Welcome to the North American Subaru Impreza Owners Club Tuesday January 28, 2020
Old 12-03-2019, 05:52 PM   #1
azhiaziamsubie
Member#: 154142
2006 Impreza STi
CGM, ISM
Default Help LOUD Banging
Recently I started hearing this loud banging from under my car. Sound seems to be coming from under the shifter linkage area/passenger footwell area. It has only started at highway speeds in the rain, and goes away when I come to a complete stop. Will usually start again if I reach highway speeds. If I stay below 50mph it doesnít happen again.
I am unable to reproduce the problem in dry weather.
Can this be the driveshaft? Exhaust? Center diff? Iím at a loss.
azhiaziamsubie is offline   Reply With Quote
Old 12-03-2019, 06:21 PM   #2
Muffin15
Member#: 326958
2006 Impreza WRX
San Remo Red
Have you jacked the car up and looked underneath? It certainly sounds rotational and I would imagine that if it's causing THAT much noise it shouldn't be too hard to find. It sounds like something is getting hit against something hollow, maybe something wrapped around the driveshaft hitting your downpipe/exhaust?
Muffin15 is offline   Reply With Quote
Old 12-03-2019, 11:40 PM   #3
azhiaziamsubie
Member#: 154142
2006 Impreza STi
CGM, ISM
I have gone under and looked around. Nothing is clearly hanging or loose. The noise is not persistent and goes away after I come to a complete stop/slow down and does not always re-appear again.
The last time this occurred was last April when it rained, and it didn’t happen again until this past week when it rained again and has no re-appeared since the rain stopped ???? so I’m really confused.
I’m going to get under the again and check everything and try and move the driveshaft around, check the carrier bearing.
My downpipe flange snapped where it bolts t the trans. I’m thinking that might be the downpipe smacking something
Old 12-04-2019, 12:11 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Holy crap dude!!
You gotta get under there and see what's up. HOPEFULLY it's just a broken tab for the downpipe, but you really need to tap, shake, rattle everything under there to find it.
Old 12-04-2019, 12:17 AM   #5
azhiaziamsubie
Member#: 154142
2006 Impreza STi
CGM, ISM
Originally Posted by Turn in Concepts View Post
Holy crap dude!!
Thanks! Iíll do my best. If I canít figure it out myself Iíll be dropping the car off for a few days at GST most likely. Iíll report back when I solve the problem. Just looking for ideas here and if anyone has had a similar noise!
I just hope itís not the center diff. I sounds and feels like something it banging/smacking the frame/exhaust underneath the car. Scary and strange.
Old 12-04-2019, 11:51 AM   #6
Turn in Concepts
Member#: 93646
Many Track Records
If not the downpipe then the next thing I would check is the u-joints and the carrier bearing on the driveshaft along with the tranny mount and tranny subframe.
Either way, if you end up dropping it off at GST they'll get you sorted out. Great guys over there who know their stuff. Tell them we said hi, and that Mike's car is slow.
Old 12-04-2019, 05:59 PM   #7
azhiaziamsubie
Member#: 154142
2006 Impreza STi
CGM, ISM
Haha will do!
Old 12-05-2019, 11:41 AM   #8
Brother EddieJ.
Member#: 181617
2004 wrx
Dom3/IAG built hybrid
Hey this guy has the same problem as you
https://forums.nasioc.com/forums/sho....php?t=2913117
Brother EddieJ. is offline   Reply With Quote
Old 12-06-2019, 12:46 PM   #9
azhiaziamsubie
Member#: 154142
2006 Impreza STi
CGM, ISM
I believe I found the issue if anyone is interested.
Got under the car and couldn’t see any contact with the frame. I did find a spot where the driveshaft was banging the midpipe, directly under the drivers and passengers seat, which is exactly where I felt and heard the noise.
https://i.imgur.com/O7uZaKH.jpg
https://i.imgur.com/BWNLFul.jpg
It is right where the carrier bearing sits, and the carrier bearing did have some play, but not much play downward. Only when I pushed upward. Still might need to be replaced, and unfortunately that required the entire driveshaft to be replaced.
https://i.imgur.com/SJJUiai.jpg
The bracket on the downpipe was snapped off, so I had a welder fix it and position the exhaust with more clearance, hopefully this solves the problem!
https://i.imgur.com/qPC5mzv.jpg
Still Completely lost as to why I was only getting contact and noise in the rain????
Hopefully my issue is solved!
Old 12-16-2019, 05:52 PM   #10
whiplashz
Member#: 409729
2006 WRX
I was going to say this sounds very similar to when one of the bolts fell out of the bracket that holds the driveshaft up but it looks like you found it.
whiplashz is offline   Reply With Quote
