Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 07-26-2014, 05:43 PM   #1
ripscarface
Member#: 395431
Default 2015 WRX Power cable for Amp
I would like to know if there is a specific hole to run the power cable for the amp from the battery into the car. I have seen some Youtube videos of people running the power cable through a rubber grommet but I don't want to open a hole in the rubber grommet. Does anyone know a different way? Thank you for your help in advance.
ripscarface is offline   Reply With Quote
Old 07-26-2014, 07:42 PM   #2
bobditts
Member#: 392683
2014 LS hatch
quartz blue
either the grommet, or drill a whole. Id say the grommet is the easier faster way. Just did it this way myself. Super quick and hidden. A better grommet to use than the one you have pictured is the one that the factory uses for its power wires from the fuse box. It is located behind the drivers wheel well.
bobditts is offline   Reply With Quote
Old 07-27-2014, 04:01 PM   #3
SubiDoogie
Member#: 391975
2015 WRX Premium
Galaxy Blue Pearl
You only have 2 choices:
1. Cut a grommet.
2. Drill a hole.
I don't see how drilling a hole would be considered a better solution, but it is a solution.
SubiDoogie is offline   Reply With Quote
Old 07-27-2014, 06:26 PM   #4
psyclobe
Member#: 395439
2015 WRX
Crystal Black Silica
Under the right wheel liner, where the hood latch release line runs, is a nice spot to sneak a cable through the gromit without cutting it.
psyclobe is offline   Reply With Quote
Old 07-30-2014, 07:54 PM   #5
ripscarface
Member#: 395431
Can you please provide a picture of this spot? Thank you guys for your responses.
Old 07-30-2014, 09:09 PM   #6
ramiec
Member#: 393994
2015 WRX
CWP
This video shows how to go into the driver's side fender for the last gen WRX
https://www.youtube.com/watch?v=l73IoBd1_kE
The 2015 should be similar, and I plan to do some exploring by following the Hood release latch line once I decide which amp to purchase.
ramiec is offline   Reply With Quote
Old 07-31-2014, 01:38 AM   #7
sebhockey
Member#: 138957
2016 WRX STI Limited
I can confirm, it's the same. I routed my cable in this manner.
When you open the hood the gap is hidden by a soft trim panel, just pop it off and there it is.
sebhockey is offline   Reply With Quote
Old 07-31-2014, 08:42 AM   #8
cpalada
Member#: 349476
2015 WRX Premium AU
Yep +1 confirmation. There is even a little spare "nipple" on the grommet down there that you can slice off that fits a 4AWG power cable perfectly tight!
cpalada is offline   Reply With Quote
Old 01-14-2020, 07:54 PM   #9
gurusan
Member#: 258165
2015 WRX
Has anyone run 1/0 gauge wire? Ideally I want 1/0, then a distribution block with 2 4 gauge wires under the seats.
gurusan is offline   Reply With Quote
