questions though, as I've read through this thread but not sure...
I'm thinking Haltech Elite 2500. Is that going to work OK when it comes to the dash working properly and body computers etc. Everything will work as it's meant too?
And the big one is A/C. Have to keep it. I'm in Australia and it gets real hot here. I have no idea when it comes to A/C, but it seems the compressor (or something in the system) works differently on the H6 to the H4. I assume the EJ compressor won't just bolt up to the EZ bracket and all is well... Something to do with using 1 belt vs two on the EJ, so covering bases in case the compressor seizes it doesn't effect the Alt and PS??
Appreciate any help.
S2 13BT is offline   Reply With Quote
Old 12-29-2019, 10:56 AM   #3650
jvangelder
Member#: 358395
05 STI
Just looking at it quickly, the EZ30 compressor looks no different to me. Typical clutch style AC compressor. Ive not had a 3.0 car apart so I cant comment on the rest of the system.
I just looked at an EZ ac compressor on an ej style alt/ac bracket as its all I have to check against and the EZ is much narrower so it would not bolt up directly. Quickly looking at it, I don't see why a sandwich adapter couldn't be used to mate the two assuming one doesn't run out of space
However trumping all this, if the ez compressor doesn't have strange needs and works, I wouldn't worry about it seizing any more than I would any other car, these were not designed to only last 10kmiles and a few years.
-Jacob
Vag-Com cable resource thread cooleys04 Open Source Reflashes 283 04-03-2018 02:04 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 05:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-20-2007 12:36 AM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-17-2005 12:11 AM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 06:04 PM
