Welcome to the North American Subaru Impreza Owners Club Monday April 6, 2020
Old 12-12-2019, 03:16 PM   #1
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Default Master C's 2000 RSTi Coupe
Hello NASIOC!
I have been a long time member, lurked since 2004 when I bought my 2000 2.5RS coupe and signed up in 2008 when I finally moved over from rs25.com. Most of my build progress is on Instagram but since NASIOC now has image hosting I thought I'd start a thread.
Instagram: Chaecker5
I have owned this 2.5RS coupe since 2004 and it has gone through several evolutions:
2004-2006: N/A basic bolt ons, Apexi N1 exhaust, intake, HKS lowering springs
2006-2008: N/A-t build. Started with a small vf11 turbo and variable rate fuel pressure regulator and eventually got up to a TD04 and about 12psi of boost with emanage blue piggyback
2008-2012: built the original EJ251 with forged pistons, STi rods, and custom heads from delta cam. Ended up with a Greddy 18g and emanage ultimate piggyback and eventually had 800cc injectors and a Greddy 25g turbo running 21psi which maxed out my injectors and capabilities of the piggyback.
2012-present: decided to go full STi swap, shaved engine bay, chargespeed body kit, and go after my dream build. Life has got in the way along the journey but I have slowly been building.
Now that the thread is started, I will try and find pictures of the older build and share as it progresses.
Pictures as it sits today:
master c is offline   Reply With Quote
Old 12-12-2019, 03:40 PM   #2
lub
Member#: 343218
2004 WRX wagon
I need moar!
lub is offline   Reply With Quote
Old 12-12-2019, 06:13 PM   #3
pazzoduc
Member#: 493859
06 WRX TD Swapped
sorta black-ish
very cool stuff
Dah... no radiator build?
pazzoduc is offline   Reply With Quote
Old 12-12-2019, 06:20 PM   #4
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Originally Posted by pazzoduc View Post
very cool stuff
Process West V-Mount setup
Old 12-19-2019, 12:55 PM   #5
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Just scored a set of Defi Link gauges in white with green backlight to match the STi 10k rpm cluster I have. Won't be using the tach, but these should look good together.
Old 12-19-2019, 01:09 PM   #6
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Iím really liking what I see here.
Old 12-19-2019, 01:48 PM   #7
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
SUCH A TEASE!! Lessssss go Master C!!
just followed you I'm @elcucuy_sti
JDMJNKY is offline   Reply With Quote
Old 12-19-2019, 05:11 PM   #8
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Originally Posted by D-Rodman View Post
I’m really liking what I see here.
Thank you!
Thank you - When I am off work I will follow back! I enjoy tracking your builds
Old 01-20-2020, 05:06 PM   #9
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Quick update: built a custom bracket setup for the hella horns, designed a fuel filter mount for my AEM fuel filter, got the power steering system from Chase Bays routed, and am currently working on the fuel pump hanger/fuel tank and getting the engine oil cooler mounted/duct work completed.
Old 01-21-2020, 03:44 PM   #10
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
Love It!
stu is offline   Reply With Quote
Old 01-22-2020, 08:27 AM   #11
horsePOOGAS
Member#: 450712
04 STi
Followed you as well man. mine is @OG_Boo.Barusti
Love builds like these.
horsePOOGAS is offline   Reply With Quote
Old 01-22-2020, 11:29 AM   #12
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Followed back - thanks for checking out the build
Old 01-22-2020, 01:40 PM   #13
XROLLER
Member#: 1273
98 Impreza
RBP
following
XROLLER is offline   Reply With Quote
Old 01-22-2020, 08:37 PM   #14
kaos200
Member#: 2692
Well whaddawehave here?... Sub'd
kaos200 is offline   Reply With Quote
Old 01-23-2020, 12:37 PM   #15
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Rear fenders cut, welded, and ready for seam sealer. used stainless rivnuts and hardware for mounting the flares. Final fitment after paint will include a rubber weatherstrip seal around the flare to body mounting surface to seal up any small gaps and prevent rubbing.
Old 01-27-2020, 02:30 PM   #16
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
AEM fuel filter bracket complete:
Old 01-28-2020, 09:31 AM   #17
SubieSteveSTI
Member#: 511129
Looks amazing !
SubieSteveSTI is offline   Reply With Quote
Old 01-28-2020, 02:05 PM   #18
kaos200
Member#: 2692
Cool, what filter bracket is that?
Old 01-28-2020, 04:34 PM   #19
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Looks amazing !
Thank you!
Generic 2.5" billet aluminum bracket from siliconeintakes.com. They can be found at Jegs or Summit Racing too. Comes with rubber isolator so the finishes don't get marred and reduces vibration.
Old 01-30-2020, 10:56 PM   #20
kaos200
Member#: 2692
Originally Posted by master c View Post
Thank you!
Old 02-13-2020, 04:35 PM   #21
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
2/13/20 Update:
Finished modifying custom made master cylinder brace to mount AEM fuel filter and Apexi super grounding stabilizer.
Started on cleaning up the fuel tank which includes: degreasing, removing and replacing all hoses, delete EVAP system, and upgrade fuel pump hanger.
Pics:
Old 02-13-2020, 09:56 PM   #22
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
That fab work on the rear pitch mount though, lol JK MC. Diggin your work.
Old 02-25-2020, 04:49 PM   #23
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
haha thanks man - gotta hold the engine in place without a trans in there...
Got my Chase Bays power steering reservoir and coolant overflow reservoir mounted up this last weekend. Ordered some tools to flare the 5/16 fuel lines and re-bend them where I want them.
Old 02-25-2020, 09:25 PM   #24
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
That thing is nice... Do you know Chase?
Old 02-26-2020, 11:02 AM   #25
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
No, I just like their products. so far I am using their power steering kit, brake booster, brake line relocation kit, and coolant overflow. I am planning on getting one of their hydraulic handbrakes as well.
