Welcome to the North American Subaru Impreza Owners Club Monday April 12, 2021
Old 08-22-2019, 12:22 AM   #26
MGigantelli44
Member#: 234591
2004 STI
These look great. Excited to see a set on a GD.
MGigantelli44 is offline   Reply With Quote
Old 08-22-2019, 02:02 PM   #27
Mach V Dan
Member#: 12029
Gold on 2018 WRX.
Dan
Mach V
FastWRX.com
Old 08-27-2019, 02:40 PM   #28
Mach V Dan
Member#: 12029
Gloss gunmetal on 2013 WRX.
Dan
Mach V
FastWRX.com
Old 10-03-2019, 08:11 PM   #29
kwiksti
Member#: 480195
2014 STI Hatch
Dan
Mach V
FastWRX.com
What size tires?
kwiksti is offline   Reply With Quote
Old 10-09-2019, 12:58 PM   #30
Mach V Dan
Member#: 12029
Originally Posted by kwiksti View Post
What size tires?
265/35R18.
Dan
Mach V
FastWRX.com
Old 10-19-2019, 07:52 AM   #31
kwiksti
Member#: 480195
2014 STI Hatch
265/35R18.
Dan
Mach V
FastWRX.com
Fender roll?
Old 10-21-2019, 05:24 PM   #32
Mach V Dan
Member#: 12029
Fender roll?
Yes, rear only.
Dan
Mach V
FastWRX.com
Old 11-02-2019, 12:37 PM   #33
Mach V Dan
Member#: 12029
Track tested!
Photo by Finish Line Productions.
Dan
Mach V
FastWRX.com
Old 11-18-2019, 10:58 AM   #34
Mach V Dan
Member#: 12029
Dan
Mach V
FastWRX.com
Old 12-04-2019, 11:36 AM   #35
Mach V Dan
Member#: 12029
Dan
Mach V
FastWRX.com
Old 12-15-2019, 09:01 PM   #36
Jakerwrx
Member#: 159811
2015 STi
For 2015 sti on stock suspension, what size tires?
Jakerwrx is offline   Reply With Quote
Old 12-16-2019, 01:15 PM   #37
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I am debating these or the Wicked Awesomes if I jump to a 6 pot brake setup
Do you have anyone fitting these on stock body GD cars ?
Gigs90 is offline   Reply With Quote
Old 12-17-2019, 12:01 AM   #38
Jakerwrx
Member#: 159811
2015 STi
Also would there be any rubbing for the same setup?
Old 12-17-2019, 06:18 PM   #39
Pat Bateman
DUNCE
Member#: 275442
This Face
Seats Five
Those gloss gunmetal wheels look great.
Pat Bateman is online now   Reply With Quote
Old 12-18-2019, 04:53 PM   #40
Mach V Dan
Member#: 12029
265/35R18
No.
I don't have any photos, but they'll fit. You'll be somewhat limited on the tire size -- I'd do a 245/35R18.
--Dan
Mach V
FastWRX.com
Old 12-23-2019, 02:04 PM   #41
Mach V Dan
Member#: 12029
Dan
Mach V
FastWRX.com
Old 12-23-2019, 03:01 PM   #42
ThumperSTI
Member#: 509765
2018 STI
2018 STI
Do you offer a fitment of an 18x10 that will not require any fender modification or have any other fitting issues?
Currently on OE suspension but will be moving over to coil overs come spring.
ThumperSTI is offline   Reply With Quote
Old 12-23-2019, 03:11 PM   #43
Mach V Dan
Member#: 12029
Originally Posted by ThumperSTI View Post
2018 STI
No, but you really can't run a wide-enough tire to make an 18x10 necessary without fender modification. About the widest you can run on that car is a 275-width tire, and that's perfect on an 18x9.5" wheel.
Dan
Mach V
FastWRX.com
Old 12-23-2019, 11:52 PM   #44
ThumperSTI
Member#: 509765
2018 STI
Dan
Mach V
FastWRX.com
Good to know.
Sorry Iím a bit new to the Subaru world. Thanks for the info.
Old 01-06-2020, 02:14 PM   #45
Mach V Dan
Member#: 12029
Dan
Mach V
FastWRX.com
Old 01-08-2020, 02:40 AM   #46
STIposer
Member#: 509888
2017 WRX STI
Lapis Blue
Oh these wheels are too good! I'm eyeing on a set for my 2017 STI.
Why did you choose the 18x9.5 +42 spec? Besides the fact that they fill the fender wells perfectly. How does this spec affect the suspension geometry and handling characteristics over the OEM 18x8.5 +55 wheels? Do they alter the scrub ratio significantly?
I've been obsessing with these questions lately because every post I come across only is concerned about rubbing or aesthetics and nothing regarding actual handling. I even sent you a PM Dan.
STIposer is offline   Reply With Quote
Old 01-16-2020, 10:20 AM   #47
Mach V Dan
Member#: 12029
Because you can fit a wide tire without hitting the struts or the fenders.
Wheels do not affect suspension geometry. The lower offset is necessary so the tires won't hit the strut, but the change is minimal -- 13mm. It's not enough to perceive any change in steering feel.
The term is scrub radius. Moving the wheels outward relative to the car increases the scrub radius, but again, in this case it's not enough to have any perceptible negative effects on handling. Also, the wider track reduces body roll and increases lateral grip.
Dan
Mach V
FastWRX.com
Old 01-24-2020, 10:39 AM   #48
Mach V Dan
Member#: 12029
Gloss gunmetal.
Dan
Mach V
FastWRX.com
Old 02-10-2020, 03:19 PM   #49
Mach V Dan
Member#: 12029
Dan
Mach V
FastWRX.com
Old 02-13-2020, 06:35 AM   #50
waitandbleed92
Member#: 33990
Hello the white car with #5 on the side in the first post those are 255/40 tires correct?
I read somewhere where the car was lowered on coils. Looks like you had to drop the back more than the front minimize the rake look is this true?
Also any fender mods for that car on that setup. Looks great.
waitandbleed92 is offline   Reply With Quote
